Like Tree34Likes
 Old 05-08-2016, 10:23 PM   #81
brandonf's Avatar
Posts: 511   (View Stats)
brandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the world
Another day of fun.. and from the wise words of @Rokusek; :
Didn't take the time to take a bunch of pictures today. But I did get a few.Ryan Danos @danosrk got the battery relocation kit installed and ready to go along with all the gauges. We got the axels back in, swapped out the front upper control arms, H&R coils done up front along with the Evo 8 Brembo Big brakes, stainless brake lines up front. All engine electronics are done, 4 port boost controller and all the lines are installed. Got the @Matt@DamondMotorsports; Power steering cooler installed. We have made some serious progress over the last two weekends. But we still have a lot more to go.
We hoped to have the car running today but ran into some complications. We need the port injection injectors still for the JMF manifold, we are still waiting on the port injection fueling kit to get her. Wot box, Manual fan speed controller, and a few other things still need to get wired in.
For the most part, I am extremely happy with the progress we have made with a solid 4 days worth of work. We hope to have the majority of left over work to get done within this week aside from the fan controller and wot box.
It's been a long road to get this far but I must say Brandon Florin is almost done going full retard.'
- Spark plugs changed
- Boost/AFR gauges wired up
- Evo 8 brakes installed
- H&R Coils (up front) installed
- CS Upper controller arms installed
- HTP Battery relocate + Circuit Breaker installed
- Technafit SS brake lines installed
- 4 port boost controller installed
- MD Power steering cooler installed
ItsNox likes this.
2011 Silver MS3: Totaled
2006 Silver Speed 6: Modification in process
Speed3: 1/4: 12.8@115.71
Build log for the 6: http://www.mazdaspeedforum.org/forum/forum/f498/brandonf-flo-s-bt-speed6-build-191584
brandonf is offline   Reply With Quote
The Following 2 Users Say Thank You to brandonf For This Useful Post:
SpeedRebirth (05-09-2016), WetzMS3 (05-09-2016)
 Old 05-09-2016, 03:22 PM   #82
brandonf's Avatar
Moar purchases:
- Tanabe oil pressure gauge
- Apexi Turbo Timer (pte6265 is only oil cooled)
- Evo8 brake bolt, black will sent one of the wrong bolts :|
- Full replacements on all of the intercooler piping clamps
- Eibach 15mm spacers (to clear the evo8 brakes)
ItsNox likes this.
The Following User Says Thank You to brandonf For This Useful Post:
 Old 05-10-2016, 02:49 PM   #83
brandonf's Avatar
- WOT Box ordered
I thought I picked one up from Chris, but couldn't find it, so fookit.. ordered one from WOT Box - N2MB Racing
WetzMS3 (05-10-2016)
 Old 05-12-2016, 01:31 PM   #84
Modality14's Avatar
Posts: 140   (View Stats)
Modality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond repute
that engine and turbo setup looks awful familiar
brandonf likes this.
Current: 2007 s2000 ap2
RIP 2008 genwon
turboxs fmic / turboxs catless dp&rp / hks catback / HTP 3.5" intake / ATP GTX3071r ewg / tial QR bpv / cpe hpfp / cp-e 75 duro motor mounts / cp-e safeseals / stoptech slotted & vented rotors & stoptech pads / BC Coilovers / RPF1s 18x8.5 +40 / BoostJunkyz stock location turbo manifold / killah built bitch bwah
Modality14 is offline   Reply With Quote
 Old 05-15-2016, 09:20 PM   #85
brandonf's Avatar
Lol, it should.. rocking Nagel's built motor/turbo/fmic/intercooler/intake. THE CAR IS NOW RUNNING! There's still a few more things left to do.. rear sway bar, diff mounts, rear suspension, dss axles, couple braces, raise the clutch height, and possibly clean out the rear diff.. and it'll be ready for the road. Also going to get a race alignment/corner balance.
Ran into a problem with the ground on the starter not plugged all the way in.. damn thing ate up a few hours trying to figure out wtf was going on :|
Also running super lean, 23-24 stft's at idle on a base 4" intake map, so going to buy a new gasket for the DP->Turbo and replace the V-band clamp, which will hopefully fix the problem. I bought all new clamps for the fmic setup, so I don't believe any of them are leaking.
 Old 05-15-2016, 10:20 PM   #86
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Oh this is the 6 Rokusek was posting about on FB. I noticed Downmented's turbo setup on it
 Old 05-17-2016, 12:11 AM   #87
brandonf's Avatar
Yessir, he's local and has done a lot of the work (and one of the best guys I've ever known!), same with @danosrk;
Found a blown o-ring on the BPV, missing purge valve on the intake manifold, and possibly a leak between the turbo -> DP.. so ordered a new o-ring, gasket/v-band clamp for the turbo -> dp.. and will be looking in the garage for the purge valve. Hopefully this will fix the leaks
WetzMS3 likes this.
WetzMS3 (05-17-2016)
Psycho's Speed6 Build (PT6266) psychophyr Mazda MZR DISI Engine Builds (2006-2013) 710 09-18-2014 09:27 AM
07 Speed6 Build ABQ Speed6 MazdaSpeed 3/6 - Build Diaries 57 05-27-2014 01:22 AM
Page generated in 0.28910 seconds with 23 queries
