![]() Join Date: Nov 2009 Location: Vancouver, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Hmm maybe I am off a bit there. I will try to find my dyno pulls with the k04 and then the BNR S3
__________________ COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85 Stratified Tune |
![]() Join Date: May 2013 Location: Bothell, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Still torn between the two. Is it worth the extra few hundred bucks if you aren't going to be running meth or e85? correction: $150. Ignore me. I'll retreat back to the corner.
__________________ 2016 Mustang "Echo" Boost in sexy ass green. ![]() 2008 silver MS3 -Sold- Last edited by Chef_boi_r_u_dum; 03-29-2016 at 07:31 PM. Reason: I'm a dumbass. |
![]() Join Date: Mar 2014 Location: Sedalia,MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
If you want to make more power on pump gas then yeah, its worth the extra 150$. Plus so much more room for power later down the line. | |
![]() Join Date: Jun 2014 Location: Savannah , GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score The s4 cab take you beyond the stock motor if you ever decide to go that route Sent from my SM-N920P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score To be fair if you're planning on getting a built engine you may as well go a step further than an S4 anyway. |
| The Following User Says Thank You to broda For This Useful Post: | Code Monkey (04-01-2016) |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
That's why I run a gallon of methanol in the gas tank. Works wonders with 94 octane. I'm able to get away with 17 degrees of timing, and 18.5 psi at 6k rpm on the K04 with no knock. On top of that I run WMI with a small nozzle to keep BAT's cool and power consistent. Just need an S4 to take full advantage of my setup. I also don't plan on building the block any time soon, but if I do the S4 should be plenty.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 04-01-2016 at 08:41 PM. Reason: MSF Database - Automerged Doublepost | ||
| Not Ranked : 0 score Here is a comparison of my e30 mix k04 tune vs my bnr on 91 octane tune. I did pull timing in the mid range after this k04 log and on a dynojet I put down 319whp 335wtrq with the K04 on e30 mix. I haven't dynoed the bnr yet. Last edited by Dennisms3; 03-29-2016 at 10:08 PM. |
| The Following User Says Thank You to Dennisms3 For This Useful Post: | Whitebullet (12-26-2018) |
| Not Ranked : 0 score Where do you get your methanol? Consumer places or online? Sent from my SM-N920P using Tapatalk
(Thread Starter) | Not Ranked : 0 score Methyl Hydrate or Air Brake Anti freeze, I get it from Canadian Tire, they sell 1 gallon for 10 bucks. I also heard Home Depot may carry the same thing, but never checked.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
| The Following User Says Thank You to BuddySpeed3 For This Useful Post: | Liquidsilver (03-03-2017) |
![]() Join Date: Jan 2014 Location: San Diego, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Just picked up an S4 for $900! Only had 1500miles clocked on her. Sent from my SM-G935T using Tapatalk
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff |
| Neutral : +1 score S3 for me. My decision was made based on not wanting to max the stock block/internals, not wanting to use aux fueling/meth and not wanting to buy a new intake.
__________________ 2016 Mustang "Echo" Boost in sexy ass green. ![]() 2008 silver MS3 -Sold- |
![]() Join Date: Jul 2013 Location: Eastvale, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 214
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score Old thread bump, but what intake did you run? RPM's website says the s3 inlet is 2.36 while the k04 is 2.16. Will I be able to stretch a silicone JBR intake for the k04 onto the s3? |
| Not Ranked : 0 score Yes.
| The Following User Says Thank You to Code Monkey For This Useful Post: | StevenW (07-11-2016) |
| Not Ranked : 0 score I'm a diesel mechanic i got that air brake stuff everywhere. Never really looked at it. Knew it was alcohol, didn't but 2 and 2 together. Thanks for the info Sent from my SM-N920P using Tapatalk
| The Following User Says Thank You to tmillner For This Useful Post: | Liquidsilver (03-03-2017) |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score Gotta admit.... even only being on my 2nd revision 91 tune...the S4 feels great... so far max boost is a hair under 19 psi and 11 degrees of timing (@ 6.4k).. Can't wait till 91 tune is complete so I can get started with the meth tune.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
(Thread Starter) | Not Ranked : 0 score My gosh that thing is gonna rip! It's crazy how much power its making on 91 alone. It's just feeding the engine way more efficiently.
| Not Ranked : 0 score Well I didn't mention anything about the power it's making lol.. it should be around 320whp right now (based on butt dyno) ... but it's how it makes and feels with that power that is impressive.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite Last edited by specvspeedfreak; 04-08-2016 at 11:43 AM. |
![]() | | #19 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Why is this thread even still going? All this theory talk, when you can just buy it and find out for yourself. Makes more power on pump gas, can be maxed out on a built motor and aggressive tune with sufficient fuel and has better boost control than even the v2 BNR S3. If you dislike the turbo for whatever reasons It won't be the end of your car, I ran the GTX28676R and will now be going BNR S4 this go around before trying out a Precision turbo on a vband setup. JUST DO IT.
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | BuddySpeed3 (04-09-2016) |
![]() | | #20 | ![]() |
| sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | impossible (05-01-2016) |
![]() | | #21 | ![]() |
Groans: 30
![]() | | #22 | ![]() |
| Not Ranked : 0 score Side note, wtf is he doing? Transformers rattle his brain? Sent from my SM-N920P using Tapatalk
![]() | | #23 | ![]() |
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #24 | ![]() |
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC | |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score Got the S4 in yesterday, here's some BNR porn
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
| The Following 2 Users Say Thank You to voodoo2crue For This Useful Post: | BuddySpeed3 (04-24-2016), djrich26 (04-17-2016) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score This was from last weekend Currently tuning with Freektune
| The Following User Says Thank You to iamareios For This Useful Post: | Liquidsilver (03-03-2017) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Mine was a pain. Took me all of sunday to install. I'm also tuning with Freektune right now. Yay for bigger turbos!
![]() | | #28 | ![]() |
| Not Ranked : 0 score I picked mine up used so it didn't come with any exhaust studs or nuts. That was my only problem. Extracting the old rusted ones off my turbo and reusing them. PITA! Otherwise i did it without having to remove the exhaust manifold.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Maybe that's why. I did it with the manifold and stock dp in place.
![]() | | #30 | ![]() |
| Not Ranked : 0 score Been driving on an almost complete 91 tune S4 for sometime now and can say hands down the S4 is superior to the S3... I remember when the S3 was claimed as the best turbo for daily driving and stock block <<< that can't be said anymore.. The off/on boost delivery is perfect with smoother and stronger power... The best part? the power band is widened up to perfection... It has a strong hit (maybe not as fast as the s3) but the continues chugging of the turbo all the way to redline just has a different, kick ass feel now... inherents a good side effect; the feel of taller gearing. WIN Even though I really want to start my meth tune... it's at a real good place with just 91 so no big deal.
| The Following 2 Users Say Thank You to specvspeedfreak For This Useful Post: | impossible (05-01-2016), Whitebullet (12-26-2018) |
![]() | | #31 | ![]() |
![]() Join Date: May 2009
I dont care about the $200 price difference between stage 3 and 4 and I dont plan to rebuild the motor. I need a reliable DD and I need a replacement on my leaking ko4 with 113k miles on it, and soon. | |
![]() | | #32 | ![]() |
Edit.. sorry if the last line sounds like I'm selling on an infomercial lol.. In all honesty I have experienced tunes by two well known tuners(for the S4). Tuner A is like a magician and every revision has been great with throttle/turbo response I prefer. Tuner B, well, let's just say I've had good revisions to something that was super hyper ninja shit.. which I hated and made drivability garbage. At the end he just wasn't as polished of a tuner as people think he is. The reason for 2 tuners is cause tuner A is very busy and slow with kicking out revisions...got impatient and went to tuner B.. Now I'm back with tuner A, he is worth the wait. Moral of the story. Choose a good tuner!
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite Last edited by specvspeedfreak; 10-15-2016 at 01:03 PM. | |
![]() | | #33 | ![]() |
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
| The Following 2 Users Say Thank You to BuddySpeed3 For This Useful Post: | blackms3_71 (10-20-2016), We're All Thieves (11-22-2016) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Not sure... I would call them.. I don't think there is a "concern" .. well at least for me; even needing more preload isn't a concern since it can be specific to setup and really the opposite of harmful.
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | BuddySpeed3 (10-18-2016) |
![]() | | #35 | ![]() |
Groans: 30
| Not Ranked : 0 score lmao idk hollywood brings out the weird in people but I still love Shia Labeouf on screen, dude has come a LONG WAY from Even Stevens lol
![]() | | #36 | ![]() |
| Not Ranked : 0 score Running e33? Sent from my SM-N920P using Tapatalk
![]() | | #37 | ![]() |
On E25 atm
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I wish i was smart enough to self tune. S4 keeps pulling doesnt it Sent from my SM-N920P using Tapatalk
![]() | | #39 | ![]() |
Groans: 438
| Not Ranked : 0 score I've decided to go s4. My car has been down because of the 1 of the POS oem injector seals blowing, and CS was out of their beauties until the end of April. While all this has happened I decided i'll be taking off my s3, and will be getting the s4. And the seals should be here tomorrow. So yeah, I'll be putting an s3 up for sale this week/weekend sometime. Just have to stop being lazy an actually remove it. And go green again I see.
![]() | | #40 | ![]() |
Groans: 143
| Not Ranked : 0 score Why would you upgrade from an S3 to a CS anyway man? That's a sidegrade, not an upgrade. Hope the S4 works for you. I'm probably going the opposite direction (smaller) after having the S3 honestly but I can understand the appeal of big turbo power especially for how cheap the S4 is. It's an amazing value.
| Display Modes | |
