 Old 10-16-2013, 09:40 AM   #1
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Default BNR / GTX30 hybrid
So I picked up a bust up GTX 3071R that had a bearing failure, for under $100.
Billet compressor wheel, AR.60 housing and backplate are still good, but the centre shaft, bearings are damaged. So I can’t use the turbine wheel coz of the fucked shaft. Didnt come with a turbine housing.
So that got me thinking... would it be possible to fit the GTX coldside to my BNR Stage2 CHRA and hotside? Guessing the backplate might need a bit of machine work to mate up to the CHRA.
The BNR2 and 3 use the same CHRA and turbine wheel.
The compressor housing is the anti surge housing with 4” inlet.
Just wondering if the cold side will be too big for the hotside?
Should be a fun turbo if it can work.
Thanks.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 10-16-2013, 10:22 AM   #2
You might get into surge territory due to the cold side being so large.
 Old 10-16-2013, 10:44 AM   #3
Rich990's Avatar
That is my worry, however i'm hoping the anti surge compressor cover mitigates that risk.
MSF in South Africa
 Old 10-18-2013, 12:16 PM   #4
ricardo_yen's Avatar
Posts: 27   (View Stats)
ricardo_yen will become famous soon enough
Hey rich, what would a rebuild on the GTX CHRA cost..... I would venture cold side GTX, turbine side bnr...
Sorry, just for clarity..... GTX CHRA and compressor housing mated to a bnr exhaust housing
Last edited by ricardo_yen; 10-18-2013 at 12:16 PM. Reason: MSF Database - Automerged Doublepost
ricardo_yen is offline   Reply With Quote
 Old 11-15-2013, 09:45 PM   #5
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
Neutral  :  -1 score
I'll take the blown GTX3071 off your hands.
Fuck MSF
avesfan101 is offline   Reply With Quote
 Old 03-16-2014, 06:31 AM   #6
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
I actually talked to Brian about putting a bigger billet wheel on the s3. His response was that I wouldn't see any gains because the s3 turbine would be the main restriction =/.
 Old 03-16-2014, 06:27 AM   #7
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Originally Posted by panaspeed3 View Post
good job
Are you just going around to every thread you can find to put 3 words in? Especially 6 month plus old threads?
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
LatinKraze (03-16-2014)
Ford C-Max Hybrid is Blue Oval's best-selling hybrid in first month of sales [w/video] Haltech Automotive News 0 10-04-2012 12:20 PM
BT MS6 - Go GTX30 OR GTX35 WWPearlMS6 MazdaSpeed 3/6 - Big Turbo Builds 69 06-18-2012 12:58 PM
Video: Infiniti teases M hybrid drag race against Porsche Panamera S Hybrid Haltech Automotive News 0 01-22-2012 04:10 PM
Report: Kia Optima Hybrid delayed due to Hyundai Sonata Hybrid push-back Haltech Automotive News 0 03-31-2011 10:10 AM
REPORT: Two-mode hybrid joint development disbanded; Ram hybrid coming in 2010 Haltech Automotive News 0 10-28-2009 03:40 PM
Page generated in 0.27927 seconds with 25 queries
