![]() Join Date: Jul 2008 Location: Montréal, Québec
Rep Power: 0 ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Neutral : +1 score I will install a BNR stage 3 turbo really soon but I need some additionnal information about the installation. I read somewhere that after the turbo installation is complete, we are supposed to crank the car (but without totaly starting it) to make sure oil is going inside the turbo housing. Is it true and how do I made that (by removing the fuel pump fuse)? I want to make it by myself because I want to save some money. It's my first turbo installation but I have do a lot of mechanical work. Any help, information, tip on the installation should be great before I put my car on jack stand and start the job. Thanks |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score PM forzda, and Iam sure he will tell you everything you need to know about the installation steps regarding the bnr turbo.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score From what I understand, the bnr stage 3 is very similar to the 2871. If that is the case, I wrote a how to under the gen 2 how to section... I didn't put any photos, as the 2871 is similar to a 3071 install, and Lenny has a how to sticky under gen 1 w lots of photos... I think it is called Lenny gets big turbo fever too. So, when u pm forzdA (who is one of the most knowledgeable dudes on the forum) like zx2man suggested, if you verify that it is like the 2871, then you should be able to learn all the trouble spots between those two how to's. ... I did not prime the turbo and nothing bad has happened yet, but idk if you are supposed to or not. Sorry, I'd give u some links here but I'm on my phone. |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (05-17-2011) |
| Not Ranked : 0 score The BNR is more "bolt on" than the ATP in that it doesn't need the big mouth TIP and IIRC one line needs to be bent a little - Forzda did do a writeup on it. As for cranking the car without starting - just floor the accelerator - that will stop the injectors and spark. Not really needed though. Install everything, start and idle the car and jump out to check for leaks. Let it warm up and keep checking for leaks. |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
| Not Ranked : 0 score If i remember correctly i just unplugged the harness for the coil packs and then let the engine turn over a few times. Have you got a new coolant line ready to go & how are you running your boost control? |
(Thread Starter) | Not Ranked : 0 score I am now reading all the thread about the coolant line. Brian from BNR send me a banjo adapter for the coolant line, I think I will need a flexible line to connect to it. For the boost control, I will try the factory EBC first. Thanks a lot guys for all your information, it's very appreciate. |
![]() Join Date: Mar 2010 Location: Memphis, TN
Rep Power: 315 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score keep this updated please. i know forzda cut his coolan line and just put a rubber piece in the middle. other than that it bolted right up
__________________ 2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune |
| The Following User Says Thank You to laxplayermjd For This Useful Post: | rfinkle2 (05-31-2011) |
| Not Ranked : 0 score I just made a new coolant line with high temp silicone hose and heat reflective wrap and haven't any problems after 10,000k's If your using the standard boost control on bleed config then you need to put a restrictor pill in the boost source line. I found that 1.6-1.7mm hole worked best Last edited by Toddy22587; 05-27-2011 at 10:53 PM. |
| The Following User Says Thank You to Toddy22587 For This Useful Post: | rfinkle2 (05-27-2011) |
Groans: 31
| Not Ranked : 0 score I know there are certain turbos that don't need to be primed but there are definitely some that do need to be primed. Garrett ball bearing turbos absolutely have to be primed. I did an install one time and my friend assured me that a couple of 10 sec cranks would do the trick. Nope. Toasted the bearings. Got another turbo and had to crank for 25 sec before oil got to the turbo.
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
12. How should I break in a turbo? A properly assembled and balanced turbo requires no specific break-in procedure. However, for new installations a close inspection is recommended to insure proper installation and function. Common problems are generally associated with leaks* (oil, water, inlet or exhaust). TurboByGarrett.com - FAQ's Was this a long time ago? No one here mentioned priming the turbo... a neighbor that dropped by and started wrenching later on asked if I wanted to prime it. I had never heard of that except from him, and then you. I didn't prime it. The inside had some oil in it already, as in one oil side.. I forget which now.. well had a few drips of oil on it. Not sure if that helps speed up the priming or if they used to be different. *I had a tiny coolant leak on the feed line, and just tightened her up.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | rfinkle2 (05-31-2011) |
![]() Join Date: Jul 2010 Location: connecticut
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 163
| Not Ranked : 0 score priming the turbo is suggested and very easy to do, better safe than sorry with a very expensive shortcut
__________________ 2006 mazdaspeed 6 grand touring turbo |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Can somebody take a picture of the coolant line? I want to make one before I start to install my stage3
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | rfinkle2 (05-27-2011) |
Groans: 134
A couple notes on the other one: 1) You can simply bend it using a mallet. 2) If you do want to fabricate your own, why not just do what LennyB did for his 3071 install? If you do use your own, you need to find a way to extend the hose a bit, or angle it perfectly. | |
Brian send a banjo adapter to use with high temp hose but I'm a little bit scared about it. | |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
| Not Ranked : 0 score I also have a BNR stage 3 waiting to be installed with the catless downpipe. Please, post a how-to thread on making all the necessary lines and installing this turbo. |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score Just cut the OEM pipe about 1.5" from the banjo and use a longer piece of hose to bring it to the block nipple. It isn't some "special" hose/fitting. It is simply the coolant hose, same as the radiator hoses only smaller. I used a spring clamp and wrapped the hose with high temp reflective wrap for a short distance and safety wired around to hold it in place. The whole process is dirt simple. Check out mine in photos
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy Last edited by FORZDA 1; 05-27-2011 at 08:12 PM. Reason: mo fo |
I am interested in how you got the stock support bracket to attach to the turbo, you mentioned the DNP shifted it slightly. I assume you have one with a 2.5" inlet, what tip did you use? I am also very interested in what exactly you used to heat shield around the firewall/cowl/hood Also, while I am picking your brain, how much did that jet-hot coating run you? I am thinking of going with the swain tech coating, but it's going to be nearly $300 with shipping.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by Ziggo; 05-27-2011 at 11:01 PM. | |
Groans: 31
| Not Ranked : 0 score Yup, that's my plan as well. Just got some high temp rubber hose and some aluminum heat shielding. It will be fine. If you want to get your own banjo fittings, the bolt is M12x1.5 (it's in bnoon's restrictor bolt thread).
![]() | | #19 | ![]() |
Groans: 134
| Not Ranked : 0 score I would like to know what u used for the heat wrap for the coolant line. Ziggo, w the 2871 the bracket rest naturally against the turbo. There is enough pressure that it does not tap against it, but is firmly pressed... I do like what Lenny did w his wrapping though. |
![]() | | #20 | ![]() |
Groans: 31
| Not Ranked : 0 score You can use this and wrap it around a lot of times: DEI Cool Tape 1 3/8" x 15" 010408 Exhaust Heat Wrap | eBay Or you can get this (what I'm going to use): Thermo Tec 17062 Thermo-Tec Thermo-Flex Insulation
| The Following User Says Thank You to bmylez For This Useful Post: | Ckmazdaspeed3 (05-28-2011) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score @ Ziggo... I have the Cobb TIP on the larger Stage 3 inlet. Works just fine. You will likley need to elongate the lower turbo support bracket bolt hole to get the bolt through it into the bottom of the turbo when using the DNP mani. The hose is 5/16" high pressure fuel hose from the auto parts store. No need to "prime" the turbo with oil. It comes from BNR already lubed with plugs in the oil holes. It will fill immediately when the oil pressure comes up. It gets a plenty of oil pressure which is one reason the OEM turbo smokes so easliy. Also, here is the HP Heat Shield Tape that I've used for many years and recommend as the "best". I used the 4" wide to insulate the firewall and a short piece of the 1.5" to wrap the coolant line. If you clean the surface (I use alcohol) good it will stick and last for years. Start at the bottom of your work and overlap from above so any fluids don't run underneath it to compromise the "stick". I also use it on the bottom of the TMIC tank at the rear section over the exh mani. Damn, I'm telling all my "secrets"! LOL Heat shield tape | Heatshield Products I have also used the thinner foil tape to touchup scrapes on the heat shields around the PTO on the Speed6. The thicker tape is a better insulator for large coverage areas, but it isn't as good to stick and cover small stand-alone spots as the thinner foil. You can cut the foil into a small circle or other odd shapes. http://www.heatshieldproducts.com/pr...oil-tape/68/22
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy Last edited by FORZDA 1; 05-28-2011 at 11:37 AM. Reason: mo fo |
![]() | | #22 | ![]() |
| The Following User Says Thank You to paveltol For This Useful Post: | FORZDA 1 (05-28-2011) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey Forzda, I install the turbo today and have a problem. The oem WGA have an inlet and outlet for boost and the upgrade one on the BNR have only one. How do you route the line. |
![]() | | #24 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score sir
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #25 | ![]() |
Groans: 134
| Not Ranked : 0 score The missing line attached to the turbo is the boost source. You can make another boost source by teeing it off of the small vacuum line that goes from your bpv to intake manifold (I think that is where it connects). Now the question is, did you get a 3 port boost control solenoid? I think that it is usually recommended to get one when going big turbo if you aren't using mbc or ebc. I will go see if I can find how to attach it to the stock solenoid... I think I have it right in my head but want to verify it... Hopefully in the mean time, someone will beat me to it. |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (05-30-2011) |
![]() | | #26 | ![]() |
For the stock ECBS you need to Tee the line between the boost source and the WGA, one tee goes to the WGA, the other to the solenoid.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Ckmazdaspeed3 (05-30-2011), rfinkle2 (05-30-2011) |
![]() | | #27 | ![]() |
Groans: 134
| Not Ranked : 0 score Ok, so you only have two ports on the stock solenoid, so if it will work at all, it will be as follows i believe: For a boost source, you T off the bpv to intake manifold connection, and then make another T on the vacuum line that connects the solenoid to the WGA... That is the only way that I can think of that this would work with stock solenoid. IF you do have 3 port, it is simple. T off bpv/manifold vac line for boost source, and then just make sure you put each vac line on the right nipple on the ebcs. Oh shit, sorry to waste the space I figured all upgraded iwg turbos were the same. My bad. Last edited by Ckmazdaspeed3; 05-30-2011 at 09:31 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #28 | ![]() |
Here is the OEM arrangement Compressor outlet to WGA inlet --> WGA outlet to EBC inlet --> EBC outlet to TIP inlet If I take the way of Ziggo: Compressor outlet to WGA inlet, I have to put a T on this line and run it to EBC inlet than run the EBC outlet to TIp inlet Is that correct? | |
![]() | | #29 | ![]() |
Groans: 134
I think I had the right idea though??? | |
![]() | | #30 | ![]() |
Groans: 31
| Not Ranked : 0 score Hope this helps.
| The Following 6 Users Say Thank You to bmylez For This Useful Post: | atvfreek (05-30-2011), Ckmazdaspeed3 (05-30-2011), joey1976 (01-19-2014), jracer (06-03-2011), rfinkle2 (05-30-2011), Toddy22587 (05-30-2011) |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
| The Following User Says Thank You to Toddy22587 For This Useful Post: | paveltol (05-31-2011) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Your intake is very phallic, but the diagram is correct.
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Blackspeed (07-18-2011), dougefresh_ (05-31-2011) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score You had the right idea, but the BNR turbos come with a boost source in the same place as stock.
| The Following User Says Thank You to Ziggo For This Useful Post: | Ckmazdaspeed3 (05-30-2011) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score So how does the car with this Stg3 feel? Does it pull harder? Still have mine waiting for setup, can't help getting more info.. |
![]() | | #36 | ![]() |
| Not Ranked : 0 score I'm still waiting to get my tune sorted out. I would say that in its current state (partially tuned) it does pull harder then the stock turbo but i imagine that if i had a similar tune on my stock turbo it would be much the same. I dont think i'm seeing any major benifit from the stage 3 at the moment because i'm only running 18psi. |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't understand "Bleed setup" I will running stage 2 maps for accesport with stocl solenoid, do I need restrictor pill, if yes where should I buy it Thanks. |
![]() | | #38 | ![]() |
Groans: 31
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. Last edited by bmylez; 05-31-2011 at 05:11 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to bmylez For This Useful Post: | dougefresh_ (05-31-2011) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score All bleed mode setups need a restrictor pill. I just used a welding tip from work, already had a 1.2mm hole so i just had to drill it out a bit. the outside diameter was about 6mm so it easily pushed inside my silicone hose |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've finish the install, everything seem correct. Toddy was right when he said that I will not see my boost over 12psi. I'm hitting 15psi but I should hit 18-19psi with the stage2+SF+FMIC. I will try to find a welding tip since I receive the grimmspeed EBC. In the same time, does anybody have experience with calibration of the AP with the grimmspeed EBC. |
| The Following User Says Thank You to speedo For This Useful Post: | Ckmazdaspeed3 (06-04-2011) |
| HID installation....HELP! | ILoveSpeed | Exterior | 12 | 03-02-2010 06:21 PM |
| going up against a Stage3 B5 S4 | 08_ms3_gt | Street Racing Stories ( Bench Racing ) | 8 | 04-08-2009 07:03 AM |
| SPEC stage3+ and stock flywheel | EvilMonkey | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 07-29-2008 12:35 PM |
| MBC Installation How To | Ghetto Mods | MazdaSpeed 3/6 - Turbo Induction | 6 | 04-25-2008 07:49 PM |
