  • 1 Post By fivefingerdeathpunch
 Old 02-25-2015, 12:36 AM   #1
shortie0420's Avatar
Posts: 43   (View Stats)
shortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud ofshortie0420 has much to be proud of
Default Blowing my Tax return
OK boys its tax season My genone is in need of some Love so i blew my head gasket last week so getting it replaced, i'm sending the head out tomorrow to check it ad resurface , but since i'm there might as well get 3-5 angle ? not sure yet when i talk to shop. My little snail has 138K on OEM turbo with the original valve cover setup from 2007 clutch is Factory OEM also and still strong, original HPFP.
since i'm there and have every thing apart I might as well Buy this
Bnr stage 3 & TIP That fits
Atp downpipe
treadstone tr8
Cx racing FMIC
Autotec HPFP
New Mounts all the way around
grimmspeed boost controller
Stratified Automotive Guardian Angel V2 Overboost Protection and BPV Controller
Kozmic Motorsports Oil Return Line Kit for Mazdaspeed 3
Kozmic Motorsports Oil Feed Line Kit for Mazdaspeed 3 / 6 / CX-7
RPM Treadstone TR8 Brackets for Gen1 Mazdaspeed 3
COBB Tuning Shifter Weight for Mazdaspeed 3/6
Damond Motorsports Short Shift Plate for Mazdaspeed 3 /
Performance Street Disc with Streetlite Flywheel / ZX5-HDSS
CPE Nexus™ 3-inch Cat-Back Exhaust
Snow Performance Water/Methanol Injection Kit stage 2
Subtotal $3,710.40
Discount: 10% off MSRP on CP-E through 2/28 -$36.02 - -
Total $3,674.38
Car is Dyno tuned by ME already for e85 now 302HP 330TQ
Target 500WHP
what else ?
shortie0420 is offline   Reply With Quote
 Old 02-25-2015, 12:40 AM   #2
HYDRO's Avatar
Posts: 156   (View Stats)
HYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant futureHYDRO has a brilliant future
Seems like a lot at once, but why not...
STUFF: COBB AP V3 // AT HPFP // MYSTERY TP // RES DELETE // MAGNAFLOW CBE // JBR TIP // JBR SRI // CPE TMIC // RICE // CPE STAGE 2 RMM // TURBO SMART DUAL PORT// STRATFIELD GA // STRATFIELD OTS STG2 93
HYDRO is offline   Reply With Quote
 Old 02-25-2015, 12:52 AM   #3
i rather buy everything and get it all done at once, i haven't done anything to my car in almost a year and a half its been a good car. 138 on the clock and it has not left me stranded until last week, and i don't baby the car either
 Old 02-25-2015, 12:55 AM   #4
HYDRO's Avatar
Well it seems like you are ordering from RPM don't forget the Tax Return coupon.
 Old 02-25-2015, 12:59 AM   #5
Yeah Rpm i saw that coupon, not counting it till the very end, gas and at least extra pair of tires money lol
 Old 02-25-2015, 10:03 AM   #6
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
Target 500whp? You need a bigger turbo than a BNR S3 unless you are running NOS
taf0422 likes this.
The Following 2 Users Say Thank You to fivefingerdeathpunch For This Useful Post:
CWP_MS3 (02-25-2015), InkedInspector (03-06-2015)
 Old 02-25-2015, 10:15 AM   #7
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Also 500 whp on stock block?
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 02-25-2015, 07:08 PM   #8
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
#inb4ringlandfailz
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following User Says Thank You to levon.mark For This Useful Post:
taf0422 (03-06-2015)
 Old 02-25-2015, 10:39 AM   #9
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
If your ordering from RPM and shooting for 500hp you will need to start looking at GT(x)3076 or gt35.
 Old 02-25-2015, 10:45 AM   #10
ms3steeez's Avatar
Posts: 312   (View Stats)
ms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the world
Stock block won't last...ask me how I know.
Mine went at 391/380 and didn't have close to the miles yours has
FreekTuned GT3076R, M2 catless DP, CS HPFP internals, Custom 3.5" intake, Custom 51R battery box, Grimmspeed 3 port EBCS, CS shifter bushings, RA mudflaps, TurboXS core w/ custom piping, Devils Own 100% meth injection, JBR 88 RMM, Denso ITV22, CPE Safeseals, JBR EGR delete, Forge V1, Hawk HPS pads, VCTS Delete, 3 bar map sensor, kozmic primary EGR delete (391 whp on Vdyno, ZZB 12-17-14)
Build in progress
.020 over block, pinned and keyed, wiseco pistons, manley H beams, SP63 head w/ intake and exhaust ports, and mild bowl work. DM TB spacer, L19 studs, XSpower V1 mani, CNT catback, ACT 6 puck w/ streetlight flywheel, CS injector seals, Clevite main and King rod bearings, redefined performance PCV plate, PTP oil pan baffle w/ JBR BSD, 4 bar map sensor
ms3steeez is offline   Reply With Quote
 Old 03-06-2015, 08:30 AM   #11
Got head back , 20 thousands of inch shaved off , 5 angle head job, custom Cometic head gasket : Thickness: .075-inch.
 Old 03-06-2015, 08:35 AM   #12
jdmage_mx5's Avatar
Going by the history of Cometic around here I would not run their head gasket. The OEM one has proven to be more then enough for most builds around here.
The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post:
ASHMS3 (03-06-2015), faeker (03-06-2015), taf0422 (03-06-2015)
 Old 03-06-2015, 08:39 AM   #13
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
ain't hitting 500 on the bnr.
Mods: stock
ASHMS3 (03-06-2015), ms3steeez (03-06-2015)
 Old 03-06-2015, 09:33 AM   #14
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
You are going to want to rethink turbo choice and engine internals if you want to get to 500. You are looking at maybe low 400's with your current choices. But with 130k on your stock block probably 360ish.
 Old 03-06-2015, 02:46 PM   #15
faeker's Avatar
Groans: 731
Mid 300s is typical with bnrs3 setups
Mods: stock
 Old 03-06-2015, 03:16 PM   #16
ms3steeez's Avatar
We'll see how long it lasts...
Build in progress
 Old 03-06-2015, 03:56 PM   #17
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Tl; dr op determined to put stock block out of misery
it's fun to do bad things
ASHMS3 (03-06-2015), ms3steeez (03-06-2015), taf0422 (03-06-2015)
 Old 03-07-2015, 08:34 AM   #18
as far as the block it will have to stay as is for now,i know im not going to reach 500, i did make 320hp/380tq on stock snail with e85, i will get the car tuned for everyday street, baby it for now, i just need to get off this bike, S FL crazy drivers
the only reason comatic is because of how much had to be shaved off, 20 thousands,
Last edited by shortie0420; 03-07-2015 at 08:34 AM. Reason: MSF Database - Automerged Doublepost
blowing money jreiden1 MazdaSpeed 3/6 - Build Diaries 72 11-16-2013 06:53 AM
i keep blowing pistons, and there's oil in everything. any help? spoolinhard MazdaSpeed 3 - Engine, Transmission & Driveline 16 02-08-2012 01:08 PM
Stock ECU keeps from blowing up? MexSpeed MazdaSpeed 3 - Engine, Transmission & Driveline 4 11-14-2009 12:26 PM
ms3's blowing up like hotcakes. samsel450r
Cobb Access Port/Maps
134 01-19-2009 10:07 PM
Dip Stick Blowing Out...? AutoXRacer MazdaSpeed 3 - Engine, Transmission & Driveline 58 01-18-2009 09:52 AM
Page generated in 0.41491 seconds with 30 queries
