 Old 08-20-2012, 11:24 AM   #1
HawkNasty's Avatar
Posts: 4   (View Stats)
HawkNasty can only hope to improve
Groaned at 5 Times in 2 Posts
Default Blown Turbo
Okay, so about a week ago my turbo started smoking. And by smoking I mean a lot. Only happens at Idle after driving the car for about 10 minutes, doesn't do it at a cold start idle. My guess is the seal is gone in the turbo.
I'm going to just cut my losses and get a 3071R. My mods are Corksport TBE, TMIC, SRI/TIP, HPFP internals, Forge V1 BPV, CP-E RMM and Cobb AP. With these mods would I be able to just bolt on the turbo or what else would I need? Also is there any clues to why the stock Turbo failed? It was replaced by Mazda because of the smoking issue that most MS6's had.
Please excuse me if I haven't searched enough, but I'm trying to figure out specifically with my mods what else I'll need. Thanks for any help
HawkNasty is offline   Reply With Quote
The Following 3 Users Say NO Thank You to HawkNasty For This Un-useful Post:
captain slow (08-20-2012), cbspd3flip (08-20-2012), jack_hammer (08-20-2012)
 Old 08-20-2012, 11:37 AM   #2
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
what is the point of your post? you already have made your decision. you're going to cut your losses and get a 3071r.
i know you're not asking how to do a BT swap, right? if so, then fuck you.
it's fun to do bad things
 Old 08-20-2012, 11:40 AM   #3
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
You haven't searched at all man. This info is everywhere.
 Old 08-20-2012, 11:51 AM   #4
HawkNasty's Avatar
The point of my post was to ask if with my current set up should I replace any current mods and is there anything else I will need to upgrade to bolt on the turbo. Not all of us are as well versed in cars as you may be and even after searching posts still required some help and clarification.
The Following 2 Users Say NO Thank You to HawkNasty For This Un-useful Post:
captain slow (08-20-2012), jack_hammer (08-20-2012)
 Old 08-20-2012, 01:36 PM   #5
Groans: 549
no, you aren't asking that. because if you were asking that, you would really be asking for an ass raping for asking questions that are sooooo extensively covered. the info for BT swap is well documented. you're gonna have to read for yourself.
 Old 08-20-2012, 01:38 PM   #6
JP_Playboy's Avatar
Posts: 228   (View Stats)
JP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the worldJP_Playboy is the leader of the world
This thread makes me want to kill kittens...
09 Mazdaspeed 3 - Mazdaspeed CAI V2, COBB TIP, COBB DP, COBB CBE, Corksport TMIC, CP-E HPFP, COBB RMM, COBB AP, Stoptech slotted rotors, HAWK break pads, tuned by LEX (Stratafied).
Semper Fi
JP_Playboy is offline   Reply With Quote
 Old 08-20-2012, 01:59 PM   #7
gearhead750's Avatar
Posts: 383   (View Stats)
gearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the world
Groans: 30
Thanks 4G63 for the avatar!!!
Originally Posted by DarkHeartMS6 View Post
I didnt think there was a person on this planet as stupid as you... Congratulations, you proved me wrong. WTF is a Mazda RX-7 if not one of the best "tuner" cars as you put it.. out there. Jump off the honda dick, pull the Golf R cock out of your mouth... replace it with a gun and end this world of your stupidity! Please, before you cause a retard apocolyptic end to our world
gearhead750 is offline   Reply With Quote
 Old 08-20-2012, 02:00 PM   #8
Groans: 398
You fail at searching if you couldn't find this info. Here you go asshole
http://www.mazdaspeedforum.org/forum/foru...al-way-111319/
One of many threads.
 Old 08-20-2012, 02:42 PM   #9
Let me know if you need that turbo I will get you all set up
Bob-o (08-20-2012)
 Old 08-20-2012, 11:24 PM   #10
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
It's going to be much much much cheaper to put another k04 on. You're gonna need a dp, new inlet, maybe exhaust mani, and a way to control the boost. Look at lenny's how to thread in the sticky
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 08-20-2012, 11:30 PM   #11
greenespeed's Avatar
Posts: 1,320   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
@HawkNasty, why not just bolt on a bnrs3 and call it a day.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
 Old 08-21-2012, 06:39 AM   #12
Groans: 549
because he doesn't know what that is
greenespeed (08-21-2012)
 Old 08-21-2012, 09:38 AM   #13
You are probably right. Although it is a big secret here on MSF, I had to search for 5 hours just to find out myself. LOL
 Old 08-21-2012, 10:10 AM   #14
JP_Playboy's Avatar
At least you searched before making another stupid ass thread like OP
Semper Fi
 Old 08-21-2012, 04:40 PM   #15
My post was a joke. I know what BNRs3 is after like 3 seconds.
 Old 08-21-2012, 04:51 PM   #16
Colin1337's Avatar
Posts: 1,330   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
If your not "well versed" in cars, I wouldnt go BT if I was you. At MOST I'd say BNR s3, but even then I'd be worried.
2005 CTS-V
KCCO
2006 Mazdaspeed6 SOLD
COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion
1995 Miata SOLD
Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is offline   Reply With Quote
Another Blown Turbo... dcamp2 Gen2 MS3 General Discussion 75 06-29-2012 11:35 AM
Blown Turbo????? sacredmonkey Mazdaspeed3/6 General Discussion 10 02-15-2012 01:56 PM
Blown Turbo JD80 Gen2 MS3 General Discussion 23 07-27-2011 09:23 PM
blown turbo h0rsies MazdaSpeed 3/6 - Turbo Induction 1 07-07-2010 06:42 AM
Page generated in 0.34551 seconds with 28 queries
