Like Tree53Likes
 Old 04-14-2016, 10:22 PM   #1
ryguy 3's Avatar
Posts: 353   (View Stats)
Originally Posted by tmillner View Post
Does anyone know the gains from a 3 inch intake over cs "stg2"?
My thought was I'd rather re-buy an intake then a turbo if I want bigger
Sent from my SM-N920P using Tapatalk
I gained about 20 g/s when I went from the corksport stage 2 to the jbr Tru 3".
 Old 03-27-2016, 10:56 AM   #2
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
I upgraded from the corksport to a JBR 3 inch intake on the stock k04 and didn't notice any significant changes. I also had it retuned for the intake size. My friend has the exact same car with exact same mods and we would consistently be even during 3rd to 4th gear pulls. The intake may have offered a slight bump at higher rpm, but in my opinion it was not worth it on a stock turbo. It did motivate me to get the BNR S3 though and that combination works very well.
voodoo2crue likes this.
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 03-27-2016, 12:04 PM   #3
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
I don't see a draw back
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 03-28-2016, 12:59 PM   #4
Rambo's Avatar
Posts: 16   (View Stats)
Rambo is an unknown quantity at this point
Been lurking for awhile, I have no plan on building the block so I think the s3 will fit my needs. Don't need anymore than 350 whp as I find hooking even with PSS is difficult and no plan on meth either. Also in Canada e85 is almost impossible to find.
Rambo is offline   Reply With Quote
 Old 03-28-2016, 01:04 PM   #5
Nitro's Avatar
Rambo I run an S3 that is tuned to 350. It pulls great and you won't be dissapointed. 3rd gear traction on PSS is a challenge
Rambo likes this.
Stratified Tune
 Old 03-28-2016, 01:06 PM   #6
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Hey @Rambo;, here's the thing though. The S4 will make more power on pump gas than the S3. So, even if you didn't desire to push the S4 up to it's limits it's still worth it.
If I were running an S3 or S4 on just pump gas, I would still choose to run the S4. You still hit the knock limit with the S3 on pump gas pretty quick over the k04. The S4 offers more airflow at lower boost levels than S3. Who's the one that got really impressive #s on an S4 with just pump gas? I can't remember who, but I was really impressed with the #s .
memin and Rambo like this.
MINI H1 6.0 - CAR LED TAILS
BuddySpeed3 (04-01-2016), Whitebullet (12-26-2018)
 Old 03-28-2016, 01:09 PM   #7
tmillner's Avatar
Dale are you on an s4 now?
 Old 03-28-2016, 01:27 PM   #8
Neg. Still S3. On pump gas alone, I think I only picked up about 30whp with the S3 though over the k04. Now, when I went Meth injection, the gains were much better. But I digress. Here's a quick overview of why the S4 will make more power than the S3 on pump gas:
In very basic terms, a "bigger" turbo will move more airflow with less heat generated during the compression stage. This is due to the compressor wheel being sized to move the appropriate amount of air within the "happy" compressor RPM range.
And, more importantly, once this air is combusted and turned into exhaust, a turbo with a "bigger" turbine wheel will spin at an appropriate RPM and will induce less power-robbing exhaust backpressure. The less backpressure on the exhaust side, the more air that can be pumped through the engine at any given boost pressure.
Mrzoomzoom and Atticaz like this.
allo80 (04-23-2016), Atticaz (12-04-2016), BuddySpeed3 (04-01-2016), manselainen (04-01-2016), Whitebullet (12-26-2018)
 Old 03-28-2016, 01:09 PM   #9
Rambo's Avatar
Really? Well that's peaked my interest... Lol I was just searching the for sale section for a s3. Living in Canada has its advantages but our dollar is horrendous right now. Thanks @dale_dribble
Sent from my LG-D852 using Tapatalk
 Old 03-28-2016, 01:25 PM   #10
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Haha, i came in here as well leaning toward an s3 BUT this thread changed my mind.
Rambo likes this.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 03-28-2016, 01:38 PM   #11
tmillner's Avatar
I'm on the s4 more, haven't finished tuning though, and I've only picked up like 40whp on pump alone. Not what i expected.
What's different is it holds boost so much better, 22+ straight through. I'm going to have to go e30
The Following 2 Users Say Thank You to tmillner For This Useful Post:
 Old 03-28-2016, 03:36 PM   #12
Rambo's Avatar
@tmillner; when do you start hitting boost?
 Old 03-28-2016, 03:42 PM   #13
tmillner's Avatar
Let me find a log, hold on
allo80 likes this.
 Old 03-28-2016, 03:47 PM   #14
tmillner's Avatar
I'm at 18 psi at 3500, usually carries 22 through 6k. Alot different then k04
Rambo likes this.
 Old 03-28-2016, 03:55 PM   #15
Based on the dynos and logs I've seen, on shipped WG preload, the S4 is spooled by ~3500-3600. Spools like a mid turbo, flows like a bigger one.
Mrzoomzoom likes this.
 Old 04-01-2016, 08:52 PM   #16
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
So to get more boost with less wgdc, would it be necessary to adjust the wastegate actuator to a higher threshold?
Would it be possible to over boost at lower rpm's if the wastegate actuator is adjusted too high on the s3 or s4? I know the K04 does this all the time. I had to zero out wgdc until 3000 rpm to keep boost in check at lower rpm's.
I read somewhere that this was happening with the BNR's and then they started shipping them with a lower wastegate setting to open around 12 psi.
 Old 03-28-2016, 03:57 PM   #17
tmillner's Avatar
I had to adjust my wg preload, causing boost creep. Kinda a pain in the ass. If anyone does get an s4 talk with your tuner, before you install, about your preload.
The Following User Says Thank You to tmillner For This Useful Post:
Kreiderm01 (10-15-2016)
 Old 03-28-2016, 05:52 PM   #18
I'm no longer thinking about it, I just pulled the trigger on the S4
2012 MS3 VRM/w Tech
Oil-RP 10/30
The Following 2 Users Say Thank You to voodoo2crue For This Useful Post:
dale_gribble (03-28-2016), Thepedigree13 (03-29-2016)
 Old 03-28-2016, 05:59 PM   #19
tmillner's Avatar
HELL YEAH
 Old 03-28-2016, 11:23 PM   #20
memin's Avatar
Posts: 994   (View Stats)
I know this may be a little off topic but I debating between S4 and the CS turbo, does anybody has any input on this two turbos?? I am trying to get the most bang for my $$ overall (reliability, quality, hp, etc) Thanks in advance!!!
Flying_NEB and ANS like this.
 Old 03-29-2016, 02:25 AM   #21
The CS Turbo is most similar to a S3.
sent from my Nexus 6P
allo80 (04-23-2016), memin (03-29-2016)
 Old 03-29-2016, 05:19 AM   #22
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
If you autocross at all, S3 all the way. The S4 is going to be a dog in the low RPM's. The S3 by comparison has a much lower boost threshold and reaches peak torque pretty damn early (3000 RPM's on my car). It feels similar to a K04 on the course, just less "punch" down low. The S3 is no slouch in terms of flow, either. More than enough to max the stock engine (torque, power, fuel injector) but without the delayed spool of the S4 or other midsize turbos.
If you don't autocross, S4 is probably the way to go per previous posts. Fatter powerband with more total power for track/street usage.
2007 Mazdaspeed3 GT
 Old 03-29-2016, 07:28 AM   #23
08speed's Avatar
Posts: 147   (View Stats)
08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of
I'll be ordering a s4 in the next week or two. There's still a few supporting mods i'll need to get though.
allo80 likes this.
08speed is offline   Reply With Quote
 Old 03-29-2016, 08:49 AM   #24
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
My k04 recently gave out on me, so I needed to replace the turbo. I was also trying to figure out which which turbo to go with the s3 or s4. I chose the bnr s3 because it spooled very much like the k04 but with the benefit of the top end power. Also I do not plans on pushing my car 400whp at all, and didn't want to put too much stress on the engine. I got a really sweet deal on therpmstore for the bnr s3 combo. Bnr s3 is great! Spools fast and holds boost all the way to redline. Only downside is that on pump 91octane gas its very knock limited. But on an e85 mix this thing is a complete monster. So far I like the turbo a lot. Super fun for a dd and to smash down some curvy back roads, the power is everywhere. So if i say if you don't have any plans on pushing your car 400whp+ then this is a great turbo!
Nitro likes this.
Dennisms3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Dennisms3 For This Useful Post:
Kreiderm01 (10-15-2016), manselainen (04-01-2016)
 Old 03-29-2016, 09:10 AM   #25
tmillner's Avatar
What kind of gains did you see from the e85 mix? I think I'm getting close to being knock limited
 Old 03-29-2016, 09:21 AM   #26
Dennisms3's Avatar
Default BNR S3 or BNR S4
Currently just got done with my 91 octane tune. If I remember correctly, I was running 22psi. and only able to run about 8.5* or 9* timing @7k rpm. Vd showed ~320whp ~350wtrq. I am now tuning it for a e30 mix with 20psi tampering to 23psi @redline with 13* @7k rpm. Vd is showing ~350whp ~360wtrq. I still have more left in the turbo. My goal is 370-380whp on e30.
Mods are:
Tmic (not sure what kind)
3bar map sensor
Grimmspeed ebcs
Ebay catless dp
Jbr tru 3" intake
Bnr s3
Autotech hpfp internals
Forge bpv
Custom Vented occ
NGK step colder plugs
Cobb ap v3
Im also going fmic soon, I feel like it will help in the summer.
 Old 03-29-2016, 09:25 AM   #27
tmillner's Avatar
On a 93 tune, not finished yet, I'm running around 22 psi not sure of timing. Vd is showing snot the same 320. We'll see what the finish product is. But I'm pretty sure I'll do an e30 tune too
What kind of knock were you seeing
Last edited by tmillner; 03-29-2016 at 09:25 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-29-2016, 09:29 AM   #28
Dennisms3's Avatar
I think it was around 1.40-2.00.
 Old 03-29-2016, 09:34 AM   #29
tmillner's Avatar
Did it taper off or consistent
 Old 03-29-2016, 09:42 AM   #30
Dennisms3's Avatar
It was consistent from around 6200-6500. When I do my logs I keep an eye out on the knock, as soon as I noticed the knock I let off the throttle. Im almost certain it was from high bats. I did 2 pulls on a chilly night, bats were fairly cool and got no knock. Then did 2 pulls in 70degree weather during daytime with the same timing and got that knock. So I pulled some timing and no more knock on 91 octane. I think I was getting knock around 10* @7k rpm. So I think I'm at 8.5* now. Because of the high bats is why I'm considering a fmic. Iv seen people make 330-350 on 93 octane, so I'm pretty sure you can make a bit more.
 Old 03-29-2016, 05:11 PM   #31
tmillner's Avatar
Looks like I'm at 8.5* but now i have no kr after spool up. This revision the tuner advanced timing not sure how high. I'll do another pull tonight. Im hoping to get to 350whp on 93 but doesn't look like its going to happen
 Old 03-29-2016, 05:32 PM   #32
Rambo's Avatar
Anyone making 350+whp on a s3 pump gas? We get 94 here in Canada
 Old 03-29-2016, 05:33 PM   #33
Nitro's Avatar
350hp on 93 would be nice. I am at that with she'll 92 and e85. 18* at 6000rpm
@Rambo; our Chevron 94 on the west coast is terrible.
Stratified Tune
Last edited by Nitro; 03-29-2016 at 05:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-29-2016, 05:37 PM   #34
tmillner's Avatar
@Rambo our Chevron 94 on the west coast is terrible.
Where are you located, I can't find it through this damn app
 Old 03-29-2016, 05:38 PM   #35
Nitro's Avatar
Lol. I am in Vancouver, Canada
Stratified Tune
 Old 03-29-2016, 05:39 PM   #36
tmillner's Avatar
If trump gets elected I'll be calling you neighbor
 Old 03-29-2016, 06:06 PM   #37
Nitro's Avatar
Sounds good @tmillner
Stratified Tune
 Old 03-29-2016, 06:49 PM   #38
Rambo's Avatar
@Nitro; how much were you making on pump gas?
 Old 03-29-2016, 06:52 PM   #39
Nitro's Avatar
@Rambo. VD showed low in my opinion. It was around 310hp. The problem with VD, in my opinion, is it is hard to get an accurate reading. I finally went to an actual dyno to get my e85 tune confirmed.
Stratified Tune
 Old 03-29-2016, 06:55 PM   #40
Rambo's Avatar
Damn... @nitro. I'm at 305whp with the K04 on pump. I want to be able to feel the extra power hoping the s3 can get me 40-50whp
allo80 likes this.
Page generated in 0.62551 seconds with 31 queries
