![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Hey everyone, I searched and couldn't find a dedicated thread comparing the these two turbochargers. I'm looking into upgrading the stock K04 with either a BNR S3, or a BNR S4 simply because of their good reviews, price, and simplistic installation. I'm leaning more towards the S4 because it opens up more possibilities in the future for more power to be made. How do they compare in terms of: - Reliability - Ease of installation - Efficiency (max boost before being overworked) - Spool characteristics (rpm wise) And is there a parts list available for all the required parts to run either setup safely and efficiently? Thanks any input is appreciated.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
| Not Ranked : 0 score Without a single hesitation, S4. I wouldn't even think twice about it. I've had a BNR S3 for a few years. The BNR S4 spools as quickly as the S3 and flows an extra ~5lbs/min on the top end and it doesn't have to work as hard as the S3 to do it. In other words, with an S4 you give up nothing and get more and the install is just as easy. I've been contemplating an S4 myself after seeing the dyno plots of that S4. They give me tingly feelings.
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: | CWP_MS3 (03-24-2016), Mauro_Penguin (03-24-2016), We're All Thieves (05-06-2016), Whitebullet (12-26-2018) |
List of required parts for an S4 setup: - 3 inch intake/inlet hose - 3 bar/3.5 bar map sensor with IAT sensor to monitor BAT's (will a 3 bar suffice?) - EBCS (which brand should I go with?) Is there anything else I need? Or is it really that simple? Do all the oil and coolant lines just bolt right up? I read that I will have to change the MAP Scalars and Offsets for the new MAP sensor to read accurately, but that shouldn't be a problem. I also read that for an S3 setup the BCS has to be relocated. I'm wondering if that would be the same for the S4. Thanks again!
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
| Not Ranked : 0 score The BNR S3/S4 turbos comes with new crush washers for the oil feed and coolant feed and drain banjo fittings. The Turbos also come with a little coolant feed adapter so it goes right onto your stock coolant feed. It's really quite straightforward. Your list is fine. I think a 3-bar is fine unless you plan on going over 40psi. I would get whichever EBCS is offered in the package deals, that's fine. Do yourself a favor and get 9 new turbo studs and 9 new nuts for said studs. You really don't want to rely on removing and reusing your existing studs/nuts because chances are they are going to be fused together at this point and not reusable. You can get the studs/nuts pretty cheap from Edge if I remember right. Don't get OEM, they are pricey. You can reuse the metal turbo to exhaust manifold gasket and metal downpipe gasket if you want. I replaced mine, but originals looked fine. I would recommend getting a new oil drain gasket (the diamond shaped one) that is between the turbo's 2-bolt drain pipe and the turbo. Cheap insurance. Yes, scale MAP sensor. Zero all wastegate and rebuild boost curve from scratch. Work with a tuner if you are unsure about how to proceed.
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: | Mauro_Penguin (03-24-2016), PapaBruno (03-24-2016), We're All Thieves (07-02-2016), [R]usty (03-24-2016) |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
| The Following 7 Users Say Thank You to Djohns For This Useful Post: | dale_gribble (03-23-2016), impossible (04-06-2016), Mauro_Penguin (03-24-2016), MD1032 (03-29-2016), MS3Shadow (03-23-2016), WAMBUSHHHH! (03-24-2016), We're All Thieves (07-02-2016) |
(Thread Starter) | Not Ranked : 0 score Whoa really? Studs and nuts? Which vendor? How do I go about relocating the ECU?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 03-24-2016 at 05:24 PM. Reason: MSF Database - Automerged Doublepost |
The reason I ask is because I've looked around and see some that only sell the turbo, and don't mention any other parts.
![]() Join Date: Sep 2013 Location: Winnipeg, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score ive even been considering selling my 2871 and grabbing an S4. seems like a damn good turbo
__________________ 2007 CWP MS3 Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks |
| Not Ranked : 0 score I am really trying to fight the urge to buy an s4 right now. I don't need it, s3 is great. Lord, give me strength.
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
As for the OP, honestly if you have the extra $$$ to go with the S4, do it. Very little trade-off between the S3 and S4 and the S4 offers you a little extra head room for future in case you wanted to go further.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 | |
| The Following User Says Thank You to WAMBUSHHHH! For This Useful Post: | Mauro_Penguin (03-24-2016) |
| Give in into the S4. Let the S4 flow through you. sent from my Nexus 6P
| The Following 3 Users Say Thank You to MS3Shadow For This Useful Post: |
| Not Ranked : 0 score Let the s4 flow through your intercooler.
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score Think of it as a $500-600 upgrade if you have an s3... that's the approach I took justifying my purchase.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | dale_gribble (03-23-2016) |
| Not Ranked : 0 score Mine comes in within the first week of April and my body is ready
| The Following User Says Thank You to Djohns For This Useful Post: | BuddySpeed3 (03-24-2016) |
| The Following 5 Users Say Thank You to dale_gribble For This Useful Post: | CWP_MS3 (03-24-2016), impossible (04-26-2016), jrlms6 (03-26-2016), Jtaylor (05-02-2016), NC-MS3Rob (03-24-2016) |
![]() Join Date: Nov 2009 Location: Vancouver, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score I would get a gaurdian angel from Stratified. It is a great failesafe for over boosting and it will work as an updated MAF. I run this with a stratified 3port
__________________ COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85 Stratified Tune |
| The Following User Says Thank You to Nitro For This Useful Post: | BuddySpeed3 (03-24-2016) |
| The Following User Says NO Thank You to Nitro For This Un-useful Post: | faeker (05-01-2016) |
![]() Join Date: Jun 2014 Location: Savannah , GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Tuning an s4 now with stratified. Installation was pretty straight forward, any questions pm me I'd be more than happy to help. Like dale said your list is good, if you get through rpm will come with ebcs, jbr, 3 bar and adapter. If you do get a 3 inch intake you'll need to relocate the ecu. Also consider getting a new coupler if you have a fmic, where the hot pipe comes in to the turbo sits higher than the stock k04. Sent from my SM-N920P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC |
| The Following User Says Thank You to tmillner For This Useful Post: | BuddySpeed3 (03-24-2016) |
| Not Ranked : 0 score tmillner I run a JBR 3 inch on a BNR S3 and did not have to relocate the battery. Does the S4 fit tighter? I purchased everything through Stratified: BNR S3, 3 port, gaurdian angel, Cobb catted downpipe and Tune. He was great and his prices are very fair and comparable.
![]() | | #19 | ![]() |
![]() Join Date: May 2013 Location: Bothell, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Well shucks. I'm looking at an S3 and you might just talk me into an S4 even though I wouldn't necessarily need it.
__________________ 2016 Mustang "Echo" Boost in sexy ass green. ![]() 2008 silver MS3 -Sold- |
| The Following User Says Thank You to Chef_boi_r_u_dum For This Useful Post: | cgspeed6 (10-13-2016) |
![]() | | #20 | ![]() |
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC | |
![]() | | #21 | ![]() |
| Not Ranked : 0 score I think the turbo inlet extends further on the s4. Its a 3 inch inlet rather than the stock size like the s3 Sent from my SM-N920P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC Last edited by tmillner; 03-24-2016 at 02:55 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #22 | ![]() |
| Not Ranked : 0 score It works very well. I plan on getting a cooling mist fail safe for my wmi. It will trigger if there is a pump failure with the gaurdian angel.
![]() | | #23 | ![]() |
![]() Join Date: Jul 2010 Location: Bear, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
| Not Ranked : 0 score I'm currently BNR S1. At the time when my ko4 crapped out I didn't have supporting mods for a S3 or big turbo. A little time has passed - lots of parts ordered. I now have all the supporting mods. When I return from my deployment it's S4 time.
__________________ Silver 08 MS3- Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP. [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to Jsn_Rob For This Useful Post: | dale_gribble (03-24-2016), MizzyMS3 (03-25-2016) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score S4 with no aux fuel and stock block?
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah for now, and at this point I'm using WMI with a small nozzle for added knock protection and low BAT's. How much boost do u think I can get away with up top without aux fueling? I suppose I may have to lean out a bit depending how much I target.
![]() | | #26 | ![]() |
| Not Ranked : 0 score I think corksport sells a battery box ecu relocation kit. Mine is a ghetto set up until i stop being lazy and build a bracket. I had to remove some zip ties and loom to get the slack Sent from my SM-N920P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC Last edited by tmillner; 03-24-2016 at 05:27 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Studs/nuts are not necessary.. even if they are fused together, once you start tightening the nut it will break loose and you just need to continue tightening.. but that said they are cheap. Nothing else is needed for the s4 other than the correct coupler. All the gaskets are provided. It even comes with mani/dp gaskets. I forget the exact term but I would extend the coolant (heater) hose that runs underneath the intake. You'll need it if you have a bigger intake. Smaller battery box is not needed.
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | BuddySpeed3 (03-26-2016) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Battery box isn't needed but if you go with a 3 inch intake ecu relocation is, so might as well get on to relocate ecu I forgot about extended that coolant hose. I cosign the not needing new studs, mine came out pretty easy, i guess i lost the new ones they sent. But if you can get them you should Sent from my SM-N920P using Tapatalk
![]() | | #29 | ![]() |
Out of curiosity, how much boost can the S4 generate at high rpm's before it starts becoming inefficient?
![]() | | #30 | ![]() |
http://www.hitunedperformance.com/5-...extension-kit/ sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | alexwlwsn (03-28-2016), Sasuke-kun (02-16-2019) |
![]() | | #31 | ![]() |
![]() Join Date: Jan 2014 Location: Harco MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Thanks for the link!
__________________ 2008.5 CWP MazdaSpeed3 Purple Drank Tuned ATP GT3076R @ 26 psi 369.5whp & 348wtq.. yawn | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I think more than the stock block can handle but I'll let someone smarter than me answer. I got hose from auto parts store, i think it was 5/8 and a fitting to connect. Whether you replace studs or not spray with pb blaster to remove. I never liked the stuff but it helped. Sent from my SM-N920P using Tapatalk
![]() | | #33 | ![]() |
| Not Ranked : 0 score I think the S4 can take things beyond the stock fueling capability.
![]() | | #34 | ![]() |
| Not Ranked : 0 score Depends on how clean you want it to look... if relocating the ecu of top of the fuse box is not good enough than you'll need the CS box or small battery box, etc. The heater hose stuff you can buy from home depot or lowes... just use the link as reference... Get the s4 and end the questions and doubts! Lol
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | Sasuke-kun (02-16-2019) |
![]() | | #35 | ![]() |
| The Following 2 Users Say Thank You to tmillner For This Useful Post: | Sasuke-kun (02-16-2019), specvspeedfreak (03-26-2016) |
![]() | | #36 | ![]() |
| If you get a smaller battery (51R), the ECU can fit inside of the stock battery box. sent from my Nexus 6P
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Sasuke-kun (02-16-2019) |
![]() | | #37 | ![]() |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score This thread is exactly what I've been bouncing around back and forth in my head for several weeks now. I'll be buying one of these turbos in the next week or two and still can't decide. I'll have about 1100$ to play with so I'm trying to figure out what the best way to go would be. If I go with the s3 I'll have enough to upgrade my intake also which is currently the corksport "stg 2" combo that has the stock turbo sized inlet pipe on the inlet side. If I go with the S4 I'll be stuck with the CS SRI/TIP for a while longer....I know, just buy it all and quit being a pussy right? BUT,I HAVE to start having some will power to quit spending money on this car lol
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Kinda, I'll probably go s4 and worry about the intake later, I don't want to be kicking myself in the ass in a few months for NOT getting the s4.
![]() | | #40 | ![]() |
| Not Ranked : 0 score Does anyone know the gains from a 3 inch intake over cs "stg2"? My thought was I'd rather re-buy an intake then a turbo if I want bigger Sent from my SM-N920P using Tapatalk
