  • 1 Post By Lex
 Old 06-11-2013, 02:54 PM   #1
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
Default BNR S3 TURBO.
Not quite a big turbo obviously but a bigger turbo then the stock snail. Scope out the pic. Also in the pic evo x rims and a cnt catless downpipe.... i still need a ebc and im planning on only running 20psi and keeping the cobb intake/inet and stock maf and map for now and still running e85
File Type: jpg 946272_10200477827321219_1849859254_n.jpg (38.8 KB, 173 views)
boostdmazda3 is offline   Reply With Quote
The Following 5 Users Say Thank You to boostdmazda3 For This Useful Post:
atvfreek (06-11-2013), ckMS3 (06-11-2013), h.h.sk1nny (06-11-2013), LatinKraze (06-11-2013), prototype_x9 (11-07-2014)
 Old 06-11-2013, 03:47 PM   #2
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Cool beans man. I should be getting mine on Thurs. Reverse taper to 25-26 psi and shooting for 400awhp/400awtq. Not too many better turbos for the street
The Following 2 Users Say Thank You to h.h.sk1nny For This Useful Post:
Juyoung (06-11-2013), Little John (06-11-2013)
 Old 06-11-2013, 03:55 PM   #3
LatinKraze's Avatar
Posts: 804   (View Stats)
You're gonna love it! Great choice
2016 CX-5 GT AWD
 Old 06-11-2013, 03:56 PM   #4
i want to make powa! But not at the expense of my motor. People are blowing up with the BNRs at around 380whp at 26psi. I'll be content with just running 21 psi max.
 Old 06-11-2013, 04:58 PM   #5
LatinKraze's Avatar
Got links?
I'm aiming for 24psi.
2016 CX-5 GT AWD
 Old 06-11-2013, 05:08 PM   #6
ricknm's Avatar
Posts: 1,102   (View Stats)
ricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the world
Im sure its not the HP as much as it is the tq. Unless you have seen this on here I dont know that I can believe that. @atvfreek; was running over 400hp on his BNR and still is on his new turbo
BNR s3 w/ some other stuff. Hypnotic tuned.
ricknm is offline   Reply With Quote
The Following User Says Thank You to ricknm For This Useful Post:
 Old 06-11-2013, 05:21 PM   #7
LatinKraze's Avatar
It's my understanding that we aim to stay bellow 400wtq unless fully built.
2016 CX-5 GT AWD
 Old 06-11-2013, 05:28 PM   #8
freek is running meth with his setup i believe. Why is hard to believe people blow up with the beaner? People blow up with the stock turbo....peak tq down low is prob the main reason for this as mentioned.... but yes people on MSF have even posted about there ZZB with the bnr.
 Old 06-11-2013, 05:43 PM   #9
Has a lot to do with the tune. You can target more than 20psi up top with the turbo and still be fine for street applications especially if using the higher octane E85. A sweet spot for the top end is around 23-24psi.
The Following 8 Users Say Thank You to Lex For This Useful Post:
atvfreek (06-11-2013), boostdmazda3 (06-11-2013), breakfstincluded (12-01-2013), ckMS3 (06-11-2013), cshunter (06-11-2013), Gitcherex (12-01-2015), himurax13 (06-11-2013), SpeedRebirth (06-11-2013)
 Old 06-11-2013, 05:45 PM   #10
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Love Evo X rims on the Speed 3s great choice. Also good turbo choice that's the perfect amount of power right there bet you're excited lol
2003 Evo VIII
 Old 06-11-2013, 05:48 PM   #11
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
You could run a Stratified Boost Dial with your stock EBCS instead of going with a 3 port.
Who is doing the install and the tune?
Pickles Tune in progress
Lex (06-11-2013)
 Old 06-11-2013, 05:54 PM   #12
Here we go himurax13 had a zzb with the BNR.
I'm excited and nervous at the same time...the car is fast enough now and reliable. But everyone knows hows the mod bug works.
Last edited by boostdmazda3; 06-11-2013 at 05:54 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to boostdmazda3 For This Useful Post:
4G63 (06-11-2013), ckMS3 (06-11-2013), Roddiy (06-11-2013)
 Old 06-11-2013, 05:55 PM   #13
himurax13's Avatar
Groans: 255
You are mistaken good sir.
I had no ZZB and I was on stock turbo when #4 cylinder lost compression.
It is adviseable to keep the last 5 oil filter and oil receipts. It makes warranty claims go through easier.
The Following 3 Users Say Thank You to himurax13 For This Useful Post:
cshunter (06-11-2013), ItsNox (07-25-2013), Lex (06-11-2013)
 Old 06-11-2013, 05:57 PM   #14
ckMS3's Avatar
Posts: 1,112   (View Stats)
Can't wait to see come race vids once you get this puppy on.
21psi with some healthy timing will still get you in the 360whp range. Not too sure whose been blowing up, as I haven't been on here a lot lately, but I've been 360whp+ with this turbo for over a year now with no problems and it's my dd.
348tq/367whp -21.5 psi
The Following 4 Users Say Thank You to ckMS3 For This Useful Post:
atvfreek (06-11-2013), ItsNox (07-25-2013), LatinKraze (06-11-2013), steelknight7d (06-11-2013)
 Old 06-11-2013, 06:04 PM   #15
Correct, dialing in a nice responsive tune with this is very straight forward
Stratified Boost Dial [BOOST DIAL (0100-0004.1)] - $70.00CAD : Stratified Automotive Controls
 Old 06-11-2013, 06:05 PM   #16
how miles are on your car? Do you have the cpe safe seals? I want to keep my cobb intake/inlet and stock map will that be an issue?
The Following User Says Thank You to boostdmazda3 For This Useful Post:
ckMS3 (06-11-2013)
 Old 06-11-2013, 06:06 PM   #17
With the stock MAP sensor you will be limited to 21-21.5psi. The COBB intake will be fine up to around 23psi.
ckMS3 (06-11-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 06:08 PM   #18
Obviously there will be sushi rolls with the new snail.
The Following 2 Users Say Thank You to boostdmazda3 For This Useful Post:
ckMS3 (06-11-2013), himurax13 (06-11-2013)
 Old 06-11-2013, 06:10 PM   #19
ckMS3's Avatar
Neutral  +1 score
I have 76k on it now and had 56k when I put on the bnr. Yea, you'll be fine that won't be an issue at all. That was exactly my setup when I was on 21psi, of course until upgraded later on. You will still make great power especially with a great tune to go along with it. Are you getting it tuned at church again?
The Following User Says Thank You to ckMS3 For This Useful Post:
 Old 06-11-2013, 06:11 PM   #20
atvfreek's Avatar
Posts: 7,787   (View Stats)
23-24 is definitelty the sweet spot for peak power, as lex mentioned. Going higher will give gains, but they start to get minimal. I use load as a limiter and have it dyno verified for my car quite well. For the most part my car only hits 19-20 up until about 4500, then it ramps up pretty quick toward redline.
21-22 psi will get you 350-360hp no problem on e85, so that is a nice goal in the BNR.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 7 Users Say Thank You to atvfreek For This Useful Post:
boostdmazda3 (06-11-2013), ckMS3 (06-11-2013), cshunter (06-11-2013), himurax13 (06-11-2013), LatinKraze (06-11-2013), Lex (06-11-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 06:14 PM   #21
Is the Full 3 inch Intake worth getting? Obviously it will breathe better but i trust your opinion since you have both setups. In terms of the tune i do trust Church with my car and have had great results...I really dont want to open up that can of worms with E tuners Vs Church. I am open to both but do like that church is just 10 min away.
Roddiy (06-11-2013)
 Old 06-11-2013, 06:30 PM   #22
ckMS3's Avatar
It's definitely worth getting. Of the top of my head pwned gained 7 or 8whp with the Sure 3 inch on the stock turbo at 300whp and those gains will obviously be magnified with a bigger turbo. So the gains will certainly be there.
Here's a vd from my cobb setup vs the jbr whale dong
 Old 06-11-2013, 06:33 PM   #23
20whp with the 3inch holy bitch tits.
 Old 06-11-2013, 06:35 PM   #24
ckMS3's Avatar
It's just VD, but you get the idea. lol
 Old 06-11-2013, 06:35 PM   #25
The other nice thing about the bigger intake is that you can run less boost to get the same amount of flow
It seems you're on the fence so I suggest doing this right the first time. Get a 3" intake, a 3 Bar MAP sensor, and a way to control boost (either Boost Dial or 3 Port). With a good and conservative tune you should be in the 360-380whp range with about the same amount of torque and have fun with the car.
I've seen pretty much every setup combination in terms of turbos, intakes, etc. and this is a winning combination.
BackRoads likes this.
The Following 7 Users Say Thank You to Lex For This Useful Post:
atvfreek (06-11-2013), BackRoads (06-18-2013), boostdmazda3 (06-11-2013), ckMS3 (06-11-2013), cshunter (06-11-2013), Roddiy (06-11-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 06:39 PM   #26
himurax13's Avatar
Groans: 255
If you are still confused OP, this little thread has some decent info.
BNR Stage 3 Checklist.
The Following 4 Users Say Thank You to himurax13 For This Useful Post:
boostdmazda3 (06-11-2013), cshunter (06-11-2013), Lex (06-11-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 06:42 PM   #27
thanks great information this one and ziggos....think i may keep the cobb downpipe to help prevent with any boost creep.
 Old 06-11-2013, 08:45 PM   #28
is it ok to drive the car with out the EBC hooked up while the BNR is in? I wont be boosting of course. Reason is i might put it in a diff day if the turbo takes to long.
 Old 06-11-2013, 09:00 PM   #29
Make sure you have a tube/line from the intake manifold directly the wastegate actuator to run spring pressure.
boostdmazda3 (06-11-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 09:01 PM   #30
If i literally build no boost until the ebc is in it shouldn't be a problem right?
 Old 06-11-2013, 09:03 PM   #31
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
If you're not going balls deep then it doesn't really matter
 Old 06-11-2013, 09:05 PM   #32
Ugh don't leave the wastegate unplugged. It's just asking for fail and it takes 2 minutes to do.
 Old 06-11-2013, 09:06 PM   #33
Thanks i appreciate everyones help with my questions.
 Old 06-11-2013, 09:08 PM   #34
Hmm funny how none of my posts are thanked ... I guess I just wasn't helpful enough ...
atvfreek (06-12-2013), bhamitgeek (06-20-2013), boostdmazda3 (06-11-2013), himurax13 (06-11-2013), ryno077 (06-13-2013), YABBAMZR (06-11-2013)
 Old 06-11-2013, 09:08 PM   #35
fixed lol
 Old 06-11-2013, 09:09 PM   #36
fixed lol
Lol Good luck with the install.
 Old 06-11-2013, 09:13 PM   #37
himurax13's Avatar
Groans: 255
Why would you even consider it? If you are smart and hook up the vacuum lines before the turbo goes in then it is a matter of cutting lines to size and connecting the lines and then plug the adapter into the oem port. 5 minutes tops. Just make sure the lines get hooked up right.
Or you could go the smart route and get the Stratified boost dial instead of a 3 port boost controller and all you have to do is hook up 2 vacuum lines ...
Who is installing it?
Sent via blown passenger side speakers.
Lex (06-11-2013)
 Old 08-11-2013, 03:30 AM   #38
AlaskaTransplant's Avatar
Posts: 53   (View Stats)
AlaskaTransplant is a glorious beacon of lightAlaskaTransplant is a glorious beacon of lightAlaskaTransplant is a glorious beacon of lightAlaskaTransplant is a glorious beacon of lightAlaskaTransplant is a glorious beacon of lightAlaskaTransplant is a glorious beacon of light
Great thread, Going to do this real soon. After WMI is installed. Checking out the checklist too. Ergh.. MOAR PARTS... its okay...
AlaskaTransplant is offline   Reply With Quote
Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] Haltech Automotive News 0 05-03-2013 07:50 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.57180 seconds with 31 queries
