![]() | | #81 | ![]() |
![]() Join Date: Nov 2008 Location: Fitchburg, Mass.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
![]() | | #82 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score CUSTOM!
![]() | | #83 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
![]() | | #84 | ![]() |
![]() Join Date: Apr 2011 Location: Nahant, MA
| Not Ranked : 0 score [QUOTE=chimmike;1167665]If you use ebcs like grimmspeed, you can't target above what the stock MAP sensor will see, so you'll need a 3 bar. I recommend one anyways for accurate logging. Easy to hook up. You'll probably need a 3" MAF by the time you need a 3 bar MAP sensor anyways.[/QUO Any good source to get one? |
![]() | | #85 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT plus the pigtail they sell.
| The Following User Says Thank You to Chimmike For This Useful Post: | Manny3 (03-15-2012) |
![]() | | #86 | ![]() |
![]() Join Date: May 2011 Location: Jeannette, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score subbed |
![]() | | #87 | ![]() |
![]() Join Date: Jan 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score Subd My Sprint EVO is a typical EVO epic for the first 8-10 seconds then falls on its face... |
![]() | | #88 | ![]() |
Groans: 111
| Not Ranked : 0 score Holy shit! The car is so quiet with the big turbo!! It's the decency itself! I have never ever saw that coming! Even at 10PSI you can barely hear a whine coming from the turbo! ![]() JP & Alex, thank you guys for providing me with what I needed to go the big turbo route!
![]() | | #89 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score So after reading this entire thread. It seems that I can do BNR S3 on my stock MAP and stock BC while staying under 22.xxPSI with no problems and a etune? My car is DD, what is the max PSI of the BNR S3? Will I need a new clutch? |
| The Following User Says NO Thank You to redboat For This Un-useful Post: | faeker (11-27-2013) |
![]() | | #90 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score ..........................................
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
| The Following User Says NO Thank You to faeker For This Un-useful Post: | redboat (11-28-2013) |
![]() | | #91 | ![]() |
![]() | | #92 | ![]() |
![]() Join Date: Jan 2013 Location: Union City, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
Groans: 128
A lot of that stuff you don't need, if you actually tried doing some research, you have some comprehension issues
__________________ Mod-bug's back... | |
![]() | | #93 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
don't forget oversize exhaust valves (+3mm should do the trick), VVT delete, battery relocation, rear suspension helper springs, and upgraded water pump.
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
| The Following User Says Thank You to anavrinIV For This Useful Post: | pmartz16 (07-10-2014) |
![]() | | #94 | ![]() |
![]() Join Date: May 2009
| Not Ranked : 0 score This is a great post. Thanks for spending the time to put that list together, its just what I need. I have tangential questions. So once you start making 400 hp or whatever...what starts breaking? Do the CV joints hold up? Can the clutch handle the torque? Can you pass emissions? Are stiffer engine mounts absolutely necessary to prevent wheel hop? I did a big motor swap on another car a few years back and the domino effect was substantial. |
| The Following 2 Users Say NO Thank You to Lex2007 For This Un-useful Post: | Easter Bunny (05-21-2015), faeker (05-21-2015) |
![]() | | #95 | ![]() |
Groans: 731
| Not Ranked : 0 score the tards be rollin in
| The Following 3 Users Say Thank You to faeker For This Useful Post: |
![]() | | #96 | ![]() |
![]() Join Date: Oct 2016
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I'm.doing my gt3071 build right now and injector dynamics said there is no upgrade to the injectors on my car because the stock ones cannot be increased in enough to warrant making an aftermarket direct inject injector for my 2008 MS3 disi turbo....what do you guys think of that? Sent from my LG-H901 using Tapatalk |
![]() | | #97 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER | |
![]() | | #98 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
What do you think of that?
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #99 | ![]() |
![]() | | #100 | ![]() |
That all depends on your power goals, doesn't it?
![]() | | #101 | ![]() |
![]() | | #102 | ![]() |
![]() You've got a lot of reading to do your grasshopper. Quick summary, NO MANUFACTURER makes larger aftermarket injectors to replace OEM injectors. If you max out the OEM injectors and need more fuel for your goals, you will need to buy injectors. Except these injectors will not replace yours, they will be in addition to. Go forth and read.
![]() | | #103 | ![]() |
Groans: 438
| Not Ranked : 0 score Read, read, then read some more. If you are asking basic ass questions that have been asked thousands of times, you're going to have a bad time. Why are you going with a 3071? What are your power goals? What engine internals are you going to use? Who will tune you? What device will you use to tune? TMIC/FMIC? etc... You have a lot of other things to learn about first, before you even think of going PI on this platform. But that's the great thing about MSF, all of that knowledge is here, you just have to search and read.
| The Following User Says Thank You to g00s3y For This Useful Post: | WetzMS3 (12-15-2016) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/big-turbo-what-do-you-need-91114/ | ||||
| Full bolt on's...Tell me what ya think | This thread | Refback | 09-04-2012 07:21 AM | |
| GT3071R TWIN SCROLL | This thread | Refback | 08-31-2012 11:25 AM | |
| Display Modes | |
| Future bad turbo? Vent kit fix? Turbo cleaner? | Eric28243 | Mazdaspeed3/6 General Discussion | 6 | 06-18-2011 06:05 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | Haltech | Automotive News | 0 | 02-16-2010 03:20 PM |
| First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo | Haltech | Automotive News | 2 | 05-04-2009 06:48 PM |
