 Old 07-15-2013, 07:52 AM   #1
sheltbh's Avatar
Posts: 63   (View Stats)
sheltbh has a spectacular aura aboutsheltbh has a spectacular aura about
Default Big Turbo Install Help
I ordered a gt3076r EWG from edgeautosport and have a few questions for install so I don't f it up.
1) To attach the wastegate to the turbo and downpipe, I am assuming you take the large metal o-ring and place it inside each end of the wastegate. Then attach the appropriate ends, wrap the clamp around the lips (so wrap the clamp around the turbo lip and the wastegate lip pressed together) and then tighten it down.
2) What is this little piece for? It is hollow all the way through and has a weird looking washer.
3) What vacuum lines do I connect to the wastegate? It is a tial 38mm MVS with two side air ports, 2 side water ports, and 1 top air port. The old wastegate actuator had a line from the ebcs and the turbo. This new turbo does not have a place to attach a vacuum line so does it base the pressure of the turbo from the bottom of the wastegate? If so do I just connect the one air line to the ebcs, block off the remaining side ports and VTA the top?
Also there is one hose coming off the ebcs that is just open to the air, is this correct?
Thanks for the help!
sheltbh is offline   Reply With Quote
 Old 07-15-2013, 07:52 AM   #2
sheltbh's Avatar
Sorry for the large images too, not sure what I was supposed to do to make them smaller
 Old 07-15-2013, 08:01 AM   #3
cshunter's Avatar
Posts: 1,312   (View Stats)
Use MS Paint and Resize, or the longer process of uploading them to a site just to resize them.
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 07-15-2013, 08:01 AM   #4
cuethenoise's Avatar
Posts: 136   (View Stats)
cuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the world
Groaned at 6 Times in 2 Posts
I would donate before everyone comes in here
2012 Mazdaspeed3 w/ tech package
Stage 1 Stratified OTS
JBR Powerpath Stage 2
JBR 88a RMM
HPFP internals.
cuethenoise is offline   Reply With Quote
 Old 07-15-2013, 08:12 AM   #5
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
2 and 3 are related. 2 is quick tap boost source for turbo - intercooler hose, 3 is answered once you install that and find instructions on how to connect the EBCS.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 07-15-2013, 08:32 AM   #6
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
These are really basic questions and answers to this install. Did you research anything at all before buying the BT????
 Old 07-15-2013, 09:07 AM   #7
sheltbh's Avatar
Thank you soul survivor, this was what I was missing!
And yes I did research, I was planning on an IWG setup and at the last minute decided to go EWG since boost creep seemed to be a recurring issue with the IWG kits. This is my first turbo vehicle so I am still learning a few things.
 Old 07-15-2013, 09:15 AM   #8
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Same thing I was thinking... pretty basic questions for someone installing a BT.
1) Yes.
2) Tap for your boost source. Punch a hole in the silicone coupler coming off the turbo, push it through (from the inside out), place the nut and clip on the outside. The vac line for "boost Source" attaches here
3) Follow the directions for your EBCS. It'll explain how to connect to EWG
Needed: Driver mod
BNR turbo install versyejr MazdaSpeed 3/6 - Turbo Induction 2 03-21-2011 08:55 AM
dyi turbo install h0rsies MazdaSpeed 3/6 - Big Turbo Builds 24 08-03-2010 09:13 AM
turbo install help ms3guy22 MazdaSpeed 3/6 - Turbo Induction 3 12-08-2008 06:09 PM
Page generated in 0.28184 seconds with 26 queries
