Like Tree20Likes
 Old 07-05-2012, 10:50 AM   #81
Realgib3's Avatar
Posts: 2,443   (View Stats)
I will do that reset after I do the bsd tonight.
I would also guess the reason people have this issue with an upgraded vvt is bevause it may to more force to move than a stock one. Not sure but its a possibility.
 Old 07-05-2012, 12:14 PM   #82
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
make sure u disconnect both terminals, not just negative... i wrote it wrong in that last post.
860whp/677wtq
2.7 V6 Ecoboost
Realgib3 (07-05-2012), tbot (07-05-2012)
 Old 07-05-2012, 01:11 PM   #83
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I had the same issue and I cleaned my cam position sensor, also changed out my ocv, kept getting the code so Dustin did some research and Pablo told him to have me do some crazy battery reset.
For some reason that code won't reset on a normal battery reset and stay in the cars ECU.
Disconnect negative, get in car, put headlights on, hold brakes for 30 seconds.
No lie when I did the hard reset I never got that check engine light again.
Tapafucku!
You forgot holding your left testicle between the thumb and pinky finger of your right hand while simultaneously gyrating your ass on the instrument panel. That's for the real absolute-never-get-a-code-in-your-life-again-reset. I swear you'll never get a code again.
PapaSmurf likes this.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
atvfreek (07-11-2012), djuosnteisn (07-06-2012), jracer (07-05-2012), PapaSmurf (07-05-2012), Realgib3 (07-05-2012), tbot (07-05-2012)
 Old 07-05-2012, 09:19 PM   #84
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Shiiiiiit I fiiink I know what it is...
I'm pretty sure there was some confusion between Pablo and I about the BSD. After reading a lot of instances of this happening, it's been low pressure from the BSD not being installed, just having the shaft deleted... and thinking back... I never actually checked to see if there was anything installed there when I first got the block back....
@SPEED6 KILLAH hopefully you can chime in on this one just so I can be sure...
Sorry to answer you back late be I'm busy work a lot.. But no I didn't install the BSD and add it a couple of other things to supplement for the Bsd. I pm you with the list when the motor was on it way to you.. If you have any other question feel free to pm or text me..
SPEED6 KILLAH is offline   Reply With Quote
 Old 07-05-2012, 10:30 PM   #85
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
Horry shit batman traction is for pussies lol Damn 6466 ms3 ftw. Do it evo style and make 800hp with this turbo. Just watch because some PTE turbos like to become shrapnel grenades.
2006 Evolution IX RS
ER Built 2.3l
On jackstands
awaiting parts
surebOOst is offline   Reply With Quote
 Old 07-06-2012, 12:13 AM   #86
Realgib3's Avatar
Yeah turbo is sick, spools really well and feels great right now, just on spring pressure. As soon as I get the PI fuel setup complete, I'll be turning up the fun knob
Also GREAT news. Looks like everything has been resolved by installing the BSD and clearing the code. Drove 30 miles tonight and it ran perfect the whole time. Stay tuned for some vdynos probably next week.
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
BigjohnB20 (07-06-2012), jracer (07-06-2012), tbot (07-06-2012)
 Old 07-06-2012, 06:21 AM   #87
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Glad I could help!
tapatawk
Realgib3 (07-06-2012)
 Old 07-10-2012, 04:45 PM   #88
Realgib3's Avatar
Alright guys I need help.
Long story short, I finally started getting on it with boost set at 14psi and I get insane amounts of (EDIT: WOT) KR at ~2.0 load and 5-5500rpm +
Details:
Car runs fantastic until that point. No funny noises, no jerkyness, trims are dead on, afr is dead on, BAT's are <100*. Honestly everything runs so perfect it's not even funny. Even seems like (sure it's just in my head) that the car has higher compression than the old motor because it's soooo responsive off boost and spools this turbo pretty damn fast. Also NO CELS. None
What I've tried to remedy this so far...
new ghes
inj seals (again)
spark plugs
octane booster
moved an ic pipe that was hitting the oil pan
Anyway I'm out of ideas right now, so anything you guys can throw out there would be helpful. Only thing I have left is it's possibly building a bunch of CC pressure, but I'm not blowing oil out anywhere, dipstick's staying in, and my catch can seems to be picking up a normal amount of oil. also, when I took the IM off to do the seals again, there was barely a drop of oil in that.
oh and btw I updated my APmanager and now it won't connect my PC to AP, so I can't lower timing, but even if it's real knock and timing needs to be lowered, that still means there's something wrong because I'm only running 15* at RL with 2gal corn and now octane booster at only 14psi.
looking forward to some ideas so I can actually get this thing going fast because this sucks!
@djuosnteisn
@SilverDemon (I thought I remember you having experience with this?)
@Lex
@Dano
@ ANYONE ELSE WHO CAN HELP! lol
djuosnteisn (07-10-2012)
 Old 07-10-2012, 04:48 PM   #89
Etipp98's Avatar
I know it's dumb, but did you replace the sensor with the motor or using the old one?
 Old 07-10-2012, 05:22 PM   #90
Realgib3's Avatar
The knock sensor? Using the old one, but I may replace it now just to see if that's the problem.
It's just so insane how well the car drives until that point, plus NO cels at all, NOTHING.
buh idk
 Old 07-10-2012, 05:37 PM   #91
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Your having KR at wot? Or at PT? Did you get the Cam pos CEL taken care of?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Realgib3 (07-10-2012)
 Old 07-10-2012, 05:40 PM   #92
Realgib3's Avatar
WOT only, no PT kr at all to speak of and yes, that code was due to low oil pressure because the BSD plug was not orignally installed. As soon as I put that in, no cels at all.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
djuosnteisn (07-11-2012), rfinkle2 (07-18-2012)
 Old 07-10-2012, 05:42 PM   #93
Etipp98's Avatar
Yeah, I was referring to the knock sensor. Either way, you still gonna show up thursday?
 Old 07-10-2012, 05:43 PM   #94
Realgib3's Avatar
Yeah I'll be there, just no WOT above 5500 and it runs perfect. Unfortunately the fun part is >5500 lol.
 Old 07-10-2012, 05:45 PM   #95
Etipp98's Avatar
Yes, I can now agree that is true.
 Old 07-10-2012, 05:49 PM   #96
Realgib3's Avatar
It sucks too because it doesn't knock near as bad, if at all WOT in 1st and 2nd, but 3rd and 4th are terrible
 Old 07-10-2012, 09:40 PM   #97
Bob Ross Fanclub
Tomas's Avatar
Post a log.
Check spark plugs. Condition and gap.
Chimmike (07-11-2012), djuosnteisn (07-11-2012)
 Old 07-10-2012, 10:38 PM   #98
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
the title killed me , "i blew up again" .... totally killed me ....ty
 Old 07-10-2012, 11:07 PM   #99
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Yes Rod, what you were completely incapable of doing, some of us have already done. Some, multiple times.
Past Mazdas & Speeds
Realgib3 (07-11-2012)
 Old 07-10-2012, 11:08 PM   #100
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
u guys are sure crafty
 Old 07-11-2012, 05:37 AM   #101
Realgib3's Avatar
Post a log.
can't post a log because AP won't connect to PC after the last update. Trying to get that fixed now.
The plugs I just pulled out looked fine and gap was right @.26 where I left them. Put new plugs in anyway just to see and still getting the exact same results.
Thanks for the input though guys, I'm sure if enough people throw random shit out there, we'll get it figured out.
 Old 07-11-2012, 06:42 AM   #102
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Just throwing ideas out there, i am by no means as good at this as several other people. But could it be false kr. do you maybe have something in the engine compartment moving around enough to cause this.
I wouldnt think it is because it seems to be pretty consistant but just trying to help the brain storming process
Damond Built Speed 6
The Following 3 Users Say Thank You to Deldran For This Useful Post:
djuosnteisn (07-11-2012), jracer (07-11-2012), Realgib3 (07-11-2012)
 Old 07-11-2012, 07:42 AM   #103
Realgib3's Avatar
Definitely thought about noise but I think I fixed the couole rattles there were, and the fact it's worse with more load, ie 3rd gear and up makes me pretty sure it's real. Suuucks so bad my AP wont work right now.!
 Old 07-11-2012, 08:44 AM   #104
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
My first thought was false KR as well. You are running E85 blend right? I thouhgt I read a couple gallons. That load/timing/rpm combo doesn't seem overly aggressive. You say you even dumped in some octane booster on top of the ethanol and still seeing KR? If it keeps showing up at the same RPM point you might be hitting some weird frequency/resonance that is triggering the sensor. You do have BSD, I am sure several stiff motor mounts, just had the entire front end apart. Even on a stock engine the KR sensor turns off around 5500.
Too bad you don't have the AP or you could go drop a few degrees and see what happens. Can you add more Ethanol for a test. With for example, 2 more gals you are still knocking, I would be pretty confident it is not real. Only thing against the false KR theory I see is that you say it is only in the higher gears....
Anyway, I am sure you are aware, but once you decide if real or not you can then go adjust the KR offset table some at higher RPMs to make it less sensitive.
Good luck with everything. Hope you get it figured out. I have been watching this one for a while.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following User Says Thank You to BigjohnB20 For This Useful Post:
 Old 07-11-2012, 09:36 AM   #105
Captain
I've only seen one bad knock sensor before... and it did show unusually high KR, even when there was plenty of octane. The best tests to determine if the KR is real is to simply add more octane. Even if it's a tank of race gas (as pricey as it is), if your still getting KR at that point, start looking into mechanical causes... rattling pipes, loose / faulty knock sensor, etc etc.
www.permtuning.com
phate (07-11-2012), Realgib3 (07-11-2012), rfinkle2 (07-18-2012)
 Old 07-11-2012, 11:14 AM   #106
Realgib3's Avatar
Yeah Im leaning toward somethin not octane related since Ive added another gallon of e (3 total) and 2 bottles of octane booster and still see the same counts of 10*+ kr. Plus the plugs have lookedto fibe the eholeangle time. Will check more stuff tonight when I get off work.
 Old 07-11-2012, 11:24 AM   #107
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Octane booster does dubious things, at best. Maybe .1-.2 point of octane. I don't like the additives many of them use.
Close plug gap to .025? IC pipe hitting VC?
mm vibrations maybe?
07 MS3
The original Genpoo Hater
 Old 07-11-2012, 11:37 AM   #108
Etipp98's Avatar
There is a sunoco station in willowick that sells the 260GT 100 octane..
 Old 07-11-2012, 11:48 AM   #109
Realgib3's Avatar
Been there, may fill up with that when this tank is gone but I think I'll look into mech issues till then. I'm just going to make a checklist of all these posibilities and go down that one by one.
 Old 07-11-2012, 11:59 AM   #110
Did you reused the old timing chain??
 Old 07-11-2012, 12:05 PM   #111
Realgib3's Avatar
Yes. I will check that again today but as of Mondat it was as tight as ever. Definitely so.ething to check again though.
 Old 07-11-2012, 12:21 PM   #112
Hmmmm it could be tight when install it but onces you go Wot and plus the heat it stretches.
Easy way to found out if the chain is stretch is look at the bottom of your valve cover and you will see marks like in this picture
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
86AmishMs3 (08-06-2012), twowheelrides (07-02-2013)
 Old 07-11-2012, 12:28 PM   #113
Realgib3's Avatar
Thanks Pablo! I'll look tonight!
 Old 07-11-2012, 01:37 PM   #114
2008_zoomzoom's Avatar
Posts: 83   (View Stats)
2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute2008_zoomzoom has a reputation beyond repute
@Realgib3 i had the same issue with atr and ap manager. try uninstalling the ap manager and reinstalling it. i spoke with Cobb and it was something to do with the driver software not installing properly. it worked for me. i had this issue after d/l atr to my desktop after having it on my laptop. also , if you can, manually install the driver software. it helped. took the guessing game out. good luck with your car. cant wait for numbers!
2008_zoomzoom is offline   Reply With Quote
The Following 2 Users Say Thank You to 2008_zoomzoom For This Useful Post:
 Old 07-11-2012, 08:31 PM   #115
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
10° of KR at full throttle at that RPM, and it living, tells me it's likely noise. You would at least see spackling on the plugs, if not break the porcelain.
Timing chain is a good one. Pulley bearings are another thing to check. Any time I get to see a car in person that has this kind of issue, I just start shaking shit in the engine bay. Not like poke-poke, it doesn't move; grab shit and try to force it back and forth. Intercooler piping banging on the intake mani, exhaust or exhaust hangers rattling. SSOOOOO much stuff can make noise.
-06 MS6
-Corn fed 07 MS3 - Sold
BigjohnB20 (07-12-2012), Realgib3 (07-11-2012)
 Old 07-11-2012, 09:10 PM   #116
Realgib3's Avatar
Update...
FIIIXXXEEEDD!!!
Alright so I stopped being an idiot and REALLY went through the damn engine bay and as @phate said I shook the shit out of everything I could find.
and not shit moved lol
But then I noticed a ground wire that looked loose sitting right near the hard coolant line that runs over top of the trans... also looked to see that some of my ECU wires were un-taped right next to the power wire to the starter... Tightened up that ground and re-taped alllll the ECU wires and power wires and voila, car fucking rips.
If 16psi feels this good, I can't wait to feel mid 20's!
Thanks everyone for all the brainstorming. I'll post logs as soon as I can get this damn AP fixed.
The Following 11 Users Say Thank You to Realgib3 For This Useful Post:
amoosenamedhank (07-11-2012), BigjohnB20 (07-12-2012), Dano (07-18-2012), Easter Bunny (09-09-2012), jracer (07-12-2012), phate (07-11-2012), rfinkle2 (07-18-2012), silvapain (07-12-2012), SilverDemon (07-11-2012), Tokay444 (07-11-2012), uncorked11 (08-26-2012)
 Old 07-11-2012, 09:17 PM   #117
SilverDemon's Avatar
Posts: 3,034   (View Stats)
My issue was related to a faulty 2nd O2 sensor. The ecu will dump fuel like mad to try and put heat in the sensor. Mine was a rich knock, and I never saw +10° of knock with this issue. Could the missing bsd plug caused some issues with oiling?
edit: haha never mind good catch
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
 Old 07-12-2012, 07:25 AM   #118
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Awesome !
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 07-18-2012, 09:48 AM   #119
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
shit just saw the mention..glad you got it fixed.
 Old 07-18-2012, 10:07 AM   #120
Realgib3's Avatar
Yep fixed...the broke again lol. Got my AP fixed and got 5 solid days of running great, then crzy knock came back. Idk what it is now just annoyed but I'm gonna tear into it tonight again to try and figure it out.
jracer (07-18-2012)
so i blew my sub jack_hammer MazdaSpeed 3/6 - Car Audio & Electronics 2 11-25-2009 10:44 PM
Once upon a time...I blew up!!! Realgib3 MazdaSpeed 3 - Engine, Transmission & Driveline 41 10-16-2009 07:16 PM
BLEW UP WITH FFS!!! Realgib3
Cobb ATR Support
30 08-20-2009 01:54 PM
Page generated in 0.59681 seconds with 37 queries
