Like Tree8Likes
 Old 03-25-2014, 07:21 AM   #1
mikey32235's Avatar
Posts: 44   (View Stats)
mikey32235 is a glorious beacon of lightmikey32235 is a glorious beacon of lightmikey32235 is a glorious beacon of lightmikey32235 is a glorious beacon of lightmikey32235 is a glorious beacon of light
Default BNR S3 motor build
Hey guys, originally from the TM3 forum but i see that there are MUCH more guys on here who actually know what they are talking about lol…. basically what i have completed november of 2013 was the following:
- catted DP
- Test Pipe
- Cobb Accessport
- Auto-tech High Volume Fuel Upgrade Kit
- Spark Plugs - ITV-22 Denso Plugs
- GFB ByPassValve
- CX Racing Front Mount Intercooler
- JBR Motor mounts 88 Duro
- DMP Turbo Manifold
- BNR Stage 3 Turbo
- Meth injection stg 1 bst cooler
- Mishimoto Catch Can
- EGR Delete
- 3 Bar Map Sensor
- Plug and Play map Harness
- JBR IM TIG
- JBR TB TIG
- Injector Seals
- Grim speed EBCS
- HTP 3” wide path intake
- Wiseco Pistons overbore
- Eagle H-Beam Rods
Dyno tuned (toronto, Ontario) 348whp/414wtq
Now, after to speaking to LEX at stratified tuning he is telling me that i am running too rich, and a couple other things. now i have spoken to other technicians/tuninng specialists about this and they have taken a look at my logs and said the exact same thing..
ALSO…
Why is it that my whp is much lower than the tq? i see guys on a stock block with a k04 making 350whp! these numbers do not add up to me… probably when it gets warmer i will be getting stratified tuned… but i would like to know if anyone has any idea whats going on here. I spoke to the tuner who tuned my car and he says the car is fine, and its running rich because its cold. but its constantly running too rich.. and the wheelspin causes knock…
i attached some logs, if someone can take a look at them and give me some advice that would be great.
Forged - Overbore - BNR S3 - Meth -
*** Tuned 348whp/414wtq
Stratified tuning currently… Numbers coming soon
mikey32235 is offline   Reply With Quote
The Following User Says Thank You to mikey32235 For This Useful Post:
Lex (03-25-2014)
 Old 03-25-2014, 07:32 AM   #2
TheFlash's Avatar
Posts: 2,095   (View Stats)
Those numbers are pretty low. If you have already spoken with @Lex; I'm sure he has given you his opinion on it. Being built you should be pushing much higher numbers. A lot of people come into MSF with pro tune problems and a lot of the time it is bad tuning.
I ❤️ Nators
I drive a Mazda
 Old 03-25-2014, 07:34 AM   #3
mikey32235's Avatar
should i wait till it is a bit warmer outside like mid april to get tuned by lex?
also just to add i was running VTA before and just currently switched to VTI. checked for any leaks i don't see any.
 Old 03-25-2014, 08:42 AM   #4
TheFlash's Avatar
Depends on how comfortable you are with the tune. If you think it is safe and if something goes wrong the shop will take accountability for it, then tune when you are ready.
If you are worried about it and have the funds, go ahead and start the tuning process. It sounds like you are pretty much finished adding parts so getting tuned now is perfectly logical.
MSF tuners are very knowledgable and will make sure the tune is set to adjust to all whether conditions. I have been tuned be Lex for a little over a year now on E85 and have had zero issues. I also tuned in the middle of the winter.
I ❤️ Nators
mikey32235 likes this.
I drive a Mazda
 Old 03-25-2014, 08:44 AM   #5
mikey32235's Avatar
hmm, good point..
i am not really comfortable with my current tune for the reasons that i have heard the same thing from many people, running rich, knock, un even boost etc…
too bad 85 isn't available here will be using 94 + meth.
would you recommend upgrading to a bigger meth nozzle? i have the 325ml in there. i think i have a bigger one sitting at home
 Old 03-25-2014, 08:47 AM   #6
TheFlash's Avatar
That would be something to discuss with your tuner. If he thinks running a bigger nozzle will help then so be it. Not to scare you or anything but this is the most recent "pro tune" issue on the forum.
Tuners advice, open discussion
I ❤️ Nators
I drive a Mazda
 Old 03-25-2014, 08:49 AM   #7
mikey32235's Avatar
after all what i have spent id rather get a proper tune and save my ass from spending another couple thousand for a new motor and other things…
gonna go ahead and do this.
wish me luck!
@lex
The Following 4 Users Say Thank You to mikey32235 For This Useful Post:
ItsNox (03-25-2014), Mattcinnc1 (03-28-2014), TheFlash (03-25-2014), Vansquish (03-25-2014)
 Old 03-25-2014, 08:49 AM   #8
pwdunmore's Avatar
Posts: 368   (View Stats)
- catted DP
- Test Pipe
- Cobb Accessport
- GFB ByPassValve
- BNR Stage 3 Turbo
- EGR Delete
- 3 Bar Map Sensor
- JBR IM TIG
- JBR TB TIG
- Injector Seals
- Grim speed EBCS
- Eagle H-Beam Rods
ALSO…
All I have to say is about damn time you got on here more... I always link you threads so I am thinking that's what got you on here
My car thread:
 Old 03-25-2014, 08:50 AM   #9
mikey32235's Avatar
lol hey patrick!
 Old 03-25-2014, 08:51 AM   #10
TheFlash's Avatar
wish me luck!
@Lex
Plus to mention someone you have to put @ then the name followed by ; so it looks like @ Lex ; with no spaces
I ❤️ Nators
I drive a Mazda
 Old 03-25-2014, 08:57 AM   #11
mikey32235's Avatar
got it, thanks just bought the tune, waiting to be contacted now!
 Old 03-25-2014, 09:01 AM   #12
TheFlash's Avatar
Awesome, congratulations! @Lex; is the man and will get onto it quick to ensure that you are running a safe tune. Be sure to post a comparison of the tunes when all is said and done.
Should be a 400hp car with ease.
I ❤️ Nators
I drive a Mazda
Last edited by TheFlash; 03-25-2014 at 09:01 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to TheFlash For This Useful Post:
Lex (03-25-2014)
 Old 03-25-2014, 09:09 AM   #13
mikey32235's Avatar
i definitely will! looking forward to this, lets hope i don't get pulled over doing any WOTS lol
 Old 03-25-2014, 09:13 AM   #14
This will be fun! It's nice to have the parts in place to make some nice power safely.
 Old 03-25-2014, 09:16 AM   #15
mikey32235's Avatar
woo!
@Lex; contact me if possible
 Old 03-25-2014, 09:25 AM   #16
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Lex will get you straightened out. That motor is floating lots of air, you'll make nice power once he's done with you.
2012 Velocity Red Mica
The Following User Says Thank You to Dimenus For This Useful Post:
Lex (03-25-2014)
 Old 03-25-2014, 09:32 AM   #17
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
woo!
thanks!
Generally not a good idea to publicly post your phone number on line, ever.
 Old 03-25-2014, 09:34 AM   #18
mikey32235's Avatar
removed lol. thought it was pm.
 Old 03-25-2014, 09:48 AM   #19
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Where are all these 350 HP K04 cars hiding?
340hp / 371tq
The Following 5 Users Say Thank You to TiGraySpeed6 For This Useful Post:
biggman026 (04-04-2014), Cheapspeed (03-25-2014), DSIT995 (03-25-2014), Easter Bunny (03-27-2014), memin (03-26-2014)
 Old 03-25-2014, 11:06 AM   #20
mikey32235's Avatar
let the tuning begin
 Old 03-25-2014, 11:12 AM   #21
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Especially on MSF lol
Sent from my Nexus 5 using Tapatalk 2
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
The Following User Says Thank You to Status Update For This Useful Post:
 Old 03-25-2014, 11:17 AM   #22
DSIT995's Avatar
Posts: 1,768   (View Stats)
Imho, your base #'s seem pretty average and not low. Leaning out the AFR's and working on you timing curve will help.. @Lex; has got ya covered, he knows his chit
I haven't done any tuning recently but when I stopped in the fall I was running a 25psi reverse taper and ~15* of timing @ RL and I was in the mid 360's.. We have very similar mods just to give you perspective
99 Miata NB - Stock for now
 Old 03-25-2014, 11:27 AM   #23
mikey32235's Avatar
thanks for the info, well see what happens when tuning is complete
 Old 03-25-2014, 11:41 AM   #24
jdspeed3's Avatar
Posts: 966   (View Stats)
jdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the worldjdspeed3 is the leader of the world
Hey, I just looked at your logs. It looks similar to mine but never dipped all the way to 9.5 in terms of AFR. I'm running a BNR too and tuned by one of the e - tuners here. Looks like we're targeting pretty much the same load 2.7+ and I'm seeing the same AFRs at those load but more around 9.99-10.11. I noticed this once my tune started targeting greater than 2.5 load.
2011 Black Mica Mazdaspeed3
Autotech Internals//BNR S3//JBR 3' Intake//Cobb EBCS//3 Bar w/ PnP Harness//UR-CS TBE//CPe RMM//CXRacing FMIC//TurboXS BPV//NGK Iridium IX
BNR S3 numbers coming soon
277 WHP/327 WTQ (93) Moore 2013
jdspeed3 is offline   Reply With Quote
 Old 03-25-2014, 12:20 PM   #25
mikey32235's Avatar
sometimes my af dips down to 9 flat… i think thats the lowest the ap can log, so it may even be going lower who knows. it isn't the first time I've been told a lot of these things and from many different people/tuners of course except the one who tuned it. well see what the turnout is after lex is done with it
 Old 03-25-2014, 06:35 PM   #26
TheFlash's Avatar
Ummm right here
I ❤️ Nators
I drive a Mazda
 Old 03-25-2014, 08:41 PM   #27
mikey32235's Avatar
pulled into the garage not too long ago, got underneath the car to empty catch can and saw some wet oily spots under the motor.. got a closer look and found this
now my catch can was pretty full…. maybe over full… don't know what this means, first time I'm seeing this, definitely wasn't like this before. thoughts? its late over here so I'm going to work at it in the morning and see exactly where its leaking from, gonna let it run
 Old 03-25-2014, 09:14 PM   #28
mikey32235's Avatar
also i must ad that before i pulled into the garage and emptied catch can, i did two WOT logs to send over to @Lex; turbo pulled hard, didn't hear any whining… assuming its a loose line but i will see what happens when i have the car up tomorrow.
 Old 03-26-2014, 12:01 AM   #29
That looks like the oil drain tube is leaking either at the top or top and bottom. There are two gaskets there that should have been replaced. If they were not it's a good idea to have them replaced.
pwdunmore (03-26-2014), TheFlash (03-26-2014)
 Old 03-26-2014, 05:18 AM   #30
mikey32235's Avatar
I replaced them, Mabye just not tight enough, gonna check in about an hour
Sent from my SM-N900W8 using Tapatalk
 Old 03-26-2014, 05:34 AM   #31
pwdunmore's Avatar
Doesn't look to serious on ther surface, as Lex said, it looks like the oil return line is leaking because the gasket is either pooched or it was never replaced and they just tightened down the tube when they installed it.
If you want help let me know because I can come by and get manifold off you and help with this at the same time. Just go get some new gaskets and we can tackle this. Might get a little messy from the oil but I it's not a big job. You can probably solo it easy enough too.
My car thread:
 Old 03-26-2014, 05:35 AM   #32
Snotrocket's Avatar
Posts: 900   (View Stats)
Did you gap your oil?
Haha remember this?
Good times. Donate And try not to get flamed to hard around here, these guys are relentless.
Mr Wilson likes this.
2010 MS3 Black
395whp/386wtq
 Old 03-26-2014, 06:48 AM   #33
mikey32235's Avatar
lol funny…
got under the car today, couldn't get myself comfortable with doing the work on the floor under the car…
going to pass by my old shop and see if my tech can look at it to see where its coming from. i let the car run and i was under there with my light but i couldn't see any leaks. I'm assuming it will only start leaking when there is pressure from the turbo.
 Old 03-26-2014, 06:54 AM   #34
Snotrocket's Avatar
Pressure to the turbo? What kind of pressure are you referring?
2010 MS3 Black
395whp/386wtq
 Old 03-26-2014, 07:09 AM   #35
mikey32235's Avatar
i mean when i boost, thats when it may leak. i could be wrong I'm just guessing.
 Old 03-26-2014, 07:15 AM   #36
Snotrocket's Avatar
Do yourself a favour and read like I have told you many times before. . The oil drain tube is returning your oil to your reservoir. When your car is running oil is draining. So yes you will see it.
2010 MS3 Black
395whp/386wtq
 Old 03-26-2014, 07:57 AM   #37
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
Oh Mikey you have made the Jump to the big Ocean.... Just so we clear things up you were offered help on TM3 and proceeded to cast it aside.
In true MSF fashion.... DONATE, POST NEWDS OF HOT GF, OR GTFO
Snotrocket and cymen like this.
MarineMazda is offline   Reply With Quote
The Following 4 Users Say Thank You to MarineMazda For This Useful Post:
cymen (03-26-2014), Easter Bunny (03-27-2014), pwdunmore (03-26-2014), Snotrocket (03-26-2014)
 Old 03-26-2014, 06:33 PM   #38
mikey32235's Avatar
hello all! just an update… thankfully it was nothing major, just one of the crush copper o rings needed to be replaced on the line ontop of the turbo. car is good now!
@Lex;
 Old 03-26-2014, 06:40 PM   #39
TheFlash's Avatar
Good to hear man. I love to see 400hp speeds. I excited to see the outcome. Yea, go ahead and drop that $25 for VIP. The more you are willing to give to the community the more it is willing to give back.
I ❤️ Nators
I drive a Mazda
 Old 03-27-2014, 12:21 PM   #40
mikey32235's Avatar
getting a few things done in the next few days…
summer tires/rims put on, 255/40R17-xxr's
prosport gauges installed boost/oiltemp/oil press
injection light/low level light relocated in dash for a clean look
password JDM bumper straps (if i could avoid it, i would, tired of the bumper popping out lol)
fenders rolled/pulled on monday cause this setup is wide as fuck!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s3-motor-build-167164/
mikey32235's ride thread - Page 26 This thread Refback 03-29-2014 09:45 AM
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
MZR Motor Build Kits EdgeAutosport.com EdgeAutosport.com 57 09-29-2017 01:47 PM
What does a motor build consist of? Speedster13 2010 MS3 - Engine, Transmission & Driveline 7 02-04-2014 10:36 AM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
Page generated in 0.57784 seconds with 32 queries
