 Old 05-21-2015, 08:42 PM   #1
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Default BNR S3 V2 pre-install questions
Whats up guys,
I am getting ready for two S3 beaner installs, one on my car and one on my brothers. I've been digging through the install threads and I have a question about the coolant return line (the one that feeds back to the egr). In all the threads I've read, including @Ziggo;s and @atvfreek;s threads, they show a return line being made from heater hose, but on the bnr that I've received it comes with what appear to be an oem style coolant return line. At least that is what it appears to be based on trying it out on the turbo in various locations.
Also, in most of the bnr s3 v2 threads I see that the wastegates have two nipples, where as the new on I got has only one like the original bnr s3 turbos had. Any idea what the reason was for this? I imagine it was for ease of tuning, just trying to make sure I wont need to install any restrictor pills or anything like that.
Thanks a lot
09 MGM MS3
 Old 05-21-2015, 08:58 PM   #2
The coolant return line should work like a stock return line, except it should be bent in such a way that it fits around the turbo without modification. If yours does not do this, then you should contact BNR for an appropriately bent line.
The dual nipple WGA was phased out due to what I believe was a large amount of requests by customers for a single port with an unrestricted compressor tap for the ease of 3port boost controller hookup.
Addikted To Boost (05-21-2015), ItsNox (05-23-2015), JgamB (05-22-2015)
 Old 05-21-2015, 09:41 PM   #3
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
I just did this a month ago. The supplied coolant line works (did for me). It will just be turned closer to the wastegate actuator from where you have it. I bought fancy hose after reading the how to's and ended up not using it.
As long as you have a 3 port EBCS you only need the one nipple.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
The Following User Says Thank You to superman For This Useful Post:
Addikted To Boost (05-22-2015)
 Old 05-22-2015, 02:40 PM   #4
Ziggo's Avatar
Posts: 3,843   (View Stats)
You can tee-off the line and use a bleed setup just fine with the one port too. the problem with two ports is the other one gets capped on 3 port setups and that cap has a tendency to fail, which WILL blow your motor without quick reaction and/or a safety device.
Ask Me About My:
Addikted To Boost (05-26-2015), neganox (05-23-2015)
 Old 05-22-2015, 04:50 PM   #5
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
you have it positioned wrong
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
 Old 05-22-2015, 10:14 PM   #6
I'm assuming you're talking about the coolant line? I just had it sitting on there for reference, got both of them installed tonight without too much fail. Thanks for the answer guys.
09 MGM MS3
The Following 3 Users Say Thank You to Addikted To Boost For This Useful Post:
ItsNox (05-23-2015), JgamB (05-22-2015), neganox (05-23-2015)
Koni FSD Install Questions TegRacer324 MazdaSpeed 3/6 - Suspension & Brakes 16 08-18-2011 09:14 PM
A few questions with gauge install JohnMS3 Mazdaspeed3/6 General Discussion 5 02-27-2011 06:39 PM
CPE FMIC Install Questions bykeryder4life MazdaSpeed 3/6 - Turbo Induction 9 02-07-2009 01:16 AM
Meth kit install questions Stan-O MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 01-24-2009 08:21 AM
Page generated in 0.27476 seconds with 24 queries
