  • 1 Post By mczimer
  • 1 Post By helmetface
 Old 10-28-2012, 07:34 PM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default BNR S3 Installed
Spent two days installing the BNR stage 3 this weekend, what a job! A big shout-out to @atvfreek for the great info and support (will most likely tune it with him).
His how-to: Freeks BNR install
A few tips for those in the future:
  • when bending the coolant line to fit it on the BNR, the best way I found was to mount it on the BNR, then bend it to get over. Smacking with a mallet as some have done may work too, but is more difficult IMHO.
  • I found a 14mm shorty wrench to be a critical component in order to get the rear dp-turbo nut off.
  • Be ready to loose a bunch of coolant, and make sure to clamp the coolant-turbo hose before removing the turbo
  • The lower oil line is the biggest PITA on this entire install. An 8mm ratcheting wrench is a must in order to get the lower tube-block bolt in. I also used a vice grip to give the ratchet some more length as well.
Some sizes added to atvfreek's list (to the best of my knowledge):
-Remove heat shields from manifold and turbo (8mm socket)
-Remove heat shield from the brake master cylinder (8mm socket)
-Remove egr valve and coolant hose from the coolant housing on the drivers side of the cylinder head (egr valve-2 8mm socket with extension)
-Remove brake booster hose, purge solenoid hose, and fuel line feed for the hpfp (I removed these from the firewall and then from the respective locations, to avoid damaging them. The fuel/blue is on the bottom of firewall and red is over it. Brake booster line is to the right of them
-Remove DP and upper manifold to turbo bolts (14mm socket with extensions, 14mm stubby)
-Unbolt oil feed line from the top of the turbo (8mm)
-Then go under the car and Remove the oil return line (8mm ratcheting wrench)
-Disconnect lower coolant line from turbo
-remove the turbo bracket
So, overall, I need to get a 3BAR and 3 port ebcs. I am now currently running a t-fitting as a temporary solution until those items can be sourced. Still looking for what to get and where, but I am leaning towards a Grimmspeed and the plug n play harness/3bar setup.
Thanks to all those who have contributed with info on the installation of this turbo, sorry I do not have pics to share.
Oh, I have two left over bolts, I cannot recall where they go. 14mm and 12mm (HELP ME)
tastysi2004 likes this.
mczimer is offline   Reply With Quote
The Following 5 Users Say Thank You to mczimer For This Useful Post:
atvfreek (10-28-2012), BrianB6 (10-31-2012), Dahouse702 (10-28-2012), tastysi2004 (10-28-2012), TiGraySpeed6 (10-28-2012)
 Old 10-28-2012, 07:41 PM   #2
atvfreek's Avatar
Posts: 7,787   (View Stats)
Glad to hear you got it installed. Lol at left over bolts... It happens.
The 14mm head bolt looks like it may go to the turbo support bracket but hard to tell.
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Fail_6 (10-30-2012)
 Old 10-28-2012, 08:30 PM   #3
You'll enjoy this turbo for sure!
 Old 10-28-2012, 08:35 PM   #4
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Not too sure but those bolts look super important...
Haha, I end up with several left over nuts and bolts from every install.
 Old 10-28-2012, 08:39 PM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
nice upgrade
340hp / 371tq
 Old 10-28-2012, 10:54 PM   #6
Matrix311's Avatar
Posts: 2,133   (View Stats)
Can't Wait to see your results after your tuned. I just about bought this turbo. Everyone loves this turbo
Sent from my SCH-I535 using Tapatalk 2
 Old 10-30-2012, 11:10 AM   #7
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
I think those bolts (or at least one of them) could be from the old downpipe and the mounting part on the first cat to bolt up to the frame. My first guess.
Performance:
Stratified Tune in progress
 Old 10-30-2012, 01:49 PM   #8
mczimer's Avatar
I have an aftermarket downpipe. Can you clarify?
 Old 10-30-2012, 03:40 PM   #9
Swinger13's Avatar
Groans: 53
when you took the stock cat out (the 1st cat) there should be a mounting plate that sticks out where it bolts up to the frame. Refer to the image in the red circle...
Performance:
 Old 10-30-2012, 12:00 PM   #10
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
Pretty good write up here, a lot of helpful tips for those doing this on their own
Grimmspeed is of course the most popular ebcs (and good on you for choosing ebcs over mbc), thoughive had nothing but success with the perrin. Bosche sells their 3 bar for $29 off the ballenger motorsports website, and be sure to pick up the plug and play from @MattJackson86 for approx $60. Make the install 10 mins, if that, with a 7 mm socket
Good luck
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Fail_6 For This Useful Post:
BrianB6 (10-31-2012), MattJackson86 (10-30-2012)
 Old 10-30-2012, 02:32 PM   #11
SWAY's Avatar
Posts: 2,517   (View Stats)
Groans: 190
Good luck
Mazdaspeed MAP Harness - Bitwise Motorsports
Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT
Heres the map harness site to purchase
edit: I dont know why i quoted you but theres what he needs
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 4 Users Say Thank You to SWAY For This Useful Post:
breakfstincluded (10-30-2012), Fail_6 (10-30-2012), MattJackson86 (10-30-2012), mczimer (10-30-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s3-installed-128679/
How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-06-2014 01:59 PM
Whats New/General Speed 6 Discussion - Page 236 This thread Refback 06-08-2013 10:13 PM
Beaner time! - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-16-2013 04:17 PM
Beaner time! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-26-2013 01:17 PM
BNR Stage 3 Turbo Upgrade - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-30-2012 01:30 PM
FP installed Airman3454 Gen2 MS3 General Discussion 2 07-07-2011 11:35 AM
Installed JBR RSB Speed3eak JAMES BARONE RACING 11 05-18-2011 03:59 PM
Installed SU RMM treyclash 2010 MS3 - Engine, Transmission & Driveline 5 01-07-2011 01:09 PM
PTP TMM V2 installed bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-27-2009 05:09 PM
CEL with CPE PnP Installed btkrausen MazdaSpeed 3/6 - ECU Computer Tuning 22 11-05-2008 11:01 AM
Page generated in 0.35060 seconds with 29 queries
