 Old 03-27-2016, 09:27 AM   #1
btld_ls1's Avatar
Posts: 68   (View Stats)
btld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to all
Default BNR S3 STOCK EBCS HELP
Running BNR S3 v2 wastegate has 1 port and running stock EBCSt. Right now I have it running from the compressor to a T and then from the T to the TIP and then the other side of the T to the Wastegate with a .039 nitrous jet in the line. I was seeing about 13# on the gate only but now only seeing about 12# @ 30% WGDC. Should I try a smaller restrictor or should I be looking in another direction?
2006 MazdaSpeed 6 - Megan lowering springs, 3" catless DP, 3" dumped exhaust, BNR S3, ITV-22, Corksport TIP, SRI, Autotech internals, RMM, ported Intake, TIG, EGR delete, 50/50 E85
btld_ls1 is offline   Reply With Quote
 Old 03-27-2016, 09:59 AM   #2
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Another direction.
3 port
The line up:
Page generated in 0.22611 seconds with 21 queries
