 Old 09-02-2013, 04:02 PM   #1
croglesby's Avatar
Posts: 18   (View Stats)
croglesby is a jewel in the roughcroglesby is a jewel in the roughcroglesby is a jewel in the roughcroglesby is a jewel in the rough
Default Bnr3 leaking?
Well for starters I have a 06 speed 6. The k04 started smoking. U get the picture. I want to start by thanking everyone for your help and posts so far. They have gotten me where I am today. I went the path of bnr stage 3 and started tuning with stratified. I am only getting like 15 or 16 lbs of boost. Ok I should be getting around 20 or more with my setup. (Cobb sf Sri-cx front mount-internals-tip-tigs-injector seals-all motor mounts-catless dp- corksport catback- jbr stage 2 occ-and with bnr also added 3 bar map and Cobb 3port ebcs. All bolted u would say. So I went searching for boost leaks using smoke and soap multiple times. I did find one at bpv and replaced o rings. I did find smoke comming out of back of turbo. It's around the compressor housing and middle part. Is this normal is that a bad seal? It takes no pressure( me using lungs only) for smoke to come out. This is only leak left.
Any thiughts
Last edited by croglesby; 09-02-2013 at 04:02 PM. Reason: MSF Database - Automerged Doublepost
croglesby is offline   Reply With Quote
 Old 09-02-2013, 04:13 PM   #2
croglesby's Avatar
I should add that I was getting boost spikes of 19lbs on same set up minus 3 bar 3 port and bnr stage 3. Only small amounts of wastegate added at most I think 20 up high
 Old 09-02-2013, 04:23 PM   #3
Yes, older BNRs leak, search the forum. Email/call Bryan at BNR he will send you a fix.
 Old 09-02-2013, 04:26 PM   #4
croglesby's Avatar
This is a new one. With the bnr branded tabs around them. So it is the culprit.? I do not want to change it out again dam
 Old 09-02-2013, 04:31 PM   #5
Check this out.
 Old 09-02-2013, 04:45 PM   #6
cymen's Avatar
Posts: 75   (View Stats)
cymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the worldcymen is the leader of the world
subbed
2010 Black Mica Speed3
Mods to date: GTX2867R, HTP 3.0" Intake System + 51R Battery Tray, Eibach Pro-kits, Koni Yellow's, Cobb AP, CS rear swaybar, Racing Beat cat-back Exhaust, cp-e Tow Plate, cp-e TMIC, cp-e HPFP, cp-e DP, cp-e injector seals, Turbosmart bpv, JBR Chrome-Molly RMM, JBR PMM 70a Duro, JBR TMM 70a Duro, JBR Stage 1 Heavy Shift Knob, JBR Solid Shifter Bushings, JBR 5mm Wheel Spacers, JBR Thermal Insulating Intake Gasket Kit & Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit, JBR EGR Block Off Plate, Cobb EBC, Saikou-Michi OCC, Snow Performance meth kit. Prosport 52mm Premium Series Electric Boost gauge & Oil Pressure Gauge with Prosport oil filter adaptor plate, Block8head dual gauge vent pod, Bosche 3bar map sensor.
cymen is offline   Reply With Quote
 Old 09-02-2013, 05:53 PM   #7
croglesby's Avatar
When I read this before I thought it was just on exhaust side and the new tabs were going to fix it. I guess I was wrong. Lets see how Brian handles it.
So have some better bolts with lock washers and lock tight fixed it? That's what everyone else seems to have done. But mine seems tight. Could it be a housing issue is what I'm worried about
Last edited by croglesby; 09-02-2013 at 05:53 PM. Reason: MSF Database - Automerged Doublepost
MS6 BNR3 BTB Issues Please help ms6_nate MazdaSpeed 3/6 - Big Turbo Builds 40 10-03-2013 05:58 PM
A Year With a BNR3 dereeek 2010 MS3 - Build Diaries 7 07-08-2013 08:20 AM
Possible bpv leaking!!!! Matt H. 2010 MS3 - Troubleshoot/Diagnostics 15 02-11-2012 07:53 PM
Page generated in 0.26192 seconds with 22 queries
