 Old 08-09-2013, 11:02 AM   #1
timjustindodd's Avatar
Posts: 45   (View Stats)
timjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the world
Default BNR check list
I've read all the stickies and done dozens of searches. I just want to double check my work before I actually start the swap, so I don't have a week of downtime waiting for some stupid part to come in...
Already installed:
Corksport DP and resonator
HPFP
CPE intake and COBB TIP (being replaced by PRE)
COBB AP
SU rear engine mount and rear diff mount
On hand:
BNR S3
All new studs
Manual Boost Controller
EGR block off and delete
SU TMIC
3Bar sensor and harness adapter
HTP 3" intake and battery tray for 51R
On it's way:
3' 6AN hose and ends, and also a 1' 6AN hose and ends (read both, not sure why, but better safe than sorry)
New exhaust gaskets for both ends of the turbo and new studs
Anything else I'll actually NEED before the install?
I might buy a new set of gaskets before I start (I hope to not remove the exhaust mani, so I'll not order that up... is that ok?)
It sounds like I might need some oil and coolant lines? I can't find any good hard info on this...
After it's all up and running I'm going to start Stratified tuning.
Anything else????
2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV
timjustindodd is offline   Reply With Quote
The Following 2 Users Say Thank You to timjustindodd For This Useful Post:
Benis (08-09-2013), Lex (08-10-2013)
 Old 08-09-2013, 11:05 AM   #2
This was my list for a BNR and DP install, but you can figure out what you need just for the turbo, good luck.
timjustindodd (08-09-2013)
 Old 08-09-2013, 11:14 AM   #3
m4tic's Avatar
Posts: 4,928   (View Stats)
good stuff... im getting ready to install my bnr too
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-09-2013, 11:17 AM   #4
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Why MBC? You'll need a 3-Bar if you plan to exceed 21.5 psi and a bigger MAF housing.
Blog : The modification path in a MazdaSpeed/MPS vehicle : Stratified Automotive Controls
 Old 08-09-2013, 11:18 AM   #5
DSIT995's Avatar
Posts: 1,768   (View Stats)
Extending the heater hose that runs under TIP is one thing i wish I did when I installed mine... Still planning on doing it when I switch over to a 3"+ intake... Larger intakes put a LOT of strain/rubbing w/ the beaner since it sits slightly different than the k04
Edit: also put some heavy duty clamps on that hose
99 Miata NB - Stock for now
 Old 08-09-2013, 11:25 AM   #6
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I believe some ahole made a thread about this a while ago ...
BNR Stage 3 Checklist.
Pickles Tune in progress
 Old 08-09-2013, 11:33 AM   #7
You will want to stay away from the MBC. Either get a 3 port or Boost Dial (Boost Dial works with the OEM 2 port BCS).
You will want a larger intake - 3" is recommended to avoid cuts.
If you have poor fuel in your area and depending on your power goals consider either E85 or WMI.
The other bits and pieces that help bolt the turbo on are well covered in several posts mentioned above ^^.
Also don't overlook the tune as it is critical in tying it all together.
ItsNox (08-10-2013), MattJackson86 (08-09-2013), SamiChicago (08-03-2014)
 Old 08-09-2013, 11:37 AM   #8
Oh, I think he has the right idea
The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post:
ItsNox (08-10-2013), Lex (08-10-2013)
 Old 08-09-2013, 12:01 PM   #9
I got my MBC from Stratified, I believe it's the correct MBC to keep the stock 2 port. I think you're the one that recommended using a MBC with the OEM BC, saying it's very effective.
I forgot to mention (and edited my original list), that I did get a 3" from PRE with a new battery tray
I have 93 grade around here... might do a full tune for 93 and 91 with stratified.
My power goals are only about 330 ish with 93 and 300 ish with 91.
damn, that's great... now where was that in the search?!? Hahaha I swear, sometimes the search puts me in a black hole and I end up reading about some dudes wife having a stroke or something....???? haha
Last edited by timjustindodd; 08-09-2013 at 12:01 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to timjustindodd For This Useful Post:
Mike@Stratified (08-09-2013)
 Old 08-09-2013, 12:05 PM   #10
So you go the Stratified Boost Dial? If so you are golden.
 Old 08-09-2013, 12:11 PM   #11
LumberJack's Avatar
GL with the install, In4numbers
10.36@148 Fastest Gen 2
 Old 08-09-2013, 01:51 PM   #12
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
i thought the divorced corksport DP caused issues with the wastegate on turbos that werent the stock k04?
edit: just remembered the bnr uses stock hotside so maybe it doesnt cause issues. mah bad if so. just trying to help
The Following User Says Thank You to fivefingerdeathpunch For This Useful Post:
 Old 08-09-2013, 01:59 PM   #13
sidekick's Avatar
Posts: 3,093   (View Stats)
It shouldn't cause an issue since the stock hotside is used. It could possibly be slighty better than a bell-mouth style DP, actually, due to the divorced design. It may become an issue on larger frame turbos, but I'm not sure if anyone has run that DP with something like a GT30 or larger.
 Old 08-10-2013, 12:14 AM   #14
That's what I get from replying to things from the airport!
The List: The List goes racing on Speed tonight at 10PM EST/PST... honest! Haltech Automotive News 0 02-26-2013 02:30 PM
The List: The List #0248: Attend the Woodward Dream Cruise Haltech Automotive News 0 09-18-2012 11:40 AM
The List: The List #0180: Work As A Professional Stunt Driver Haltech Automotive News 0 08-14-2012 01:30 PM
The List: The List #0001: Graduate From A High Performance Driving School Haltech Automotive News 0 12-13-2011 10:50 AM
Big Turbo Check list azokaei MazdaSpeed 3/6 - Big Turbo Builds 17 07-20-2011 03:15 PM
Page generated in 0.34963 seconds with 29 queries
