![]() | | #161 | ![]() |
![]() Join Date: Apr 2013 Location: fredericksburg,va
Rep Power: 0 ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score ![]()
![]() | | #162 | ![]() |
| Not Ranked : 0 score im going with bnr stage 1, would i have to do a retune? |
![]() | | #163 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Why? No. Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
![]() | | #164 | ![]() |
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score Just incase anyone needed some new nuts for the Turbo to Mani or Turbo to Downpipe, here is the part #: JE1040355, $6.12 EACH at my dealer! Some spaces are definitely a PITA with the stock downpipe, but doable. Wasn't able to get my turbo bracket off from the 2 bolts on the block, those suckers were on their GOOD! Even heated, PB'd, LW, them and nothing. Thank you for this write up as well Ziggo, helped a lot. Might possible add a 22mm (7/8) Oxygen Sensor Socket to required tools to remove the top o2 sensor on the downpipe to get the stock heatshield off to reach the downpipe nuts. All nuts for the mani, and downpipe are definitely all reachable from the top, if anyone is wandering. 1/2" breaker bar made life easy for all the nuts. Last edited by He Hate Me; 09-10-2013 at 01:39 PM. |
| The Following User Says Thank You to He Hate Me For This Useful Post: | BoostedRide (02-20-2015) |
![]() | | #165 | ![]() |
Groans: 255
The 15mm copper colored exhaust nuts from edgeauto are like a dollar each and are much beefier ...
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #166 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score And because they're copper they don't seize up like the OE ones do.
__________________ |
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #167 | ![]() |
Groans: 255
| Not Ranked : 0 score True but they require a bit more effort to install due to the beefier oval design. On certain downpipes, only the OEM nuts will work where the downpipe is really close to the stud.
| The Following User Says Thank You to himurax13 For This Useful Post: | silvapain (09-10-2013) |
![]() | | #168 | ![]() |
| The Following 4 Users Say Thank You to He Hate Me For This Useful Post: |
![]() | | #169 | ![]() |
| Not Ranked : 0 score How many of you have installed the latest BNR with the 2 port WG actuator? Have you had issues increasing boost and when you do, it spikes in the upper RPMs?
![]() | | #170 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score THAT doesn't sound good.....
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
![]() | | #171 | ![]() |
| Not Ranked : 0 score I've tuned a few of the new ones now and I am seeing a trend in how boost control works. Just want to get more data.
| The Following User Says Thank You to Lex For This Useful Post: | Nliiitend1 (09-10-2013) |
![]() | | #172 | ![]() |
![]() Join Date: Feb 2009 Location: Plantation,Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 17 Times in 4 Posts
| Not Ranked : 0 score I think you and I were having this issue at the beginning it has since gotten better.. but it still happens with upper gears like 5th or 6th gear it spike's.Boost guage showing 23-24 psi ap showing 22.7 but its only for a split sec and then drops back to 18-19. |
![]() | | #173 | ![]() |
| Not Ranked : 0 score Do you have a 3 bar map sensor? Of not then that is the stock map sensor being maxed out at 22.7psi.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #174 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Im confused. So it used to only have one port? Mine has 2, so for now hooked it up like stock as using stock EBCS. When I install my 3 port I was going to use the bottom for the EBCS and the top for my boost only line to Synapse rather than Ting into EBCS line as it is now. Will that work?
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
![]() | | #175 | ![]() |
Groans: 255
![]() | | #176 | ![]() |
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB | |
![]() | | #177 | ![]() |
| Not Ranked : 0 score You can run it exactly like OEM but the restriction in the top port is not big enough to give you enough boost from what I've seen. IMO the new WG actuator is a big step backwards for these turbos. All the new ones have been a much bigger pain to the tune than the old single port WG actuators.
| The Following User Says Thank You to Lex For This Useful Post: | LatinKraze (01-04-2014) |
![]() | | #178 | ![]() |
| Not Ranked : 0 score Not doubting you, but doesnt really make sense if the smaller port is plugged...I just want to be able to drive my car to work in the morning...slowly.
![]() | | #179 | ![]() |
![]() | | #180 | ![]() |
![]() Join Date: Jan 2012 Location: Long Beach,Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score I just got one of the bnr turbos with the dual port wastegate. is there anything I can do before I install it to make it easier to tune? I have a cobb ebcs I was going to install with it. |
![]() | | #181 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
![]() | | #182 | ![]() |
![]() Join Date: Jul 2010 Location: Finland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score I installed a 1 mm welding tip as restrictor in pressure line to WG as there does not seem to be a restrictor there unlike in K04 (I'm reusing stock EBCS). One thing to check: in my kit the copper crush washers for oil feed banjo bolt were too small.
__________________ 3 MPS '07, BNR S3, HTP 3", ETS TMIC, Cobb catted DP, PTP HPFP internals, Bosch 3 bar MAP w/ PNP Harness, RMM, KW Variant 3, DO water/meth, Michelin Pilot Sport Cup 2 235/40-18, OZ Alleggerita, self tuned with VersaTuner E30, awaiting inspiration to build bottom end due to major blow-by @ 100 kmiles / 165 kkm |
![]() | | #183 | ![]() |
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
| Not Ranked : 0 score With my install the banjo supplied for the coolant line was damaged. Caused a leak whenever I fed coolant through the system. Don't know if I damaged it or it was damaged but check both faces of the banjo for imperfections. I reused the coolant hard line, custom bent lol, until I found a replacement banjo.
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
![]() | | #184 | ![]() |
| Not Ranked : 0 score The banjo outlet supplied with the kit was of smaller diameter than EGR inlet where this coolant return goes. So my 6AN line was loose on banjo, causing a coolant leak. Double hose clamp hopefully did the trick in my case. It seems surprisingly difficult to get these small part kits right
![]() | | #185 | ![]() |
| Not Ranked : 0 score Only when quality control starts taking a back seat
![]() | | #186 | ![]() |
| Not Ranked : 0 score This Ziggo's how-to helped me a lot! I wish I can put here some my experiences without having to write my own. As I continued to run stock parts (downpipe, exhaust manifold, EBCS, TIP) my case was somewhat different. Hope this info may be of some use to others. - I removed wipers and cowl to get some more room - I did not remove oxygen sensor but cut the DP heat shield off -> major PITA, I don't recommend it - exhaust manifold was not removed - all EM to turbo nuts and studs can be removed from top, same applies for all turbo to DP nuts, studs can be removed later when turbo is on the work bench - I did not remove turbo brace, just took one bolt off to free turbo - I removed EGR, one EM manifold stud closest to EGR and heat shield of brake fluid -> turbo was removed from side - I reused oil feed banjo bolt crush washers as new did not fit - I reused both oil return gaskets (BNR kit had gasket for oil line to block) - some glue to hold bolts is your friend when installing oil return to turbo - I reused all studs and bolts - stock TIP was not possible to get back on without cutting rubber gasket a bit
![]() | | #187 | ![]() |
![]() Join Date: Aug 2013 Location: PA
Rep Power: 0 ![]() ![]() ![]() Thanks: 63
| Not Ranked : 0 score Does anyone have the Mazda part#s for the EM to turbo & turbo to DP gaskets? How many of these nuts should I order? Last edited by BoostedRide; 02-20-2015 at 09:20 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #188 | ![]() |
| The Following User Says Thank You to Lex2007 For This Useful Post: | BoostedRide (02-20-2015) |
![]() | | #189 | ![]() |
| Not Ranked : 0 score | |
![]() | | #190 | ![]() |
![]() | | #191 | ![]() |
![]() Join Date: Aug 2013 Location: North of Pittsburgh, PA
Rep Power: 0 ![]() ![]() Thanks: 54
| Not Ranked : 0 score From what I've seen, there seems to be a little confusion so someone correct me if I'm wrong but I believe you want L3K9-13-710 and L3F2-13-490. Onlinemazdaparts has good (relatively) prices.
__________________ -Tim 2007 Cosmic Blue MS3 Bilstein B8 Sports... That's it |
| The Following User Says Thank You to some call me...Tim For This Useful Post: | BoostedRide (02-20-2015) |
![]() | | #192 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score DP gasket - Mazda OEM Downpipe Gasket (Upper) MS3 MS6 Turbo to EM gasket - Mazda OEM Manifold Turbo Gasket MS3 MS6 Studs incase some snap - 10mm (1.5 pitch) Stud Locking nuts - 10mm (1.5 pitch) Nut Locking Head |
| The Following 5 Users Say Thank You to neganox For This Useful Post: | Darthspeed3 (03-02-2015), G1sdaname (05-22-2015), ItsNox (02-20-2015), Micha (11-11-2015), some call me...Tim (02-20-2015) |
![]() | | #193 | ![]() |
![]() Join Date: Nov 2012 Location: College Park, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
| Not Ranked : 0 score Great write-up to the op!! I'll definitely use it this spring
__________________ Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI. |
![]() | | #194 | ![]() |
![]() Join Date: Jul 2013 Location: Spokane, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 94
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Do you need to run a oil restriction bolt on a bnr s3 ? Sent from my SAMSUNG-SGH-I337 using Tapatalk
__________________ 2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials. |
![]() | | #195 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
No.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 | |
![]() | | #196 | ![]() |
| Not Ranked : 0 score Oil restriction bolts are a band-aid for a smokey turbo. No. |
![]() | | #197 | ![]() |
| Not Ranked : 0 score Okay. Thank you. Just got one for my cx 7. Can't wait to get it Sent from my SAMSUNG-SGH-I337 using Tapatalk
![]() | | #198 | ![]() |
| Not Ranked : 0 score Ziggo, so its been a few years since you installed the BNR S3. How has it treated you? |
![]() | | #199 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
(Thread Starter) | Not Ranked : 0 score Still running strong. I had the issue with the housing bolts backing out that the early units did, but other than that I have had no issues. Drive it every day almost on my 5/7 E85 mix map.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #200 | ![]() |
| Not Ranked : 0 score Awesome! How many miles if you don't mind me asking? Few more questions: -Not sure if you have emissions testing in Tx, but we do here in Maryland and my concern is whether I would pass emissions. There is no visual, they just plug into OBDII port. -Did the OEM clutch withstand the added torque? -Whats your MPG, out of curiosity? (I have a long commute.) - Any PCV issues with the additional boost? Thanks for your post and for sharing your experience with us. |
| Fs-ZE Swap | Focus | MSP - ECU Computer Tuning | 4 | 09-11-2014 08:43 AM |
| HID swap | TXspeed3 | MazdaSpeed 3/6 - Appearance | 19 | 06-28-2009 05:04 PM |
