  • 1 Post By kvg823
 Old 01-28-2015, 12:21 PM   #1
cam1391's Avatar
Posts: 326   (View Stats)
cam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the world
Groaned at 26 Times in 14 Posts
Default Big Turbo Antisurge ?
I think my k04 has finally bit the bullet, so im getting ready to order a 3071 from atp with ewg setup. Ive seen a ffew different options for anti surge however and I cant seem to find which option is better. I know atp offers anti surge Porting, and another dealer also offers the standard garrett anti surge compressor housing option. Does anyone know if ATP's porting is better than garrett's standard anti surge housing?
cam1391 is offline   Reply With Quote
 Old 01-29-2015, 06:42 AM   #2
cam1391's Avatar
Bump
 Old 01-29-2015, 07:40 AM   #3
kvg823's Avatar
Posts: 58   (View Stats)
kvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant future
I can't speak from rubber-to-road experience, but I am waiting to install the ATP 3071r EWG anti-surge ported kit I bought from @EdgeAutosport.com; . I did a bit of lurking in the BT threads and read This sticky along with the posts within it to make my decision.
EdgeAutosport.com likes this.
2006 "GTMO Green" Speed 6
{ Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals }
{ TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy}
{TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs }
HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge }
AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt }
{ Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs }
{ Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint }
kvg823 is offline   Reply With Quote
The Following User Says Thank You to kvg823 For This Useful Post:
EdgeAutosport.com (01-29-2015)
 Old 01-29-2015, 06:57 AM   #4
Plimmer's Avatar
Posts: 695   (View Stats)
Plimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the world
On the GTX3071r I'd be surprised if the standard 4" inlet 2" outlet ATP compressor housing is different to the Garrett one.
Was: 2012 with GTX3071 and BF Goodrich g-Force Rivals
Now: 2015 Mustang GT 5.0, soon to be track toy
Plimmer is offline   Reply With Quote
 Old 01-29-2015, 07:20 AM   #5
shamie's Avatar
Posts: 952   (View Stats)
Are you talking anti surge or anti creep?
 Old 01-29-2015, 11:58 AM   #6
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
Two different events.
Anti-surge housings are explained by Edge and myself above.
Surging at low RPMS, occur (simply) when the engine is not flowing enough (think exhausting enough or fast enough) for what the turbo is trying to "force" into the engine, causing a significant pressure rise (opposing the compressor flow direction) at the compressor outlet.
Essentially, the turbo is trying to move more air into the engine than the engine is capable to ingest (high PR at the low RPM issue). The housing allows this excess air to be relieved through ports in the compressor housing as opposed to causing huge swings in pressure over the compressor wheels and causing shock waves. This can damage a turbo if left unattended. Anti-surge housings also do not increase compressor efficiency or flow and in some (very few) cases, can actually lower the compressor efficiency by 1 or 2 points. But nothing that is an issue.
Because of the larger size (volume) and the ability of the DI 2.3 engine to flow fairly well at low RPMS (not a volume or flow restriction), IMHO, an anti surge housing for a T3 series Garrett is not a "necessity" on the street. But, that is just my opinion and nothing else.
RalliartRsX is offline   Reply With Quote
The Following 2 Users Say Thank You to RalliartRsX For This Useful Post:
chaser27 (01-29-2015), Karleurope (04-18-2015)
 Old 01-29-2015, 03:07 PM   #7
cam1391's Avatar
Thanks for clearing that up. I suppose its just a difference in design of the porting. Id rather buy ported and not need it, then buy ported and fing out I need it.
 Old 01-29-2015, 07:45 AM   #8
I would suppose they are pretty similar and the results are minute enough on a "street" setup, you wouldn't even know the difference.
The idea for anti-surge housing is to push the surge line to the left somewhat. Good for small engines with a somewhat larger sized turbo. For the DISI 2.3, it has fairly good flow at low RPM/hi PR on the turbo. However, it's mostly used for the "bigger" type turbos so I am not sure what benefits you would see if any by going that route and spending the extra $$$ for it. Just my 0.02c
The Following User Says Thank You to RalliartRsX For This Useful Post:
 Old 01-29-2015, 10:55 AM   #9
Anti surge prevents damage to the turbo in the event that surge occurs by giving the air a path of least resistance to escape around the blades rather than back out through the blades.
We're All Thieves (06-01-2015), WetzMS3 (01-29-2015)
Los Angeles: 2014 Porsche Panamera Turbo S is a 911 Turbo for the family man Haltech Automotive News 0 11-21-2013 10:20 AM
Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] Haltech Automotive News 0 05-03-2013 07:50 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
Page generated in 0.30553 seconds with 26 queries
