Like Tree23Likes
 Old 12-19-2011, 12:44 PM   #81
RedBliss's Avatar
Posts: 245   (View Stats)
RedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the worldRedBliss is the leader of the world
What other options are there for going EWG other than the ATP .55 hotside? Obviously t3/t4 steedspeed EWG Mani is needed but what DP would work? ATP vband? So you could go t3 mani gt30/gtx30 with vband and ATP DP? If not what other options are there for EWG?
RedBliss is offline   Reply With Quote
 Old 12-19-2011, 12:45 PM   #82
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
CUSTOM!
07 MS3
The original Genpoo Hater
 Old 12-19-2011, 04:24 PM   #83
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
CUSTOM!
x2
using a different exhaust manifold, and the vband or bolt on dp flange, will effect the alignment of the piping...it is going to have to be fabricated.
Tabasco69 is offline   Reply With Quote
 Old 01-16-2012, 10:58 AM   #84
guerrero1977's Avatar
Posts: 32   (View Stats)
guerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant futureguerrero1977 has a brilliant future
[QUOTE=chimmike;1167665]If you use ebcs like grimmspeed, you can't target above what the stock MAP sensor will see, so you'll need a 3 bar. I recommend one anyways for accurate logging. Easy to hook up.
You'll probably need a 3" MAF by the time you need a 3 bar MAP sensor anyways.[/QUO
Any good source to get one?
guerrero1977 is offline   Reply With Quote
 Old 01-16-2012, 11:17 AM   #85
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT
plus the pigtail they sell.
Manny3 likes this.
07 MS3
Manny3 (03-15-2012)
 Old 03-03-2012, 11:47 AM   #86
ebrown0104's Avatar
Posts: 30   (View Stats)
ebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant futureebrown0104 has a brilliant future
subbed
ebrown0104 is offline   Reply With Quote
 Old 03-03-2012, 12:36 PM   #87
DEVAST8R's Avatar
Posts: 76   (View Stats)
DEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond reputeDEVAST8R has a reputation beyond repute
Subd
My Sprint EVO is a typical EVO epic for the first 8-10 seconds then falls on its face...
DEVAST8R is offline   Reply With Quote
 Old 03-24-2012, 02:53 PM   #88
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Holy shit! The car is so quiet with the big turbo!! It's the decency itself! I have never ever saw that coming! Even at 10PSI you can barely hear a whine coming from the turbo!
JP & Alex, thank you guys for providing me with what I needed to go the big turbo route!
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-27-2013, 08:59 PM   #89
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
So after reading this entire thread. It seems that I can do BNR S3 on my stock MAP and stock BC while staying under 22.xxPSI with no problems and a etune? My car is DD, what is the max PSI of the BNR S3? Will I need a new clutch?
redboat is offline   Reply With Quote
The Following User Says NO Thank You to redboat For This Un-useful Post:
faeker (11-27-2013)
 Old 11-27-2013, 09:35 PM   #90
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Mods: stock
The Following User Says NO Thank You to faeker For This Un-useful Post:
redboat (11-28-2013)
 Old 07-10-2014, 01:41 AM   #91
maas173's Avatar
Posts: 9   (View Stats)
maas173 is on a distinguished road
Groaned at 3 Times in 1 Post
can someone give me a quick list of what i might need in addition to exhaust mani, intake mani with meth injection, cs cams, gtx3076, 3 bar map/harness, pistons and rods, studs, bearings, seals, tune, motor mounts, intake, 5th/6th port injection? ive already got most of the bolt ons like fmic, dp, exhaust, bov...and reccomendations or advise would be great!
maas173 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to maas173 For This Un-useful Post:
faeker (07-10-2014), ms6mil (07-10-2014), Yousuf (09-05-2014)
 Old 07-10-2014, 02:27 AM   #92
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
What the actual fuck man..
A lot of that stuff you don't need, if you actually tried doing some research, you have some comprehension issues
Mod-bug's back...
 Old 07-10-2014, 06:40 AM   #93
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
don't forget oversize exhaust valves (+3mm should do the trick), VVT delete, battery relocation, rear suspension helper springs, and upgraded water pump.
Blue Pu.
pmartz16 (07-10-2014)
 Old 05-20-2015, 08:11 PM   #94
Lex2007's Avatar
Posts: 574   (View Stats)
This is a great post. Thanks for spending the time to put that list together, its just what I need.
I have tangential questions. So once you start making 400 hp or whatever...what starts breaking? Do the CV joints hold up? Can the clutch handle the torque? Can you pass emissions? Are stiffer engine mounts absolutely necessary to prevent wheel hop?
I did a big motor swap on another car a few years back and the domino effect was substantial.
The Following 2 Users Say NO Thank You to Lex2007 For This Un-useful Post:
Easter Bunny (05-21-2015), faeker (05-21-2015)
 Old 05-21-2015, 10:22 AM   #95
faeker's Avatar
Groans: 731
the tards be rollin in
Mods: stock
The Following 3 Users Say Thank You to faeker For This Useful Post:
aromig (05-22-2015), Easter Bunny (05-21-2015), mr.speedy3 (05-21-2015)
 Old 11-15-2016, 12:20 AM   #96
deltapsik0's Avatar
Posts: 72   (View Stats)
deltapsik0 is a jewel in the roughdeltapsik0 is a jewel in the roughdeltapsik0 is a jewel in the rough
I'm.doing my gt3071 build right now and injector dynamics said there is no upgrade to the injectors on my car because the stock ones cannot be increased in enough to warrant making an aftermarket direct inject injector for my 2008 MS3 disi turbo....what do you guys think of that?
Sent from my LG-H901 using Tapatalk
deltapsik0 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to deltapsik0 For This Un-useful Post:
g00s3y (12-15-2016), WetzMS3 (12-15-2016), zenit (11-15-2016)
 Old 11-15-2016, 09:04 AM   #97
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
DUDE, STOP WHAT YOU ARE DOING, AND READ.
 Old 11-15-2016, 11:33 AM   #98
I think Injector Dynamics told you correctly.
What do you think of that?
 Old 12-15-2016, 09:22 AM   #99
deltapsik0's Avatar
I think im not going to have to buy injectors lol
 Old 12-15-2016, 09:24 AM   #100
O rly?
That all depends on your power goals, doesn't it?
 Old 12-15-2016, 09:25 AM   #101
deltapsik0's Avatar
O rly?
True that. Who do you suggest as a manufacturer since ID doesn't make them?
 Old 12-15-2016, 09:30 AM   #102
You've got a lot of reading to do your grasshopper.
Quick summary, NO MANUFACTURER makes larger aftermarket injectors to replace OEM injectors. If you max out the OEM injectors and need more fuel for your goals, you will need to buy injectors. Except these injectors will not replace yours, they will be in addition to.
Go forth and read.
g00s3y and follman8r like this.
 Old 12-15-2016, 10:48 AM   #103
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Read, read, then read some more.
If you are asking basic ass questions that have been asked thousands of times, you're going to have a bad time.
Why are you going with a 3071? What are your power goals? What engine internals are you going to use? Who will tune you? What device will you use to tune? TMIC/FMIC? etc...
You have a lot of other things to learn about first, before you even think of going PI on this platform.
But that's the great thing about MSF, all of that knowledge is here, you just have to search and read.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/big-turbo-what-do-you-need-91114/
Full bolt on's...Tell me what ya think This thread Refback 09-04-2012 07:21 AM
GT3071R TWIN SCROLL This thread Refback 08-31-2012 11:25 AM
Future bad turbo? Vent kit fix? Turbo cleaner? Eric28243 Mazdaspeed3/6 General Discussion 6 06-18-2011 06:05 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.41813 seconds with 36 queries
