Like Tree47Likes
 Old 07-06-2012, 06:23 PM   #121
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
where are you going to mount the ecu?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 07-06-2012, 07:20 PM   #122
Ziggo's Avatar
Posts: 3,843   (View Stats)
I am mostly OK with where it is now. Only thing I might change is to add some kind of a shim to stand it off the fuse box better to get better airflow over the heatsink on the bottom.
Ask Me About My:
Boosted Beluga (07-06-2012)
 Old 07-07-2012, 08:34 AM   #123
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
That's a funny looking ECU mounting. You would be able to free up the harness enough that the ECU isn't all cock-eyed. What would be sweet is if a company made an ECU harness extender so we could put that bitch wherever we wanted. It would be $$$$ though.
2007 CTS-V - Trying to sell
rfinkle2 (08-12-2012)
 Old 07-07-2012, 08:39 AM   #124
Have you had a chance to quantify how much the larger intake has helped k n terms of airflow and power?
Ziggo (07-07-2012)
 Old 07-07-2012, 08:48 AM   #125
bmylez's Avatar
Groans: 31
If I had to guess...over 9000.
 Old 07-07-2012, 09:36 AM   #126
Ziggo's Avatar
Not yet, had to turn a couple MAFCAL revisions first, then have to evaluate the effects on WGDC. I dropped it by 10 across the board to start with, but need to make sure I am spike free. Butt Dyno says the turbo spools even earlier now, which at this point is just stupid. I'll have some information up in the next couple days. Unfortunately the HD on my tuning laptop died, so the only comparisons I will be able to make are to stuff that was uploaded here.
Ask Me About My:
Boosted Beluga (07-07-2012), Lex (07-07-2012), wolly6973 (07-07-2012)
 Old 07-07-2012, 01:10 PM   #127
Ziggo's Avatar
@Lex @jbarone
So I the fueling isn't nearly as stable as it was on the CAI, but I have not gone in depth on the MAFCAL either, this is just 2 global multiplier revisions so I may be able to dial it in with a Cell by Cell MAFCAL. Could also be an indicator of needing an airflow straightener in front of the MAF, but its too early to say for sure.
Airflow is pretty much identical to my last posted log with the CAI, but the ambient temperature was 20* lower on the CAI log so I can say with certainty that this will increase airflow significantly if compared at an equal ambient temperature. Note* to obtain actual absolute massflow you need to multiply the number in the Logs by .775 to correct for scaling for my e85 mixture. Both logs are using the same e85 mix, and thus the same correction factor applies to both.
JBR WP Log: http://www.mazdaspeedforum.org/forum/foru...1&d=1341687489
Last CAI Log: http://www.mazdaspeedforum.org/forum/foru..._4th_60112.csv
Virtual dyno results are not really comparable since they were taken on different
stretches of road, but attached it for reference anyway. Red is JBR WP, blue MSCAI
Ask Me About My:
atvfreek (07-07-2012), JBR (07-07-2012), wolly6973 (07-07-2012)
 Old 07-07-2012, 02:46 PM   #128
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
Groaned at 20 Times in 11 Posts
so you have less hp/trq with JBR intake?
dan7225 is offline   Reply With Quote
 Old 07-07-2012, 03:01 PM   #129
Ziggo's Avatar
Doubtful, back to back logs of the intakes on the same stretch of road would be the only way o directly compare power.
Ask Me About My:
 Old 07-07-2012, 03:07 PM   #130
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Changed the intake situation around a little bit. JBR WP intake installed. Should prevent those pesky water on the MAF issues I had, and give me some headroom on the MAF sensor , I was exceeding 4.9V before. This should drop it considerably. Rescaled, 4.92v is now 662g/s, before it was 379g/s so I think I have sufficient headroom.
I think its time for a slimmer bat and HTP tray
put ECU back where is was and still have room. IIRC a different group battery will fit in their tray without going to a "slim" bat and you gain 2" of space....
ziggo do you think that would be enough space?
I want a 3 or 3.25 intake and am making my plans. I like the JBR 1 piece idea but think some straighteners would be a +
looking forward to your results and to see if you stabilize your AF curve.
 Old 07-07-2012, 03:10 PM   #131
Ziggo's Avatar
I would put the battery in the trunk first. Not that the HTP isn't a decent piece, just that if I am going to make space, I REALLY want to make space, and shifting a few pounds to the rear wouldn't hurt either.
Ask Me About My:
RobT2009 (10-13-2012)
 Old 07-07-2012, 03:17 PM   #132
Trail of Fail
Dano's Avatar
yeah well I haul stuff in my car all the time w seats down, so bat in hatch is not an option for me at this point.
I don't see needing any more than 2 extra inches....lol.... that's what she said anyway
atvfreek (07-07-2012), Pointless (11-19-2012), wolly6973 (07-07-2012)
 Old 07-07-2012, 09:53 PM   #133
@Dano now I see why you're eager to see my 3" results. I will be doing some back to back testing this coming week.
@Ziggo thanks for the info. The earlier spool alone must be very nice.
Dano (07-07-2012), m249saw (07-08-2012)
 Old 07-07-2012, 10:56 PM   #134
Trail of Fail
Dano's Avatar
Yes. Get off ur ass man!!
Tappin
 Old 08-01-2012, 12:54 AM   #135
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Neutral  +1 score
Subd
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 08-01-2012, 05:02 AM   #136
atvfreek's Avatar
Posts: 7,787   (View Stats)
Lex, did you end up getting back to back test results on intakes? I know I will need an upgrade soon. Even with the CS intake, I have 20+psi on the bnr at 3200rpms. But I'm looking more for top end gains.
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 08-01-2012, 09:58 AM   #137
Freekn tappin
Here is my summary of findings:
1. Go with a 3" or larger but go all the way to the turbo.
2. Use an AEM dryflow filter. It outflows the cotton gauze filters.
Over the SRI alone that should give you 10-20 g/s better airflow up top - it lowers the pressure ratio on the turbo.
ESB Jiu JItsu likes this.
The Following 11 Users Say Thank You to Lex For This Useful Post:
atvfreek (08-01-2012), Boosted Beluga (08-01-2012), Boost_creep (08-01-2012), breakfstincluded (08-01-2012), Dano (08-01-2012), Dmurray06 (12-01-2012), Easter Bunny (08-01-2012), m249saw (08-01-2012), Pointless (11-19-2012), rfinkle2 (08-12-2012), wolly6973 (08-01-2012)
 Old 08-01-2012, 12:07 PM   #138
Groans: 50
I found that using the the specture filter gained me around 5g/s over the aem. I'm running a cai and am on stock turbo
08 Mazdaspeed 3
 Old 08-01-2012, 12:56 PM   #139
Trail of Fail
Dano's Avatar
could that 5gs be attributed to a brand new clean specture vs a dirty AEM
 Old 08-01-2012, 01:19 PM   #140
Groans: 50
You would think but both of them were brand new.
08 Mazdaspeed 3
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
atvfreek (08-01-2012), Dano (08-01-2012)
 Old 08-01-2012, 01:57 PM   #141
I will be trying something that "should" be better than AEM as well - we will see. With the OEM turbo its easy to see the difference since the WG is pegged but with a BNR you are not as boost limited unless you're running it up against its limits as well.
In any case you will at least see a reduction in WGDC if you're not pegging it already in which case you will see an increase in boost, airflow, and spool.
atvfreek (08-01-2012), Boosted Beluga (08-01-2012), Easter Bunny (08-01-2012), wolly6973 (08-01-2012)
 Old 08-01-2012, 02:05 PM   #142
Groans: 50
Everything was the same except airflow. But its so small of a difference I doubt one will prefer one over the other.
08 Mazdaspeed 3
 Old 08-01-2012, 05:29 PM   #143
Trail of Fail
Dano's Avatar
yeah! lex is official!
hey BTW what is your take on the Amsoil filters? are they cotton weave? Their surface area appears to trump all others but I don't know if they flow more for sure.
 Old 08-10-2012, 10:26 PM   #144
Ziggo's Avatar
Trouble is brewing...
skeurton likes this.
Ask Me About My:
The Following 7 Users Say Thank You to Ziggo For This Useful Post:
802MS3 (08-11-2012), atvfreek (08-11-2012), BigjohnB20 (08-11-2012), Boosted Beluga (08-11-2012), cld12pk2go (08-11-2012), rfinkle2 (08-12-2012), skeurton (08-10-2012)
 Old 08-10-2012, 10:28 PM   #145
Trail of Fail
Dano's Avatar
yesssssss, it tis....
 Old 08-11-2012, 07:17 AM   #146
Ziggo's Avatar
@djuosnteisn LOGS!,
We had a freak cold snap, and it was only 78* at 7am this morning. Note my MAF is scaled 22.5% for my E85 mixture so while I peak a 470g/s in the logs, its actually only 369g/s (49lb/min).. which should be plenty for 400whp.. go go beaner turbo.
Seems to be working great. First log is just letting it pop on and drag me rich to verify its functional.
Second and Third logs are with closed loop enabled, but no MAF adjustments. I am going to need to soften the turn-on somehow, though in 2 stroke with a minimum pulsewidth of 1ms it has some surge. Calculations got me close to my desired maximum DI IDC of 80%, but there is a bit of lag in the system so I need to turn it on a bit earlier, so an earlier softer turn on seems like a good idea. Then its time to adjust the MAF curve as needed.
Ask Me About My:
The Following 6 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (08-11-2012), Boosted Beluga (08-11-2012), Caligula (08-11-2012), Dano (08-11-2012), rfinkle2 (11-30-2012), Tomas (08-11-2012)
 Old 08-11-2012, 07:28 AM   #147
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Are your cruising BATs always about 30 degress above IAT?
Kinda high no?
Ziggo (08-11-2012)
 Old 08-11-2012, 10:00 AM   #148
Ziggo's Avatar
If you are referring to log 2 it was a very short roll in from siting for 20 minutes. I had a failed flash and had to recover and was inspecting all the lines.
Zigatapatalka
Ask Me About My:
 Old 08-11-2012, 10:17 AM   #149
Caligula's Avatar
Groans: 185
This makes me want an S3 so bad... sigh but I need new tires soon
 Old 08-11-2012, 10:19 PM   #150
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
how are you liking the swaintech coating on the turbine housing/mani?
'08 CWP MS3 w/ T3 3071r
 Old 08-12-2012, 12:38 PM   #151
Ziggo's Avatar
It has discolored from it's pearly white state, but no cracks or flaking so I am pretty happy.
I don't think there is a measurable benefit in performance spool wise, I was after the the thermal insulative properties to protect other things in the engine bay since all the heat shields are gone. Since it has always been on there I couldn't take before and after measurements, but nothing has in the area has melted and plastics appear to be holding up well, not showing any signs of embrittlement.
Zigatapatalka
Ask Me About My:
The Following 5 Users Say Thank You to Ziggo For This Useful Post:
802MS3 (08-12-2012), atvfreek (08-12-2012), breakfstincluded (11-29-2012), rfinkle2 (08-12-2012), wolly6973 (08-12-2012)
 Old 08-16-2012, 08:52 PM   #152
Ziggo's Avatar
My maf curve is so retarded. Scale up 67% for JBR intake, then another 22.5% for 5/7 mix E85, then subtract 115 from 4.1V and up for AIC1, curve reduction between 3.6 and 3.8 for start of 5th port and flatline between 3.8 and 4.1 as the 5th port becomes fully operational
Ask Me About My:
The Following 10 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (12-01-2012), Boosted Beluga (08-16-2012), breakfstincluded (11-29-2012), BrianB6 (08-17-2012), cld12pk2go (08-16-2012), Micha (01-07-2013), Pointless (11-19-2012), rfinkle2 (11-30-2012), silvapain (08-17-2012), wolly6973 (11-28-2012)
 Old 11-28-2012, 10:29 AM   #153
Silverspec06's Avatar
Posts: 244   (View Stats)
Silverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud of
Neutral  +1 score
Here is the easy way to get the EM bolt off under neath it what i did was put a ratcheting with the box end on the nut open away then I slung a 17 mm box end over the open end of the 14 mm put it up between the manifold between the 2 pipes on the passenger side. pull up on it broke loose with no pb blaster and minimal effort.
There are no problems that the liberal application of BOOST can't solve.
INSTALLED: COBB SRI//TiP||Turbosmart 50/50 BPV/BOV|| COBB AP||CNT RACING DP||Corksport 3" CBE||JBR FLAPS|| CP-E stage 2 Rmm|| Autotech CDFP Stage2 tune ||Godspeed FMIC|| Hawk HPS Pads|| Sure SSP|| NGK Step COLDER||
Intalling soon: CPE Triple Gauge pod|| Prosport Evo Gauges|| Ebay OCC With baffling mod.
Up next: EBC Rotors|| BNR S3 Turbah|| JBR balance shaft delete|| JBR 88a Pmm 80a TMM
Silverspec06 is offline   Reply With Quote
The Following User Says Thank You to Silverspec06 For This Useful Post:
rfinkle2 (03-11-2013)
 Old 11-29-2012, 01:32 PM   #154
Caligula's Avatar
Groans: 185
Zigatapatalka
Is that the plasma sprayed ceramic stuff?
 Old 12-01-2012, 02:49 PM   #155
Domino81's Avatar
Posts: 5,081   (View Stats)
lawlz at freak cold snap being 78 degrees. I won't see 78 until May, April if I'm lucky.
atvfreek likes this.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 02-24-2013, 08:33 AM   #156
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
plenty of great info in this thread. thanks for write up @ziggo
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 03-10-2013, 05:57 PM   #157
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Reused coolant line, we didn't have the new fitting. Necessity is a mother.
Sent from my frontal cortex.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
DSIT995 (03-10-2013), LatinKraze (03-10-2013)
 Old 03-10-2013, 11:31 PM   #158
Ziggo's Avatar
That's the coolant feed line, you have to bend it a bit and reuse. The coolant drain is the one I fabbed up a new line for.
Ask Me About My:
 Old 03-11-2013, 05:10 AM   #159
kritz's Avatar
Groans: 95
Reused both as is,
 Old 09-06-2013, 07:32 AM   #160
1sicms3's Avatar
Posts: 18   (View Stats)
1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough
Default BNR S3 Swap How To
thank you for this thread, im goin to be installing a bnr next week
1sicms3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s3-swap-how-88946/
Turbolader ausbauen / tauschen This thread Refback 06-09-2015 12:25 PM
Eine Frage an die Turbo Spezialisten - leichtes Pfeifen unter Last This thread Refback 12-31-2014 04:56 AM
TURBO Ein-Ausbau, Tips bzw. Anleitung This thread Refback 10-21-2014 02:11 PM
Turbolader defekt - Seite 2 This thread Refback 07-23-2014 03:20 AM
How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-02-2014 04:35 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades This thread Refback 07-08-2013 11:01 AM
Bnr s3 upgrade help This thread Pingback 06-25-2013 12:36 AM
Whats New/General Speed 6 Discussion - Page 236 This thread Refback 06-08-2013 05:23 PM
Beaner time! - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-10-2013 04:37 PM
BNR Stage 3 Turbo Upgrade - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-24-2013 05:04 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades - Seite 5 This thread Refback 02-20-2013 03:00 AM
Beaner time! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-26-2013 08:23 PM
mikey32235 everything is broken - Page 11 This thread Refback 12-01-2012 07:42 AM
• View topic - KO4E Turbo Upgrade This thread Refback 11-28-2012 11:27 PM
[ALLE] BNR Turbo Upgrades - Seite 5 - Turboaufladung - mazda-mps.de This thread Refback 11-13-2012 10:41 PM
[ALLE] BNR Turbo Upgrades - Turboaufladung - mazda-mps.de This thread Refback 11-03-2012 11:53 AM
BNR Stage 3 Turbo Upgrade - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-12-2012 10:04 AM
INTERCEPTOR EVOLUTION!!! This thread Refback 11-24-2011 02:15 PM
Fs-ZE Swap Focus MSP - ECU Computer Tuning 4 09-11-2014 08:43 AM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.60944 seconds with 35 queries
