 Old 10-19-2012, 03:28 PM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default BNR Stage3 Base map
Does anyone happen to have a base map they wouldn't mind sharing? I was thinking of just cutting WGDC to 0 across the board on my current tune, but I know that wouldn't be the ideal solution.
Fully bolted with FMIC, if that helps further.
mczimer is offline   Reply With Quote
 Old 10-20-2012, 07:14 AM   #2
Importfan12's Avatar
Posts: 171   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
If I can figure out how to post it I can post mine. Let me know if mods are similar
2007 MS6 GT3076 Built motor.
Importfan12 is offline   Reply With Quote
 Old 10-20-2012, 02:58 PM   #3
mczimer's Avatar
yes, only thing is intake
BNR Stage3 Installation speedo MazdaSpeed 3/6 - Big Turbo Builds 57 04-18-2014 10:39 AM
400hp BNR stage3 atvfreek 2010 MS3 - Dyno Sheets/Discussions 925 12-21-2013 05:21 AM
going up against a Stage3 B5 S4 08_ms3_gt Street Racing Stories ( Bench Racing ) 8 04-08-2009 07:03 AM
SPEC stage3+ and stock flywheel EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 8 07-29-2008 12:35 PM
Page generated in 0.24565 seconds with 21 queries
