![]() Join Date: May 2011 Location: Johannesburg, South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 783
(Thread Starter) | Not Ranked : 0 score I wanted to find out if anyone is running a BNR at altitude and if so how it holds boost, particularly after 5000 rpm, and also what maf flow you guys see. I have a bnr stage 2 and it just drops boost after 5000, I have an option to retrofit a 2871 or 2876 wheel at a low cost, I just wonder if it will make a difference at my altitude. Ill start: 5500 feet above sea level, baro pressure is about 12.2 psi BNR stage 2 Full bolt ons except manifolds 3port running 100% wgdc from 5000-redline Fmic Hits 20/21 psi at 3000 and holds 20 to about 4500 and trails to max 16 psi at redline Max flow I have seen is 318 gs and hits 2.5 load and tapers off to 1.8 load at redline. Thanks. Rich.
__________________ 2007 Velocity Red MS6 Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads Parts stockpile... Wiseco 88mm's / Manley H beams Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04 Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth) Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust 5500 ft altitude FTL MSF in South Africa |
| Not Ranked : 0 score S3 has a much larger compressor wheel and you will be able to hold above 20psi. As for flow you will be around 20-25 g/s below what people see at sea level.
| The Following User Says Thank You to Lex For This Useful Post: | Rich990 (07-03-2013) |
(Thread Starter) | Not Ranked : 0 score excellent, thank you Lex, thats what I wanted to hear!!
(Thread Starter) | Not Ranked : 0 score Sorry to revive this, do you guys think a 2876 wheel will be too big for the housing and / or the turbine wheel? 5500 ft means I lose about 3/4 psi capability on the top end and I would like to be able to hold 22 psi at redline, without the turbo spitting fire. Thanks
Groans: 370
| Not Ranked : 0 score 2876 in a small turbine housing will be a bit of an odd turbo- I would opt for the 71mm compressor option, basically making it like a BNR S3 |
| Altitude Strikes again... | snailD | 2010 MS3 - Dyno Sheets/Discussions | 13 | 09-10-2012 11:45 AM |
| bolt ons at altitude.. | hcbr929rr2 | Gen2 MS3 General Discussion | 3 | 11-02-2011 04:38 AM |
| Altitude? what? where? | BUNGEEZZ | MazdaSpeed 3/6 - ECU Computer Tuning | 18 | 07-24-2010 03:50 PM |
| High Altitude 1/4mi Times | Emoranges | Drag Racing | 6 | 04-14-2010 07:04 AM |
| altitude and my 3071 | djuosnteisn | MazdaSpeed 3/6 - Turbo Induction | 0 | 08-13-2009 01:22 PM |
