Like Tree53Likes
 Old 03-23-2016, 03:25 PM   #1
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Default BNR S3 or BNR S4
Hey everyone, I searched and couldn't find a dedicated thread comparing the these two turbochargers. I'm looking into upgrading the stock K04 with either a BNR S3, or a BNR S4 simply because of their good reviews, price, and simplistic installation. I'm leaning more towards the S4 because it opens up more possibilities in the future for more power to be made.
How do they compare in terms of:
- Reliability
- Ease of installation
- Efficiency (max boost before being overworked)
- Spool characteristics (rpm wise)
And is there a parts list available for all the required parts to run either setup safely and efficiently?
Thanks any input is appreciated.
Youngsway21 likes this.
 Old 03-23-2016, 04:14 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Without a single hesitation, S4. I wouldn't even think twice about it. I've had a BNR S3 for a few years. The BNR S4 spools as quickly as the S3 and flows an extra ~5lbs/min on the top end and it doesn't have to work as hard as the S3 to do it.
In other words, with an S4 you give up nothing and get more and the install is just as easy. I've been contemplating an S4 myself after seeing the dyno plots of that S4. They give me tingly feelings.
MINI H1 6.0 - CAR LED TAILS
CWP_MS3 (03-24-2016), Mauro_Penguin (03-24-2016), We're All Thieves (05-06-2016), Whitebullet (12-26-2018)
 Old 03-23-2016, 06:51 PM   #3
Haha I bet they do, and the price difference isn't that much between the two on the rpm store website. I'm probably going to go with the S4 because it seems there are no downsides.
List of required parts for an S4 setup:
- 3 inch intake/inlet hose
- 3 bar/3.5 bar map sensor with IAT sensor to monitor BAT's (will a 3 bar suffice?)
- EBCS (which brand should I go with?)
Is there anything else I need? Or is it really that simple? Do all the oil and coolant lines just bolt right up? I read that I will have to change the MAP Scalars and Offsets for the new MAP sensor to read accurately, but that shouldn't be a problem. I also read that for an S3 setup the BCS has to be relocated. I'm wondering if that would be the same for the S4. Thanks again!
 Old 03-23-2016, 06:58 PM   #4
The BNR S3/S4 turbos comes with new crush washers for the oil feed and coolant feed and drain banjo fittings. The Turbos also come with a little coolant feed adapter so it goes right onto your stock coolant feed. It's really quite straightforward.
Your list is fine. I think a 3-bar is fine unless you plan on going over 40psi. I would get whichever EBCS is offered in the package deals, that's fine.
Do yourself a favor and get 9 new turbo studs and 9 new nuts for said studs. You really don't want to rely on removing and reusing your existing studs/nuts because chances are they are going to be fused together at this point and not reusable. You can get the studs/nuts pretty cheap from Edge if I remember right. Don't get OEM, they are pricey.
You can reuse the metal turbo to exhaust manifold gasket and metal downpipe gasket if you want. I replaced mine, but originals looked fine.
I would recommend getting a new oil drain gasket (the diamond shaped one) that is between the turbo's 2-bolt drain pipe and the turbo. Cheap insurance.
Yes, scale MAP sensor. Zero all wastegate and rebuild boost curve from scratch. Work with a tuner if you are unsure about how to proceed.
iamareios and PapaBruno like this.
Mauro_Penguin (03-24-2016), PapaBruno (03-24-2016), We're All Thieves (07-02-2016), [R]usty (03-24-2016)
 Old 03-23-2016, 07:28 PM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
The fun part about the s4 package is that it comes with new studs!
2010 black mica speed3
Soon:built motor
The Following 7 Users Say Thank You to Djohns For This Useful Post:
dale_gribble (03-23-2016), impossible (04-06-2016), Mauro_Penguin (03-24-2016), MD1032 (03-29-2016), MS3Shadow (03-23-2016), WAMBUSHHHH! (03-24-2016), We're All Thieves (07-02-2016)
 Old 03-24-2016, 05:24 PM   #6
Whoa really? Studs and nuts? Which vendor?
Originally Posted by tmillner View Post
I think the turbo inlet extends further on the s4. Its a 3 inch inlet rather than the stock size like the s3
How do I go about relocating the ECU?
Last edited by BuddySpeed3; 03-24-2016 at 05:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-24-2016, 05:14 PM   #7
Thank you, I will definitely follow that advice. Do all vendors sell these turbos with the said seals or is it just a select few? And which vendor sells the most complete kit with the necessary supporting mods?
The reason I ask is because I've looked around and see some that only sell the turbo, and don't mention any other parts.
 Old 03-23-2016, 08:42 PM   #8
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
ive even been considering selling my 2871 and grabbing an S4. seems like a damn good turbo
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
 Old 03-23-2016, 08:44 PM   #9
I am really trying to fight the urge to buy an s4 right now. I don't need it, s3 is great. Lord, give me strength.
PapaBruno and voodoo2crue like this.
 Old 03-24-2016, 03:24 PM   #10
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
stop being a pussy and do it.
As for the OP, honestly if you have the extra $$$ to go with the S4, do it. Very little trade-off between the S3 and S4 and the S4 offers you a little extra head room for future in case you wanted to go further.
The Following User Says Thank You to WAMBUSHHHH! For This Useful Post:
 Old 03-23-2016, 09:15 PM   #11
Give in into the S4.
Let the S4 flow through you.
sent from my Nexus 6P
Atticaz and PapaBruno like this.
The Following 3 Users Say Thank You to MS3Shadow For This Useful Post:
dale_gribble (03-23-2016), Djohns (03-23-2016), jrlms6 (03-26-2016)
 Old 03-23-2016, 09:19 PM   #12
Djohns's Avatar
Let the s4 flow through your intercooler.
Soon:built motor
 Old 03-23-2016, 09:34 PM   #13
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Think of it as a $500-600 upgrade if you have an s3... that's the approach I took justifying my purchase.
 Old 03-23-2016, 10:23 PM   #14
Djohns's Avatar
Mine comes in within the first week of April and my body is ready
Soon:built motor
BuddySpeed3 (03-24-2016)
 Old 03-23-2016, 10:29 PM   #15
PapaBruno, sh4d0w, dinoxor and 1 others like this.
CWP_MS3 (03-24-2016), impossible (04-26-2016), jrlms6 (03-26-2016), Jtaylor (05-02-2016), NC-MS3Rob (03-24-2016)
 Old 03-24-2016, 01:50 PM   #16
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
I would get a gaurdian angel from Stratified. It is a great failesafe for over boosting and it will work as an updated MAF. I run this with a stratified 3port
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
The Following User Says Thank You to Nitro For This Useful Post:
The Following User Says NO Thank You to Nitro For This Un-useful Post:
faeker (05-01-2016)
 Old 03-24-2016, 02:07 PM   #17
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
Tuning an s4 now with stratified. Installation was pretty straight forward, any questions pm me I'd be more than happy to help. Like dale said your list is good, if you get through rpm will come with ebcs, jbr, 3 bar and adapter. If you do get a 3 inch intake you'll need to relocate the ecu. Also consider getting a new coupler if you have a fmic, where the hot pipe comes in to the turbo sits higher than the stock k04.
Sent from my SM-N920P using Tapatalk
Nitro likes this.
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
The Following User Says Thank You to tmillner For This Useful Post:
 Old 03-24-2016, 02:11 PM   #18
Nitro's Avatar
tmillner I run a JBR 3 inch on a BNR S3 and did not have to relocate the battery. Does the S4 fit tighter? I purchased everything through Stratified: BNR S3, 3 port, gaurdian angel, Cobb catted downpipe and Tune. He was great and his prices are very fair and comparable.
va7kpt likes this.
Stratified Tune
 Old 03-24-2016, 02:31 PM   #19
Chef_boi_r_u_dum's Avatar
Posts: 380   (View Stats)
Chef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond repute
Well shucks. I'm looking at an S3 and you might just talk me into an S4 even though I wouldn't necessarily need it.
2016 Mustang "Echo" Boost in sexy ass green.
2008 silver MS3 -Sold-
Chef_boi_r_u_dum is offline   Reply With Quote
The Following User Says Thank You to Chef_boi_r_u_dum For This Useful Post:
cgspeed6 (10-13-2016)
 Old 03-24-2016, 02:59 PM   #20
tmillner's Avatar
S4 all the way
 Old 03-24-2016, 02:55 PM   #21
tmillner's Avatar
I'm looking at the guardian angel now, really considering it
Nitro likes this.
Last edited by tmillner; 03-24-2016 at 02:55 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-24-2016, 02:58 PM   #22
Nitro's Avatar
It works very well. I plan on getting a cooling mist fail safe for my wmi. It will trigger if there is a pump failure with the gaurdian angel.
Stratified Tune
 Old 03-24-2016, 03:19 PM   #23
Jsn_Rob's Avatar
Posts: 116   (View Stats)
Jsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond repute
I'm currently BNR S1. At the time when my ko4 crapped out I didn't have supporting mods for a S3 or big turbo. A little time has passed - lots of parts ordered. I now have all the supporting mods. When I return from my deployment it's S4 time.
Silver 08 MS3-
Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP.
Jsn_Rob is offline   Reply With Quote
The Following 2 Users Say Thank You to Jsn_Rob For This Useful Post:
dale_gribble (03-24-2016), MizzyMS3 (03-25-2016)
 Old 03-24-2016, 03:27 PM   #24
S4 with no aux fuel and stock block?
 Old 03-24-2016, 05:06 PM   #25
Yeah for now, and at this point I'm using WMI with a small nozzle for added knock protection and low BAT's. How much boost do u think I can get away with up top without aux fueling?
I suppose I may have to lean out a bit depending how much I target.
 Old 03-24-2016, 05:27 PM   #26
tmillner's Avatar
I think corksport sells a battery box ecu relocation kit. Mine is a ghetto set up until i stop being lazy and build a bracket. I had to remove some zip ties and loom to get the slack
I went through rpm, they sell the 3 bar, harness, ebcs, turbo with gaskets and studs
Last edited by tmillner; 03-24-2016 at 05:27 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-25-2016, 06:28 AM   #27
Studs/nuts are not necessary.. even if they are fused together, once you start tightening the nut it will break loose and you just need to continue tightening.. but that said they are cheap.
Nothing else is needed for the s4 other than the correct coupler. All the gaskets are provided. It even comes with mani/dp gaskets. I forget the exact term but I would extend the coolant (heater) hose that runs underneath the intake. You'll need it if you have a bigger intake.
Smaller battery box is not needed.
BuddySpeed3 (03-26-2016)
 Old 03-25-2016, 06:31 AM   #28
tmillner's Avatar
Battery box isn't needed but if you go with a 3 inch intake ecu relocation is, so might as well get on to relocate ecu
I forgot about extended that coolant hose.
I cosign the not needing new studs, mine came out pretty easy, i guess i lost the new ones they sent. But if you can get them you should
 Old 03-26-2016, 11:12 AM   #29
Thanks for the help, I'm definitely leaning more towards replacing the studs and nuts, relocating the ECU, purchasing a full 3 inch intake, and maybe getting a battery box if its required for ECU relocating. I want to accumulate all the required parts before commencing work on the car so I can get it done in one day, as it is my DD. And for extending the coolant hose, should I just buy some longer hose from home depot that can handle heat?
Out of curiosity, how much boost can the S4 generate at high rpm's before it starts becoming inefficient?
 Old 03-26-2016, 11:25 AM   #30
This is the extension I assume.
http://www.hitunedperformance.com/5-...extension-kit/
alexwlwsn (03-28-2016), Sasuke-kun (02-16-2019)
 Old 03-28-2016, 01:57 PM   #31
alexwlwsn's Avatar
Posts: 47   (View Stats)
alexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant future
5/8" Hose Extension Kit - Hi-Tuned Performance Products
I struggle getting my intake back on every time cursing that heater hose. Now I feel stupid I didn't know this existed.
Thanks for the link!
Nevershallifall likes this.
2008.5 CWP MazdaSpeed3
Purple Drank Tuned
ATP GT3076R @ 26 psi
369.5whp & 348wtq.. yawn
alexwlwsn is offline   Reply With Quote
 Old 03-26-2016, 11:19 AM   #32
tmillner's Avatar
I think more than the stock block can handle but I'll let someone smarter than me answer.
I got hose from auto parts store, i think it was 5/8 and a fitting to connect.
Whether you replace studs or not spray with pb blaster to remove. I never liked the stuff but it helped.
Nitro likes this.
 Old 03-26-2016, 11:27 AM   #33
Nitro's Avatar
I think the S4 can take things beyond the stock fueling capability.
Stratified Tune
 Old 03-26-2016, 03:49 PM   #34
Depends on how clean you want it to look... if relocating the ecu of top of the fuse box is not good enough than you'll need the CS box or small battery box, etc.
The heater hose stuff you can buy from home depot or lowes... just use the link as reference...
Get the s4 and end the questions and doubts! Lol
 Old 03-26-2016, 03:50 PM   #35
tmillner's Avatar
The Following 2 Users Say Thank You to tmillner For This Useful Post:
Sasuke-kun (02-16-2019), specvspeedfreak (03-26-2016)
 Old 03-26-2016, 03:55 PM   #36
If you get a smaller battery (51R), the ECU can fit inside of the stock battery box.
 Old 03-27-2016, 10:01 AM   #37
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
This thread is exactly what I've been bouncing around back and forth in my head for several weeks now. I'll be buying one of these turbos in the next week or two and still can't decide. I'll have about 1100$ to play with so I'm trying to figure out what the best way to go would be. If I go with the s3 I'll have enough to upgrade my intake also which is currently the corksport "stg 2" combo that has the stock turbo sized inlet pipe on the inlet side. If I go with the S4 I'll be stuck with the CS SRI/TIP for a while longer....I know, just buy it all and quit being a pussy right? BUT,I HAVE to start having some will power to quit spending money on this car lol
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 03-27-2016, 10:57 AM   #38
tmillner's Avatar
Does that help voodoo?
 Old 03-27-2016, 11:59 AM   #39
Kinda, I'll probably go s4 and worry about the intake later, I don't want to be kicking myself in the ass in a few months for NOT getting the s4.
allo80 likes this.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 03-27-2016, 10:47 AM   #40
tmillner's Avatar
Does anyone know the gains from a 3 inch intake over cs "stg2"?
My thought was I'd rather re-buy an intake then a turbo if I want bigger
Page generated in 0.65331 seconds with 32 queries
