![]() Join Date: Nov 2011 Location: NY
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score I started my big turbo build and have been doing as much research as I can, but I can't find out if bigger injectors are a must? I know injector seals are a must which I already purchased but can find anything on larger injectors. Also my build as of now is ATP gt2871r, ATP turbo inlet, Cobb AP, injector seals, 3inch catless DP, with next three mods being larger injectors if needed, hpfp, and bov, followed by a tune. What do you guys think? |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score there arent any bigger injectors yet...and they shouldnt be necessary with the power levels you are going to get with at gt28, you definitely should get an upgraded fuel pump before you go live on the bt though. bpv probablyl wont be necessary, and the tune should be easy to get through some people on the board. |
| The Following User Says Thank You to ScarMS3 For This Useful Post: | Frecine (11-29-2011) |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score gt28 isn't a big turbo. go with a gtx3071 |
| The Following 2 Users Say Thank You to manelscout4life For This Useful Post: | captain slow (11-29-2011), stang9779 (11-29-2011) |
![]() Join Date: Feb 2011 Location: Cheyenne, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,031
| Not Ranked : 0 score so is your AP installed? or just bought it and want to just put a BT on? you are either a TROLL, an idiot, or so F*CKING new to this platform you dont know any better. Intro to Your MAZDASPEED
__________________ 2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011 2008 Black Ms3 SOLD Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs AP Dizzy Tuned by BUCKER CorkSport Interior LED Kit 2015 STi Limited in Lightning Red Stock bottom end died at 18K hard canyon miles. Current Mods after build Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune [11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap |
Groans: 97
| Not Ranked : 0 score he did list an ap in the stuff for his build so i guess you didnt read well |
(Thread Starter) | Not Ranked : 0 score Thank you for the quick responses. And I have an AP I listed it ablve. Also I didn't want to go to big for my DD. Thanks again. |
| Not Ranked : 0 score im sorry my response wasnt clear or i dont understand you fully. is your ap installed already or did you just buy it? my point was, if you dont have an AP already installed and you are trying to go BT, you should check out that link i posted. if you already have that AP installed and you are just choosing to go BT thats completely different story all together. so which is it?
![]() Join Date: Nov 2010 Location: Rutherfordton, NC
Rep Power: 312 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 31
Groaned at 28 Times in 15 Posts
| Not Ranked : 0 score Just swap out the DI injectors for a set of DSM injectors. Might have to use some shims and use some duct tape... but should work. |
| The Following 5 Users Say Thank You to Spirry For This Useful Post: | bcmurphy87 (11-29-2011), i8urgti (11-29-2011), Realgib3 (11-29-2011), ScarMS3 (11-30-2011), zpele (11-29-2011) |
Groans: 433
| Not Ranked : 0 score 2871 isn't going to outflow the stock injectors. I DD a gtx3076r and it's fine, so ain't nobody gonna tell me 3071 is too big to DD.
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score The OP didn't saying anything about this, but I feel I should add that a 2871 won't outflow the stock injectors if running on pump gas. You will run out if trying high E85 mixes. Tapadatass
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | reidclark (11-29-2011) |
![]() Join Date: Jan 2011 Location: Rockledge, FL and Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
| Not Ranked : 0 score To answer your question simply....no they are not a must, but get a new fuel pump...also your stock pump is a hpfp, just for future reference.
__________________ 2006 Mazdaspeed6/Cobb short ram/M2(eBay)DP/BC Coilovers/Denso ITV22's/Custom front mount/cooling mist water meth/Kmd internals/up next//Copp AP(again )/AMG reps/[SIGPIC][/SIGPIC] |
| The Following User Says Thank You to reidclark For This Useful Post: | Frecine (11-29-2011) |
(Thread Starter) | Not Ranked : 0 score Anyone knw where I can find the tune for ap specified for my turbo and mods other than getting it pro tuned! |
![]() Join Date: Dec 2010 Location: Springfield, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,536
Groans: 354
Groaned at 213 Times in 109 Posts
| Not Ranked : 0 score Im guessing you want something for nothing when you are only 5 posts deep?
__________________ 2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now) 2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy |
(Thread Starter) | Not Ranked : 0 score I'm am willing to pay I have been looking for a preformance shop in the local area where I live and I can't find one that is familiar with the speed3 just tryna get an actual tune and If I can get it online why not....but would I be able to download the pro turn straight to the ap ?! |
Groans: 433
| Not Ranked : 0 score You have zero familiarity with this car, so I'm gonna say, get it protuned by someone who can be hands on and can see if you've installed shit correctly or not. Also, having zero familiarity will not assist you in e-tuning with someone.
![]() Join Date: Jun 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
Groans: 58
Groaned at 134 Times in 68 Posts
| Not Ranked : 0 score Imminent fail detected.
__________________ US ARMY 07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me. 96 Red Miata // Not stock** Missing home... Florida ![]() |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
Groans: 398
| Not Ranked : 0 score Dude, sounds like you took a big leap. PERM tuning is pretty sweet and can pro tune you but they can only help you if your hardware is installed right and working properly, which it prolly isn't. You need internals stat!
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack |
![]() | | #19 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 6 Users Say Thank You to doubleflusher For This Useful Post: | Chimmike (11-29-2011), essejkcamraw (11-29-2011), i8urgti (11-29-2011), manelscout4life (11-29-2011), Realgib3 (11-29-2011), ScarMS3 (11-30-2011) |
![]() | | #20 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Research...
![]() | | #21 | ![]() |
![]() Join Date: Nov 2010 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
__________________ 2010 MS3 Velocity Red w/ Tech Package Custom FreekTune e85 mix Future Mods DO stage 2 WMI, Intake manifold of some type. |
| Possible bigger injectors? | Boosted Beluga | MazdaSpeed 3 - Engine, Transmission & Driveline | 31 | 07-30-2011 06:40 PM |
| injectors | Matx | MazdaSpeed 3/6 - Big Turbo Builds | 1 | 02-28-2011 03:31 AM |
| My Injectors... | SgtP | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 02-19-2011 09:08 PM |
| Video: Fórmula Truck - The bigger they race, the bigger they crash | Haltech | Automotive News | 0 | 08-02-2010 09:50 AM |
| Injectors | speeddemon | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 10-28-2009 11:49 PM |
