![]() Join Date: Mar 2010
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score Already installed: Corksport DP and resonator HPFP CPE intake and COBB TIP (being replaced by PRE) COBB AP SU rear engine mount and rear diff mount On hand: BNR S3 All new studs Manual Boost Controller EGR block off and delete SU TMIC 3Bar sensor and harness adapter HTP 3" intake and battery tray for 51R On it's way: 3' 6AN hose and ends, and also a 1' 6AN hose and ends (read both, not sure why, but better safe than sorry) New exhaust gaskets for both ends of the turbo and new studs Anything else I'll actually NEED before the install? I might buy a new set of gaskets before I start (I hope to not remove the exhaust mani, so I'll not order that up... is that ok?) It sounds like I might need some oil and coolant lines? I can't find any good hard info on this... After it's all up and running I'm going to start Stratified tuning. Anything else????
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV Last edited by timjustindodd; 08-14-2013 at 11:41 PM. |
| Not Ranked : 0 score This was my list for a BNR and DP install, but you can figure out what you need just for the turbo, good luck.
| The Following User Says Thank You to Code Monkey For This Useful Post: | timjustindodd (08-09-2013) |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score good stuff... im getting ready to install my bnr too
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score Why MBC? You'll need a 3-Bar if you plan to exceed 21.5 psi and a bigger MAF housing. Blog : The modification path in a MazdaSpeed/MPS vehicle : Stratified Automotive Controls
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score Extending the heater hose that runs under TIP is one thing i wish I did when I installed mine... Still planning on doing it when I switch over to a 3"+ intake... Larger intakes put a LOT of strain/rubbing w/ the beaner since it sits slightly different than the k04 Edit: also put some heavy duty clamps on that hose
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| The Following User Says Thank You to himurax13 For This Useful Post: | timjustindodd (08-09-2013) |
| Not Ranked : 0 score You will want to stay away from the MBC. Either get a 3 port or Boost Dial (Boost Dial works with the OEM 2 port BCS). You will want a larger intake - 3" is recommended to avoid cuts. If you have poor fuel in your area and depending on your power goals consider either E85 or WMI. The other bits and pieces that help bolt the turbo on are well covered in several posts mentioned above ^^. Also don't overlook the tune as it is critical in tying it all together.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. | |
I forgot to mention (and edited my original list), that I did get a 3" from PRE with a new battery tray I have 93 grade around here... might do a full tune for 93 and 91 with stratified. My power goals are only about 330 ish with 93 and 300 ish with 91.
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV Last edited by timjustindodd; 08-09-2013 at 12:01 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to timjustindodd For This Useful Post: | Mike@Stratified (08-09-2013) |
| Not Ranked : 0 score So you go the Stratified Boost Dial? If so you are golden.
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| GL with the install, In4numbers
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
![]() Join Date: Mar 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
| Not Ranked : 0 score i thought the divorced corksport DP caused issues with the wastegate on turbos that werent the stock k04? edit: just remembered the bnr uses stock hotside so maybe it doesnt cause issues. mah bad if so. just trying to help
__________________ 2006 White Water Pearl Mazdaspeed6 Grand Touring #5430 HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan Old: BNR S3 370/380 VD 91 + Meth BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforum.org/forum/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/ |
| The Following User Says Thank You to fivefingerdeathpunch For This Useful Post: | timjustindodd (08-09-2013) |
| Not Ranked : 0 score It shouldn't cause an issue since the stock hotside is used. It could possibly be slighty better than a bell-mouth style DP, actually, due to the divorced design. It may become an issue on larger frame turbos, but I'm not sure if anyone has run that DP with something like a GT30 or larger.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| Not Ranked : 0 score That's what I get from replying to things from the airport!
| The List: The List goes racing on Speed tonight at 10PM EST/PST... honest! | Haltech | Automotive News | 0 | 02-26-2013 02:30 PM |
| The List: The List #0248: Attend the Woodward Dream Cruise | Haltech | Automotive News | 0 | 09-18-2012 11:40 AM |
| The List: The List #0180: Work As A Professional Stunt Driver | Haltech | Automotive News | 0 | 08-14-2012 01:30 PM |
| The List: The List #0001: Graduate From A High Performance Driving School | Haltech | Automotive News | 0 | 12-13-2011 10:50 AM |
| Big Turbo Check list | azokaei | MazdaSpeed 3/6 - Big Turbo Builds | 17 | 07-20-2011 03:15 PM |
