 Old 03-09-2010, 06:51 PM   #41
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
07 SpeedSixxx
56k on motor
stock block
GT35R ATP fail for now--T3 soon
44mm Tial ewg---14 lb spring
Medievil Manifold, resurfaced
cpe 4 inch TIP
PnP Intake mani--vcts delete
ATP DP
CP-E cai
BSD
front and rear MM
FMIC
SB
egr delete
TT-rear diff bushing inserts
EDIT:more nonsense...
hks bov, turbo XS and greddy--switch when i want
MAXXXbore 63MM TB
Turbosmart in cabin MBC
soon getting a PTP HPFP and injector seals
some of these things are on the car now others are waiting for the nice weather to come around for the install
I plan to make as much AWHP as I can with the ATP fail hotside on the 35r until I reach 100k on the motor then I will build bottom up and go from there with the SB hopefully making upwards of 500AWHP....if thats even possible by the time I build my motor.
as of now I'm in the stock block boat with many other as I have faith in my motor.
a couple things in my list I don't even have yet like the SB but I'll have these things ready by the time I install my 35r and rape brians anus.
i'll make a thread when I do the instal
The Following User Says Thank You to SpeedSixxx For This Useful Post:
madvillain (03-10-2010)
 Old 03-09-2010, 06:53 PM   #42
cageyvet's Avatar
Posts: 715   (View Stats)
Greddy EBC solenoid is dead. Going to try and pick up a mbc tomorrow and drop the car off. Even if he starts tuning it again tomorrow I doubt it'll be finished b/c tuning with the AP is pretty time intensive. I'll wait until I see the end results of the tuning but I'm expecting good results.
The Following User Says Thank You to cageyvet For This Useful Post:
SpeedSixxx (03-09-2010)
 Old 03-09-2010, 06:56 PM   #43
SpeedSixxx's Avatar
Groans: 778
shoulda just went MBC from the start...
i hate ebc..they fail all the time , aside from being fail
 Old 03-09-2010, 06:59 PM   #44
cageyvet's Avatar
That's the second greddy profec b spec II that I've owned where the boost control solenoid died. Its a bad ass EBC when it works but the boost control solenoids have a reputation for failing.
 Old 03-09-2010, 10:01 PM   #45
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
My progress so far:
IC disconected
Intake removed
Inlet removed
EBC removed
Top heat sheild removed
Turbo studs removed
DP disconnected
3/10 manifold nuts removed
Things left to do:
Finish removing manifold
Drain oil and change filter
Disconnect oil/water lines
Remove stock turbo
Replace alternator and 'big-3' wires
Install new oil/water lines
Install new turbo w/open element filter
Reconnect DP
Test fit new manifold for fitment/clearence (once received)
Ceramic coat the manifold
Install manifold
Wire up EGT gauge
Install breather filter on valve cover
Install EWG
Reconnect IC
Refill oil
Go get dump pipe made
Wash car
Claybar & wax
Log
Tune
Log
Tune
Log
Tune
Log
Log
Log
Then shortly in the future:
Procure PTP S2 FP
Install said FP with the dual walbro in-tank set up
Change out 0.5 bar spring for 1.0 bar spring in EWG
Log
Tune
Log
Tune
Log
Tune
Log
Log
Log
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
The Following 5 Users Say Thank You to ATE BALLER For This Useful Post:
802MS3 (03-09-2010), Fagwagon (03-10-2010), kilik2 (03-09-2010), madvillain (03-09-2010), SpeedSixxx (03-10-2010)
 Old 03-09-2010, 10:14 PM   #46
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
thats an awesome list ATE, hopefully the new wife isn't giving you too much heat about all the work
'08 CWP MS3 w/ T3 3071r
 Old 03-10-2010, 09:04 AM   #47
ATE BALLER's Avatar
lol, not a problem. Who do you think bought me the turbo
 Old 03-10-2010, 09:34 AM   #48
spnkr21's Avatar
Posts: 2,827   (View Stats)
I'll give an update on my ride. I have built motor and pnp head. My welder ordered the piping last week for ewg setup. Once that is done I can put the 3071 on and start tuning for 400+hp. I'm running the car now with stock turbo and it is screaming for mercy. Spiking to 20 psi on stock tune.
2012 WRX HB w/mudflaps yo!
 Old 03-10-2010, 09:36 AM   #49
conso's Avatar
Posts: 186   (View Stats)
conso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the worldconso is the leader of the world
sorry im hiding
07 speed3, vivid has my car under house arrest
03 miata, top down
conso is offline   Reply With Quote
The Following 4 Users Say Thank You to conso For This Useful Post:
madvillain (03-10-2010), MarkyMark (03-11-2010), RayRayBauder (04-04-2010), SpeedSixxx (03-10-2010)
 Old 03-10-2010, 04:38 PM   #50
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
The day has finally come. I've just received images of my kit, the one off the shop car, and will begin its transit over to the lovely state of Arizona tomorrow morning on a Fedex truck. I HOPE to see it by the weekend, as Fedex delivers on Saturday, but I won't hold my breath.
KeysMS3 (03-10-2010)
 Old 03-10-2010, 07:32 PM   #51
cageyvet's Avatar
wtf, are they selling you a used kit???
 Old 03-10-2010, 08:05 PM   #52
madvillain's Avatar
Groans: 78
I chose to take it, and got a lot of money back. its better than waiting for god knows how much longer for the production kit, and I know the shit fits. Since the latest mid march date can no longer be met, i threw in the towel on it.
 Old 03-11-2010, 02:25 PM   #53
failure's Avatar
Posts: 77   (View Stats)
failure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant future
Groaned at 3 Times in 1 Post
You seem like a cool guy so I wish you luck on it. I wouldn't expect anything wonderful off of a shop car though.
failure is offline   Reply With Quote
 Old 03-11-2010, 02:48 PM   #54
^ failure has spoken.
madvillain (03-11-2010), MarkyMark (03-11-2010)
 Old 03-11-2010, 04:48 PM   #55
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
madvillain is cool beans so I wish him luck as well "HOPEFULLY" everything turns out alright
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
 Old 03-11-2010, 04:58 PM   #56
felt's Avatar
Posts: 1,504   (View Stats)
Groans: 1,364
OK, I guess I'll be the first to ask, can you share the pictures? I'm sure many will want to see them.
felt is offline   Reply With Quote
The Following User Says Thank You to felt For This Useful Post:
mpsanger6 (03-15-2010)
 Old 03-11-2010, 05:05 PM   #57
madvillain's Avatar
Groans: 78
I am by no means hanging on RR's nuts like many think, nor have I been this whole time. I simply want to share my experience with them, which has for the most part been positive, and for those who are on the edge to keep all the options open.
Although I've had a good experience, the situation is obviously not ideal. I will not share any of the pictures until I have the kit in my hand, but I can genuinely say that the kit looks great. There are a few things that still need to be worked out with Brice, but I am pleased to be on the home stretch, I just want everything to be over.
For those thinking that I'm getting bent over and fucked by getting the used kit, I am not. The price at which I'm purchasing it is more than fair, and the difference of money was back into my bank account within a day. Those who speak of RR as if they're sipping margaritas down on the beach in Mexico, are those who have never once spoken to them. Would I make the same choices as they have thus far? Hell no. But, its not my company.
Anyways, everything is on a fedex truck and en route. Fingers are crossed that it will reach me on Saturday
The Following 2 Users Say Thank You to madvillain For This Useful Post:
KeysMS3 (03-11-2010), SpeedSixxx (03-11-2010)
 Old 03-11-2010, 05:36 PM   #58
felt's Avatar
Groans: 1,364
Sounds good dude, can wait to see them!
 Old 03-11-2010, 07:14 PM   #59
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
Good luck man!!! Keep us posted. A lot of people had a lot of hopes and dreams riding on this kit, so let's pray that it is actually legit. I'm pullin for ya bud.
banditscout is offline   Reply With Quote
The Following User Says Thank You to banditscout For This Useful Post:
 Old 03-13-2010, 11:34 PM   #60
cageyvet's Avatar
They did some more tuning on the car today, things went by alot faster and the car would be done except for an unforseen error on my part. My tial 44mm ewg has a small blue spring and can only hold 14lbs. of boost with the mbc. My tuner said I need to run a large yellow with the small blue. The first tuning session i had on monday he was working on tuning out the KR i was seeing. Today, he continued doing that and on the first run @ 12 psi the car dynoed 279whp but it was runnning lean and hit boost cut. He added some fuel and adjusted the boost cut and the car made 288 whp @ 12 psi, afr at the sniffer @ the end of the exhaust was 12.11.12.20. KR was at 0 so he decided to up the boost on the MBC. First, run with the mbc turned up, boost spike ups to 20psi immediately and he lets off so the mbc can be turned down. Looking at the dyno graph from that run, 20+ psi is in the turbo's efficiency range b/c there was a dramatic shift of the graph to the left and the slope of the graph was very steep. He dials down the mbc, boost ends up holding 14psi @ the next run and the car made 308whp. He told me to he'd try to finish tuning the car later this week after I get another wastegate spring, but he said the car should definetly make 400. The highest KR i see now is .35 and my afr's are in the low 11's @ WOT. My car is being tuned by Huy Tran (inline racing).
The Following 5 Users Say Thank You to cageyvet For This Useful Post:
-cj- (03-13-2010), 06Speed6 (03-14-2010), Fagwagon (03-14-2010), kilik2 (03-14-2010), madvillain (03-13-2010)
 Old 03-13-2010, 11:41 PM   #61
madvillain's Avatar
Groans: 78
cagey- sorry if i missed it, but what kind of dyno are these numbers on? congrats on the progress
cageyvet (03-13-2010)
 Old 03-13-2010, 11:48 PM   #62
cageyvet's Avatar
Dynojet
 Old 03-14-2010, 10:24 AM   #63
ATE BALLER's Avatar
My progress as of now:
stock manifold removed
stock alternator removed
stock turbo removed
greddy e-01 removed
stock oil lines removed
began test fitting turbo
broke my finger
Things still to do:
modify new/old oil drain lines
find missing water line
place all new oil/water lines
mount new turbo
install iragge alternator
run all 'big-5' wires per iragge's instructions
install fresh serpentine belt
recharge and install battery
test fit ptp manifold when received
wire egt gauge and sensor
ceramic coat ptp manifold
install ptp manifold with ewg
construct dump pipe for ewg
 Old 03-14-2010, 11:04 AM   #64
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
lol how did you break your finger?
 Old 03-14-2010, 11:29 AM   #65
ATE BALLER's Avatar
haha, I was trying to break loose the bolt holding the turbo to the bracket undernieth it, and when it finally went, so did my fist right into a bulge in the firewall. It's not really broken I don't think, but more my knuckle is all fucked up, swollen, and throbbing.
 Old 03-14-2010, 02:32 PM   #66
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
ATE- might i suggest some medication like the one in your avatar. should solve some issues.
2008 STi
Intake
Turboback
AP
 Old 03-14-2010, 04:19 PM   #67
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Well it will be awhile before my Turbo setup gets installed and running since the motor is STILL blown. Still on the fence somewhat concerning whether to build the block I got or buy a running low mileage motor and keep that one stock. But I am now leaning towards building this block as I really want to see what my setup will make as no one else has run this yet.
Exh mani : custom one off T3 top mount Ceramic coated
Turbo : Turbonetics T3/T4 hybrid 50 trim with a .63 A/R hot side ceramic coated
BCS : Perrin ECBS
EWG : Tial 38mm w/ 14 lb. spring.
DP : Custom one off ceramic coated down to the flex joint
Screamer pipe is a custom one off that is also ceramic coated and is VTA
I was gonna sell my stuff (and still may) but was only interested selling it all together and not piece meal as I wanted to see what it would do. But since I mocked it up on my motor thats on my engine stand the damn thing is just to damn sexy looking and I know I'd be kicking myself if it put up good numbers. So what the hell is another $5 K when you consider what I've got in the car already right???
The Following 8 Users Say Thank You to SneakyP86 For This Useful Post:
802MS3 (03-14-2010), danesti (03-14-2010), Docnox (03-15-2010), kilik2 (03-14-2010), madvillain (03-14-2010), SpeedSixxx (03-14-2010), spnkr21 (03-14-2010), superskaterxes (03-15-2010)
 Old 03-14-2010, 04:19 PM   #68
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
ATE it might be broken get that shit looked at. I split my knuckle in half and just told everyone that its cool, and I kept playing basketball. The next day I looked like I had a grapefruit with fingers.
kilik2 is offline   Reply With Quote
 Old 03-15-2010, 08:54 AM   #69
Fagwagon's Avatar
Groans: 75
Still left to do....pretty much everything lol. This weekend im going to try and at least get the PTP internals installed if that goes well i will be taking the mani/dp/turbo off and mocking up the holset onto the medival mani to figure out what position im going to have to weld the new t3 flange on, if it goes well i might even have time to chop off the stock flange and tack up the t3 so i can bring it to someone who knows what they are doing with a welder lol.
 Old 03-15-2010, 10:51 AM   #70
ATE BALLER's Avatar
meh, I'll be alright, lol. The worst part is having to type at work. Plenty of herbal suppliments should keep the pain at bay til it's healed. Every one of my fingers had been broke at least once before I was even in highschool. Gotta love little-league football!
 Old 03-15-2010, 05:16 PM   #71
austin102085's Avatar
Posts: 1,195   (View Stats)
shit you might be done b4 me. FML!!!
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
The Following User Says Thank You to austin102085 For This Useful Post:
Fagwagon (03-16-2010)
 Old 03-16-2010, 09:27 AM   #72
Fagwagon's Avatar
Groans: 75
i seriously doubt it...im doing everything out of a buddys garage which is about 20 min away from me and i hate leaving the car there for weeks at a time
 Old 03-17-2010, 06:39 PM   #73
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
just got done putting my 3071, manifold, ewg, ebc, and half of the fmic back. i am excited to finish up tomorrow!
The Following User Says Thank You to dizzin9 For This Useful Post:
madvillain (03-17-2010)
 Old 03-17-2010, 07:09 PM   #74
cageyvet's Avatar
Drove over some incomplete construction on a pothole, couldn't change lanes and did some nice damage to my fmic. On a good note, I installed a (large green & small yellow) ewg springs along with the stock boost control solenoid. I would recommend using the stock solenoid over a mbc b/c it has eliminated the boost spike i was seeing from running a larger wastegate and is consistent.
 Old 04-04-2010, 07:57 PM   #75
madvillain's Avatar
Groans: 78
Bump.. anyone else make any progress? I iz stuck until I get back in town and have my ECU from Cp-e.
 Old 04-04-2010, 08:05 PM   #76
spnkr21's Avatar
Default Re: The Big Turbo Progress Thread
Was running 15psi and started dialing afr. Car was running great! Then the turbine inlet broke. Bummer.
 Old 04-04-2010, 08:07 PM   #77
i got my car back. its running good. just feels like it has less power then my reworked k04 on the ap. im useing the sb now with out any of the flashes. (holset h1c at 15psi ewg spring. )
2008.5 Mazdaspeed 3
 Old 04-04-2010, 08:31 PM   #78
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Damn i hope DCR makes good thats bullshizel
 Old 04-05-2010, 04:57 AM   #79
spnkr21's Avatar
Well I'm not even going to try and call them. I'm just gonna bring it to the welder and have him put a nice bead on it.
 Old 04-05-2010, 08:42 AM   #80
madvillain's Avatar
Groans: 78
that's probably wise. sucks man, i wish you luck!
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1441 06-25-2019 06:11 PM
Big turbo chicken thread phailerider MazdaSpeed 3/6 - Turbo Induction 111 07-01-2010 06:18 AM
Corb's Thread of Progress corbs Appearance - WHITE 98 09-17-2009 05:19 PM
Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread Kennosuke MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-27-2009 01:26 AM
Page generated in 0.58406 seconds with 39 queries
