 Old 01-14-2012, 05:59 PM   #1
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
Default ATP 3071GTX Blanket
I decided to switch after talking to JP at EdgeAutosport. I'm going to forgo the BNR Stage 3 and go with the 3071GTX kit, which I ordered the other day. Been reading a lot of threads to get up to speed. I really want to keep temps down underhood. I've looked at a number of different turbo blankets but can't make a decision really. For the guys that have them on the ATP turbos, which one did you go with and did you have to modify it since we are using an internal WG?
I'm going to use the factory exh manifold for now, has anyone used header wrap on it?
Any advice would be appreciated....
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
 Old 01-14-2012, 06:03 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
they're pretty much all the same. I wouldn't header wrap the stock manifold, just use OEM heat shields is fine. I did silicone paint my stock manifold a little bit.
if anything, get the turbine housing swain coated, and header wrap the downpipe.
07 MS3
The original Genpoo Hater
 Old 01-16-2012, 02:44 AM   #3
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Just use the stock manifold heat shield. Due to the location of my t-bolt clamps I cut a little metal off the stock heat shield so it fit perfect.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 01-16-2012, 08:50 AM   #4
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
DJ sold me my blanket it fits great and its cheap. Ask him
 Old 01-16-2012, 10:01 AM   #5
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
A t3 turbo blanket doesn't fit cleanly over an IWG housing because the WGA rod gets in the way and so does the stock oil feed. I tried putting my t3 blanket on my k04 and it was pretty awkward. It will still help, just won't cover the whole housing.
2007 CTS-V - Trying to sell
Turbo Blanket KayWhy MazdaSpeed 3/6 - Turbo Induction 9 07-25-2009 02:18 PM
Page generated in 0.24907 seconds with 24 queries
