![]() | | #41 | ![]() |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2008 Location: Marlton, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score yah MBC or EBC - both are better than stock is what i'm reading
__________________ 2009 Mazdaspeed3 SOLD! Summit Point Main 1:32.725 (on all seasons) Lime Rock Park 1:05.419 (R888) Pittsburgh Int. 1:09.594 (R888) NJMP Lightning 1:21.203 (R888) 2013 Ford Mustang GT NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons) NJMP Lightning - 1:20.087 (modded car with 245 summers) Pocono North - 1:06.xx (Dunlop SP600 245x18) wet Pocono North - 1:00.655 (275mm Conti Slicks) Lime Rock - 1:07.2 (Dunlop SP600 245x18) 1989 Honda CRX Si VIR Full Course - slowww Summit Point Main 1:35.230 Renault Spec Racer Lime Rock Park 1:04 VIR Full Course 2:30 |
![]() | | #43 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score I listed the EBC as an option in my build thread. At $105 for a plug in 3 port I don't know why you wouldn't upgrade, but you don't HAVE to have it. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | InFeXIoN (11-18-2011) |
![]() | | #44 | ![]() |
| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
| *noob question*: What's the goal on having a MBC when you can control boost with the AP?
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() | | #45 | ![]() |
| Not Ranked : 0 score once you go BT the stock solenoid can't keep up too well is what i've read. also it only goes to 22psi or so accurately?
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
| Not Ranked : 0 score I believe its the MAP sensor that cant read above 22.73psi or whatever. But yeah, you definitely want to go aftermarket with either MBC or EBCS.
__________________ 2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD 2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's Lund Tuned 683whp/622wtq 11/11/16 Upcoming mods: Full-length Headers and ID1300s for E85 1995 Mazda Miata: Stock (daily) |
![]() | | #47 | ![]() |
![]() Join Date: Jun 2010 Location: Toronto, Ontario, Canada
Rep Power: 297 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 899
| Not Ranked : 0 score Noob question. With a big turbo, is a full TBE recommended or would the stock CBE be sufficient flow?
__________________ 2010 Black Mica MS3 Mods to date: Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071 Mods to come: Driver Mod || Snow Performance Meth Kit |
![]() | | #48 | ![]() |
| Not Ranked : 0 score i dont think anyone has done a before/after dyno but i'm curious just how much the stock will flow.... 400 wheel?
| The Following User Says Thank You to martin_nj For This Useful Post: | fywdyl (10-12-2011) |
![]() | | #49 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score Realgib made 400whp with stock exhaust manifold and CBE, so flow thru stock exhaust is not a problm. As for using stock ebcs........I'm doing that right now. While not optimal, it seems to be doing just fine.
![]() | | #50 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score where can i find the other parts that go along with changing the injector seals. i am adding a new fuel pump, injector seals and 3.25 maf to my set up in a couple months and i want to make sure that i have all the small parts covered. right now i am running a gt3076r with dp, cobb ap, intake, inlet, atp front mount. i would like to know some good advise on a manifold that i should get and also i would like to change my setup to external gate. how would i go about doing this? thanks for all the posts guys and i look forward to the advise. |
![]() | | #51 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
Groaned at 30 Times in 25 Posts
| Not Ranked : 0 score the biggest thing you need....money...add it to the list plz.
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler |
![]() | | #52 | ![]() |
![]() Join Date: Apr 2011 Location: southern california
| Not Ranked : 0 score fuck my life. i wish i never read this thread. there goes all of my tax returns... or a willingness to have NO money...
__________________ 2006 mazdaspeed6 "work in progress" Last edited by dterranova; 11-07-2011 at 10:05 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Doooo iiiiiittt
![]() | | #54 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
3071r-480hp 3076r-525hp Unless you upgrade to the 3076r why bother.....it is not like there are a lot of 500whp ms3 floating around here either, a very small handfull of them. I run a gt2871r .62 hotside, I 'am getting 340whp/350ftlbs @17psi and it has a ways to go before it is near being maxed out- for me it is a good comprimise, nice linear powerband, a lot less torque steer, not a dyno queen but for me it is all about the powerband, .72 trimm IDK if I would like that very much, I don't care about the topend if I have to sit there and wait for it to spool, not an expert on twinscrolls but I have been told by quite a few fellow mucks that ts is not advantageous until you move up into gt35 series and above...face it small mid frames have no problems with spooling and that is the big deal about ts, running a gt35 that spools quick like a gt28/30 Last edited by Tabasco69; 11-13-2011 at 02:55 PM. | |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2011 Location: NY
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Just bought a gt2871r got a ATP dp, cai, Cobb ap what do I definatly need before I put in the turbo ? |
![]() | | #56 | ![]() |
| Not Ranked : 0 score balls of steel how did the math work out on this? if you're at 17psi now what psi would u need to see 460hp?
__________________ 2009 Mazdaspeed3 SOLD! Summit Point Main 1:32.725 (on all seasons) Lime Rock Park 1:05.419 (R888) Pittsburgh Int. 1:09.594 (R888) NJMP Lightning 1:21.203 (R888) 2013 Ford Mustang GT NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons) NJMP Lightning - 1:20.087 (modded car with 245 summers) Pocono North - 1:06.xx (Dunlop SP600 245x18) wet Pocono North - 1:00.655 (275mm Conti Slicks) Lime Rock - 1:07.2 (Dunlop SP600 245x18) 1989 Honda CRX Si VIR Full Course - slowww Summit Point Main 1:35.230 Renault Spec Racer Lime Rock Park 1:04 VIR Full Course 2:30 Last edited by martin_nj; 11-18-2011 at 01:06 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Depends on supporting factors that effect it's effeciency, ie contrictive intake or exhaust impact the numbers, availible fuel supply, IAT's, MAF capacity or clamping oh and btw when you help tc out with supporting improvements for example moving to a better flowing exhaust/dp I went from 340 to 358 exact same boost Garrett does not specify but assume this is hp to the crank, factor 12-15% parasitic loss through the drivetrain, for 4wd as much as 25% loss, but we look at the power that meets the road.... to us that is what counts .15 x 425chp = 361whp (close enough for estimate) *base dyno non fi 138whp *17lbs boosted = 358whp (358-138= 220/17 = 13) so 13whp per lb of boost so many variable to factor though but say a gt2871r is good for 24psi, 24x13=312 whp in addition to what the motor would make without it. this all is conjecture btw. Last edited by Tabasco69; 11-18-2011 at 06:32 PM. |
![]() | | #58 | ![]() |
| Not Ranked : 0 score agreed that it is all conjecture, and i follow the reasoning, seems sound. main flaw i see this one. 24psi? isn't that a bit high?
![]() | | #59 | ![]() |
| Not Ranked : 0 score LOL more conjecture, I don't think it is high, or the ragged edge but I don't inttend on finding this out, I 'am sure there are some people who have tested it to it's limits of failure. Based on |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I am getting ~ 400hp out of my 2871, with a bit more timing you might get as much as 425 but I am knock limited right now. That's at 22psi, which is about as much as the turbo has in it reliably. You could push it higher but I don't think you will gain much from it. It is right on the right side of the compressor map.
| The Following User Says Thank You to Ziggo For This Useful Post: | rfinkle2 (12-19-2011) |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Yeah I think to get into the maximum effiency of a gt2871r you need to be near or aleast 20psi, I agree about 22psi seems like the maximum you want to push it reliably, if that is not enough then it's time for a 30 series, myself I would go to a gtx3076r. ever consider injecting 50/50 meth or alcohol? that would allow you to advance the timing and get you to 425....but then again it is one more part that can potentially fail, kind of what has me on the ropes about it....aquamist seems to be the best system for the money, but it is a lot of money, I looked at aem system, I have heard about their controler being very unreliable though.....snow or devils own? |
![]() | | #62 | ![]() |
![]() Join Date: Dec 2009 Location: queens, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Any boost creep associated with the gt2871 ? |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2008 Location: Raleigh, NC
Groaned at 14 Times in 4 Posts
| Not Ranked : 0 score If you are still on the stock seals and don't want to chance screwing up something that isn't broken, would it still be reasonable to give them a better chance of surviving by replacing the holddown assemblies? |
![]() | | #64 | ![]() |
| Not Ranked : 0 score internal wastegate, yeah I had some, depends a lot on the dp flange design, the flange needs to be recessed enough to allow the poppet to fully open, whoever designed my dp did not do this and the vlave could only open maybe 30%, not a big deal running low boost but your fucked once you start making a lot of boost. I ended up tack welding the iwg acuator stem and going to a 38mm tial ewg with a 1.5 divorced dump vta Actually I had a fuckton of creep that oversped the compressor, I can say without a doubt 30psi surge will fuck the compressor blades up new chra installed example of a bad flange design that limits the iwg poppet valve travel if you stick with the iwg setup ATP makes a welldesigned dp flange ![]() I was working with what I had....a t25 turbine, if you are going to buy a new tc get a t3 turbine housing and find or have a custom dp fabbed....and a steedspeed or custom tc manifold, cant you add a ewg flange to the collector of the stock ms3 mani?, optimum placement of the gate is off a collector of all four runners pre tc. I did it like this Last edited by Tabasco69; 11-23-2011 at 09:59 PM. |
| The Following User Says Thank You to Tabasco69 For This Useful Post: | blkspeed307 (11-22-2011) |
![]() | | #65 | ![]() |
| Not Ranked : 0 score Gotcha thanks for reply . Still trying 2 figure out what bt route 2 take Gtx 3071r or gt 2871r , not looking for big HP numbers for a dd, & want to keep my upgraded UR dp & tp & corksport tmic have autotech fp internals already. Thanks |
![]() | | #66 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score Is it advisable to get a 3 bar MAP sensor?
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
![]() | | #67 | ![]() |
| Not Ranked : 0 score If you want accurate readings above 22.xx psi yes. I dont have one and im making some pretty decent power, I just have a good boost gauge and an mbc. |
| The Following 4 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
![]() | | #68 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score If you use ebcs like grimmspeed, you can't target above what the stock MAP sensor will see, so you'll need a 3 bar. I recommend one anyways for accurate logging. Easy to hook up. You'll probably need a 3" MAF by the time you need a 3 bar MAP sensor anyways.
| The Following 5 Users Say Thank You to Chimmike For This Useful Post: | bob^3 (12-25-2013), EdgeAutosport.com (12-15-2011), iLLin (04-21-2013), redboat (11-27-2013), rfinkle2 (12-15-2011) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score IMO, ATP should make a GTX2871. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | adlpb (12-15-2011) |
![]() | | #70 | ![]() |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
| Not Ranked : 0 score Yes sir. I agree. The only thing that is stopping me from going BT (other than moniez) is the fact that it would kill my auto cross times with the lag. Even the GTX3071 has some lag, spooling in the mid-high 3K's. If they would come up with a GTX2871, I'd jump all over it. I'm reaching 20psi at around 2900. Not that you would reach that in autocross, but the sudden delivery of power at unexpected (higher) rpm's during turns is not good...IMO
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
| The Following User Says Thank You to adlpb For This Useful Post: | rfinkle2 (12-15-2011) |
![]() | | #71 | ![]() |
Until the bigger injectors and fueling solutions hit the market, I can't commit to a BT. I'd like to continue to run some e85, but don't want to use meth as a crutch. | |
![]() | | #72 | ![]() |
| Not Ranked : 0 score they make a gtx2860 and 63 problem is the regular gt2871r still out performs both of them by a good margin, I agree they should make a gtx2871r version...the compressor wheel is the ONLY difference between gt and the gtx. this swag but a regular 71r can push close to 40lbs of air per minute, which puts you close to 400hp, say the new compressor wheel jack up the flow another 6-7lb/min and that is about a 60-70 hp gain while staying within the sweet spot of it's peformance map |
| The Following User Says Thank You to Tabasco69 For This Useful Post: | rfinkle2 (12-15-2011) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score You don't need a GTX2871 to max the injectors if you are mixing, and based on my results you need some octane boost once you start going north of 300hp. Getting above 400hp on the 2871 is more than possible. I am right there with a 3/9 mix and there is a slight bit more headroom on the injectors so a 4/8mix and a couple more degrees of timing and you are right there. Repeating myself here, but that's a big reason why I stuck with the smaller BNRS3. I reach my boost targets just before 3k rpm. It doesn't go all the way to 20psi cause I am limiting it to ~400wtq Zigatapatalka
![]() | | #74 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score 20psi at 2900rpm on anything but a stock turbo will not help your autocross at all. All that will do is assist in breaking traction sooner.
![]() | | #75 | ![]() |
| Not Ranked : 0 score this is not true if you use the new Gorilla Glue tires that tire rack sells
![]() | | #76 | ![]() |
I want to continue to run some e85, and there is no way I could run the concentration I am now with the stock fueling (@ least from what I can gather). If I could have a consistent 400 wtq through most of the power band, I would be plenty happy. | |
![]() | | #77 | ![]() |
Groans: 433
I don't think I'd want to push an S3 there, IMO the benefits of the 2871 far outweigh the negatives for going that route vs. S3.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
| The Following User Says Thank You to Chimmike For This Useful Post: | Ms3_Miami (12-23-2011) |
![]() | | #78 | ![]() |
It is really hard to get a handle on what can / can't be done with all of these turbos, as far as power levels vs. fueling. | |
![]() | | #79 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score my gtx76 has no creep. I wasn't aware that Jackson was fighting creep on his gtx71. I didn't do any porting.
| The Following User Says Thank You to Chimmike For This Useful Post: | rfinkle2 (12-19-2011) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score I'm pretty sure he just posted he is creeping (x>26 psi) in ckmazdaspeed3's build thread. EDIT: hyperlink to Jackson's post here: ckmazdaspeeds big turbo build 1 I know cld12pk2go ported his before even installing. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/big-turbo-what-do-you-need-91114/ | ||||
| Full bolt on's...Tell me what ya think | This thread | Refback | 09-04-2012 07:21 AM | |
| GT3071R TWIN SCROLL | This thread | Refback | 08-31-2012 11:25 AM | |
| Display Modes | |
| Future bad turbo? Vent kit fix? Turbo cleaner? | Eric28243 | Mazdaspeed3/6 General Discussion | 6 | 06-18-2011 06:05 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | Haltech | Automotive News | 0 | 02-16-2010 03:20 PM |
| First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo | Haltech | Automotive News | 2 | 05-04-2009 06:48 PM |
