 Old 07-29-2011, 04:32 PM   #1
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
Default BNR Stage III install problems!
Fuck this engine.
Can't get the stock pos out....
Trying to remove the manifold, and the 14mm bolt that is underneath the drivers side runners seems to be rounded. The wrench is near impossible to get to stay on, and I can't get a socket on it because of the oil line...
What do?
I thought I didn't have the remove the manifold to get the turbo out but I think I'm wrong...
sigh... end rant
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 07-29-2011, 05:18 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
It's a lot easier if u take it all out.
The Following User Says Thank You to kmac For This Useful Post:
rfinkle2 (07-29-2011)
 Old 07-29-2011, 05:38 PM   #3
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
In before offset wrenches.....
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 07-29-2011, 05:43 PM   #4
glndrums's Avatar
Posts: 153   (View Stats)
glndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant futureglndrums has a brilliant future
take off the little pump lookin thing on the back right corner of the engine. your gonna lose a lil fluid but it gives you a straight shot at those bolts...
also a closed end wrench that rachets would be ideal
2006 Mazdaspeed 6 GT RIP
ZOOM ZOOM KABOOM!!!
glndrums is offline   Reply With Quote
 Old 07-29-2011, 06:24 PM   #5
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
HAHAHAHAHAHAHAHAHA
sorry OP
that single bolt is what lead me to promise i would NEVER do another turbo install ever again.
wanna know what the next step is? cut the stock manifold in half at the flex joint with a sawzall and remove the pass side half. this will give you access to that bolt with an impact gun.
seriously the worst thing i have ever been through on this car.....
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
Realgib3 (07-30-2011)
 Old 07-29-2011, 10:29 PM   #6
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
HAHAHAHAHAHAHAHAHA
sorry OP
for me it was the two trans bolts and transfer case bolts that are behind everything when i did the clutch. BUT i havent done a turbo install yet.
Your post is misleading. Its k04 removal problems. But i think you need to run to sears and get a flex ratchet wrench. I thought thats what people been using, theres some threads around
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 08-03-2011, 05:08 PM   #7
Must Have Teh 10's!
i have 8 different 14mm wrenches purely for the manifold alone........
including the flex one
 Old 07-30-2011, 06:16 AM   #8
zenger's Avatar
Well sorry bout that mislead but if I'm having this much trouble I'm sure putting on won't be pretty. Super I hope that isn't true I really do not want to buy another manifold
Better start looking at aftermarket options though right ?
Just steedspeed ?
2007-Mazdaspeed 6
 Old 07-30-2011, 10:19 AM   #9
mason's Avatar
Posts: 946   (View Stats)
i got my stock manny if you want to buy it.
 Old 07-31-2011, 04:08 PM   #10
zenger's Avatar
I'm not cutting that sucker in half. I'm throwing in the towel, it's rounded, going to button it back up and cut my losses....
2007-Mazdaspeed 6
 Old 07-31-2011, 04:15 PM   #11
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I'll give you $200 for the BNR stage III
07 MS3
The original Genpoo Hater
Monotonous ONE (08-05-2011)
 Old 07-31-2011, 04:18 PM   #12
bewsted's Avatar
Posts: 2,456   (View Stats)
take the manifold off instaed of dropping that subframe support bracket and taking it out that way?
EWG K04...GETSUM!
 Old 07-31-2011, 04:23 PM   #13
zenger's Avatar
Can't get the manifold off that's the bolt that's rounded.
is there another way to get the turbo out without taking the manifold off?
2007-Mazdaspeed 6
 Old 07-31-2011, 04:28 PM   #14
bewsted's Avatar
yes.....take the downpipe off and out....drop that subframe brace (i guess thats what you call it....And it comes right out....And your new turbo should go right in.
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
AJ713 (07-31-2011)
 Old 07-31-2011, 04:41 PM   #15
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
How rounded off is the bolt? if you drop the turbo down to the bottom of the car then hammer a 12pt socket onto the nut you might be able to get it off.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
 Old 07-31-2011, 05:09 PM   #16
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
There are tools specifically designed for rounded bolts...Sears has them...
The Following 4 Users Say Thank You to cld12pk2go For This Useful Post:
Broxer (08-06-2011), Ckmazdaspeed3 (08-09-2011), TexasSpeed3 (08-09-2011), zenger (08-01-2011)
 Old 07-31-2011, 05:20 PM   #17
mason's Avatar
take the frame apart that stops the turbo from comming out. the frame below the turbo.
take it out and boom, turbo is out, new one is in. no need to remove the manny
The Following User Says Thank You to mason For This Useful Post:
zenger (08-01-2011)
 Old 08-03-2011, 04:40 PM   #18
zenger's Avatar
old turbo out manifold off (without cutting) wedged a 6 point socket on it and impacted off.
Lost one of the two bolts for the oil return when putting new turbo in, had to stop fml...
Chimmike likes this.
2007-Mazdaspeed 6
The Following User Says Thank You to zenger For This Useful Post:
Chimmike (08-03-2011)
 Old 08-03-2011, 04:45 PM   #19
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Hey, its progress!
403whp/451ft/lb Dry Shot
 Old 08-03-2011, 04:53 PM   #20
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Yes.
Take p side drive shaft out and turbo support L bracket of. That should be all you need to do to get the turbo out after disconnecting it from manifold and down pipe.
Edit: I could be wrong about having to remove the p side drive shaft to get the turbo out. I can guarantee however you can't get an ATP 3071 in from the bottom without removing it.
 Old 08-03-2011, 05:20 PM   #21
Importfan12's Avatar
Posts: 171   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
Yeah that bolt is a bitch I did my BNR Stage 3 with out removing the mani but after the turbo was removed I took off the mani just because. You need some offset wrenches!!!! I have to buy two sets the first didnt have enough offset.
Importfan12 is offline   Reply With Quote
 Old 08-03-2011, 05:20 PM   #22
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Post reviews once you get the turbo up and running.
 Old 08-03-2011, 05:23 PM   #23
It took me and my buddy 2 nights to remove and install everything. But I did a DP at the same time.
I didnt know you needed heatshields for the heatshields lol who decided you need 52 heatshields for you turbo lol
 Old 08-03-2011, 05:31 PM   #24
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
me and @I Love Brownies have got it down to about a 4hrs to do a turbo swap.
this is what happens when you have to take a turbo off someones DD because ATP decided to install the IWG backwards. I think in one weekend we took the manifold/turbo out like 4 fucking times.
860whp/677wtq
2.7 V6 Ecoboost
I Love Brownies (08-05-2011)
 Old 08-03-2011, 05:36 PM   #25
zenger's Avatar
/wrists I would
2007-Mazdaspeed 6
The Following 3 Users Say Thank You to zenger For This Useful Post:
atvfreek (08-03-2011), PapaSmurf (08-03-2011), TexasSpeed3 (08-09-2011)
 Old 08-03-2011, 05:38 PM   #26
PapaSmurf's Avatar
haha and to think, im doing another swap this weekend, but its externally gated. so a fucking men!
860whp/677wtq
2.7 V6 Ecoboost
I Love Brownies (08-05-2011), TexasSpeed3 (08-09-2011)
 Old 08-03-2011, 06:37 PM   #27
atvfreek's Avatar
Posts: 7,787   (View Stats)
Hopefully you get that BNR up and running soon, want to see how she rips.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 08-03-2011, 06:44 PM   #28
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Glad to hear you got it going man. Congrats. Get it on and tuned!
07 MS3
 Old 08-04-2011, 08:31 PM   #29
zenger's Avatar
all lines ran and hooked up; waiting on a gasket and it'll be all buttoned up tomorrow.
Is it a big deal not to put this turbo bracket back in? I figure the Manifold is enough support for a cast iron manifold?
2007-Mazdaspeed 6
 Old 08-04-2011, 08:42 PM   #30
Bucker's Avatar
Groans: 451
Use the bracket if at all possible,
 Old 08-04-2011, 09:02 PM   #31
zenger's Avatar
dang didn't want to hear that; guess I'll put it in tomorrow
2007-Mazdaspeed 6
 Old 08-05-2011, 10:58 AM   #32
bewsted's Avatar
Yea you really want that turbo support bracket in there.
EWG K04...GETSUM!
 Old 08-05-2011, 11:05 AM   #33
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
meh that stock manifold isnt going to crack but it wont hurt .
in all honesty like @MicaBlueMS3 said its fairly easy after the first time. plus my build this weekend we have access to a lift so it should be a cake walk in the park.
I Love Brownies is offline   Reply With Quote
 Old 08-05-2011, 01:27 PM   #34
PapaSmurf's Avatar
the only bolt thats a bitch is the one located all the way to the right underneath, next to the CDFP.
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-05-2011, 10:16 PM   #35
zenger's Avatar
turbo in and running, low boost haven't cranked it up yet only 16#.
Didn't add coolant after pegged the coolant gauge 244*
On the small drive I took it on had an overwhelming smell of clutch after every wot pass
Guess more mods...
2007-Mazdaspeed 6
 Old 08-06-2011, 07:20 AM   #36
Will fuck up ur day
Chimmike's Avatar
Groans: 433
lol suck. well, at least it's running now man.
07 MS3
 Old 08-06-2011, 01:45 PM   #37
zenger's Avatar
hitting 15 psi and feels about the same as the k04 at 18 psi
need to crank the mbc up
kunfu likes this.
2007-Mazdaspeed 6
The Following 2 Users Say Thank You to zenger For This Useful Post:
Broxer (08-10-2011), PapaSmurf (08-07-2011)
 Old 08-09-2011, 12:04 PM   #38
zenger's Avatar
Feels pretty beast hit 20 PSI for a bit then tapers to 19 and 18; upped it a bit more and it can't hold 21 or 22 for more than a few tenths of a second before it drops. So I've just backed it off to 20, BPV leaking past 20#?
2007-Mazdaspeed 6
 Old 08-09-2011, 06:48 PM   #39
Cameron Letcher's Avatar
Posts: 311   (View Stats)
Cameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the world
If you ask Forzda he may be able to tell you what's up.
Cobb AP, Cobb intake, Cobb TIP, Cobb shift weight, KMD internals, TWM stage II shifter, DNP manifold, BNR stage III, M2 performance DP, Grimmspeed ECBS, Sure rear diff mount, Sure rear eng mount, Street unit TMIC, PTP injector seals, Mazdaspeed springs.
"Verrà la morte e avrà i tuoi occhi. (Death will come and it will have your eyes.)"
— Cesare Pavese
Cameron Letcher is offline   Reply With Quote
 Old 08-09-2011, 06:38 PM   #40
could be leaking. have any logs?
i wonder if your hitting throttle closure limit? then again with a mbc it may not matter.
im sure you can run 20psi to redline no problem on that turbo without pushing it.
hows that ebay downpipe, i want one
Exhaust depot piping/FMIC install problems NCZ13 MazdaSpeed 3/6 - Turbo Induction 17 06-20-2011 03:52 PM
ETS TMIC Problems after install (Help!) Bujwazay MazdaSpeed 3/6 - Turbo Induction 17 02-10-2011 07:40 PM
Standback Install Problems bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 25 12-26-2010 04:03 PM
CP-e Xcel Nano Install Problems - got tips? Hank3 MazdaSpeed 3 - Engine, Transmission & Driveline 17 06-25-2009 10:14 AM
will a ets tmic 3.25" cause me ap problems on stage 1 + skeeter149 MazdaSpeed 3/6 - Turbo Induction 6 01-18-2009 09:42 AM
Page generated in 0.57637 seconds with 38 queries
