Groans: 31
(Thread Starter) | Not Ranked : 0 score Ok, build specs: Steedspeed T3 manifold with 38mm wg port PTE 5857 with billet compressor wheel Tial MV-S EWG with 16psi spring combo TurboXS MBC 3" downpipe made by mason Eventually going to make a custom 3" intake, but that's not a priority Ok, n00dz: As you can see, I don't need Dustin's crutch, his modified oil lines. The stock banjo bolt is M12x1.5. This banjo has a .060" restrictor, the correct size for journal bearing. This setup should work perfectly. Turbo blanket (it's beat up because I used it on my Focus turbo build)
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. Last edited by bmylez; 08-29-2011 at 07:47 PM. |
| The Following 15 Users Say Thank You to bmylez For This Useful Post: | aaronc7 (08-31-2011), AJ713 (09-03-2011), BlueStreak (09-01-2011), Broxer (11-08-2011), djuosnteisn (09-09-2011), doubleflusher (09-20-2011), emag remrofni (09-02-2011), essejkcamraw (08-30-2011), I Love Brownies (09-02-2011), JasonMzdSpd3 (05-08-2012), LiEast (09-04-2011), mason (08-30-2011), PapaSmurf (08-31-2011), PunjabiPlaya (08-29-2011), TexasSpeed3 (11-12-2011) |
![]() Join Date: Apr 2010 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35,474
Groans: 131
__________________ Cobb SRI CPE 75 duro RMM AP - tune in progress broke ass college student |
| The Following User Says Thank You to PunjabiPlaya For This Useful Post: | JasonMzdSpd3 (05-08-2012) |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score tl; dr.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
| The Following User Says NO Thank You to Bucker For This Un-useful Post: | emag remrofni (09-02-2011) |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score NICE!!!!!!!
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Got the wastegate outlet flange today. That means I'll be able to grandma it to the exhaust shop when it's done. Downpipe should arrive tomorrow. That means I'll be prepping the car tomorrow night. It will take a while to cool down, so I'll do things like battery, alternator, intake, charge piping. Not much else. It will give me a good head start, though. I want this all done Friday.
| The Following 3 Users Say Thank You to bmylez For This Useful Post: |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score Where you getting your DP from?
__________________ Cobb AP, 504whp 492wtq |
Groans: 31
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. | |
| The Following User Says Thank You to bmylez For This Useful Post: | mason (08-31-2011) |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Ok, downpipe got delayed by a day, so Friday. No biggie. I can install everything else without out. Gonna start taking the car apart right....naow!
| The Following User Says Thank You to bmylez For This Useful Post: | JasonMzdSpd3 (05-08-2012) |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Custom made. I already have the car disassembled a good amount. A lot of my turbo and manifold bolts were super loose for whatever reason....so I actually avoided massive exhaust leak by doing this, yay.
| Not Ranked : 0 score So Mason makes custom DPs?
Groans: 31
(Thread Starter) | Not Ranked : 0 score Yes. He had to guess with mine, though. He has the Steed twin scroll manifold, which puts the turbo closer to the alternator. He had to guess about 0.7" over for my manifold since it's stock location.
Groans: 31
(Thread Starter) | Not Ranked : 0 score Ugggghhhh, things slowed waaaay down when it came time to undo the rest of the manifold bolts, undo coolant lines, etc. Pain in the ass. I FINALLY see what everyone is bitching about, haha. So I hit a major snag. I wanted to use my own custom oil feed setup. Well, it would have worked perfectly except that right around the oil feed port, there are ridges on the block and my custom banjo fitting isn't tall enough...so my plan is file down the block to make it fit. Ghetto, but it will work. I'm dead tired, so callin it a night.
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | JasonMzdSpd3 (05-08-2012), mason (09-02-2011) |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Aaaaaaaaaaaaand, FAIL in 5, 4, 3, 2, 1. After I removed the stock oil feed fitting, I tried to put my custom bolt in by hand. Didn't seem to want to go in. I tried the stock bolt...also didn't want to thread in more than a turn or 2. I test both bolts on the turbo itself and they threaded right in. I took the belt tensioner off to have more room and kept trying and trying to hand tighten either one of the bolts back into the feed location but it would always tighten up after a few turns. One time I got the stock bolt to go in a few turns and tried tightening with a wrench...then the bolt went sideways, so I was like WTF. I only tightened one turn, so I thought I was ok. Long story short, my oil feed port is stripped for whatever fucking reason even though I was as careful as I could be and every single time I would put a bolt in, I always tried to hand tighten it a few turns...but I guess the one time I tried using the wrench, it tweaked it. No idea on that one. So everything is at a prolonged halt for now...
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Why? Because Obama Rigged.
__________________ |
| The Following 6 Users Say Thank You to triplejumper18 For This Useful Post: | Bucker (09-02-2011), Chimmike (09-02-2011), JasonMzdSpd3 (05-08-2012), MazdaASM (09-04-2011), Payne Racing 67 (11-30-2011), Realgib3 (09-04-2011) |
![]() Join Date: Jun 2010 Location: Santa Fe NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,637
Groans: 371
| Not Ranked : 0 score good shit man good luck with your build. looks very promising with the hardware hope you can get that oil feed fixed soon. pics of dp? |
| The Following User Says Thank You to I Love Brownies For This Useful Post: | 11cruzito11 (09-02-2011) |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Why don't you take the alternator off so you have full, unrestricted access and make sure it's stripped, and not something screwy going on.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Not really. I had a pretty good idea for oil feed, but previous owner used to have BT on it...so I'm thinking the oil line has been messed with before. I saw what appeared to be metal filings on my bolt *before* I used a wrench. Either it was metallic looking thread locker, or it really was aluminum and it was stripped before I even did anything. I lost count of how many times I tried hand tightening. Doug, I took the alternator AND belt tensioner off before I even started touching it. I wanted to make sure I had a straight shot to everything. Even with everything out of the way, not even the stock bolt would thread back in easily right after I took it out whereas everything threaded back into the turbo very easily.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. Last edited by bmylez; 09-02-2011 at 02:02 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to bmylez For This Useful Post: | dougefresh_ (09-02-2011) |
![]() | | #19 | ![]() |
. I'm close to having a similar problem w/ one of my top power steering bolts... not sure how many times I'll be able to take main off before it goes, and I'm sure it'll cost me to fix/replace that. GL with the fix... let us know how you approached it, and how it came out. GL
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
| The Following 2 Users Say Thank You to dougefresh_ For This Useful Post: | djuosnteisn (09-09-2011), rigor (09-05-2011) |
![]() | | #20 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Yes, it is correct size/pitch. M12x1.5. It threads very easily into the turbo, as do *both* stock feed bolts. Not even the factory bolt would thread back into the block right after I took it out. It looks a lot like prior damage to me considering how careful I was.
![]() | | #21 | ![]() |
| Not Ranked : 0 score yeah, sounds like it was cross threaded in befor you had it. and when you took it out, it ripped the threads to shit! dont sweat it, everything is fixable.
| The Following User Says Thank You to mason For This Useful Post: | Bucker (09-02-2011) |
![]() | | #22 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Ummm...this one is a little more complicated, haha. But I really think the threads were already fucked. Previous owner had a 3076 on it...not sure if it was stock flange or not, but I know he had a tubular manifold with EWG. I just don't see how it could have been me when I tried threading it in by hand at least 20 times before using a wrench. All the other bolts on the car threaded just fine. Oh, and I can fit the turbo and manifold together into the engine bay without taking the cowl off. I guess the stock setup is somehow bulkier despite being a tiny turbo. You just need to give the metal heat shield a little love. My Precision isn't that big, so I don't think you could do this with a 3076, but you could try. Taking the cowl off might make it possible.
![]() | | #23 | ![]() |
| Not Ranked : 0 score i did not take the cowl off with the 35R, OR THE ALTERNATOR. or the valve cover ect..... it wasnt that bad at all to me at least.
![]() | | #24 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Nice...but you did have to smash that metal heatshield in a little, right? Maybe not...my turbo blanket is hitting it and a turbo blanket makes my exhaust housing bigger than a 35r. It'll just take a small hammer tap. Also, had a chat with Gerry and he had the same problem as I do. Mazda fails at pairing bolts with an aluminum block. Just by removing the bolt, you run the risk of stripping the hole...and looks like I was a lucky winner. There are threads left further in the hole, so I need to try cleaning it out and getting a longer banjo bolt!
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts | |
![]() | | #27 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score yeah I got Doubleflusher's 35r in without having to remove anything either. |
![]() | | #28 | ![]() |
Groans: 31
My plan now is to get a bolt to block off the stock port and run a custom line from an oil sandwich plate I just so happened to buy from a friend. A little unorthodox, I know, but that stock location sucks nuts and this setup will work just fine. I'll have a pretty long feed line, but that won't matter once there is oil in it. I just don't trust the stock feed location anymore and blocking it off seems safer.
![]() | | #29 | ![]() |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score One way to get a bolt to thread into a stripped hole is to tap it on the head as you turn it and it will find its way in smoothly as long as you keep the bolt straight in the hole. Tapping the head peens the threads out of the way that are malformed. I've done that lots of times. It's worth a try. |
![]() | | #30 | ![]() |
Groans: 31
![]() | | #31 | ![]() |
Groans: 433
| Not Ranked : 0 score You should be able to find a metric bolt somewhere like ACE that can plug the stock feed port as you're planning. Use some good thread locker/sealant though.
![]() | | #32 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I went to Home Depot and they only had m12x1.75. I'll see if there is an Ace somewhere...
![]() | | #33 | ![]() |
Groans: 433
| Not Ranked : 0 score yah, big box stores SUCK when it comes to metric hardware.
| The Following User Says Thank You to Chimmike For This Useful Post: | dougefresh_ (09-05-2011) |
![]() | | #34 | ![]() |
![]() Join Date: Mar 2009 Location: LONG ISLAND, NY
Rep Power: 305 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 629
| Not Ranked : 0 score that was my worse nightmare but i was able to fit everything nicely but i did strip a bolt on the oil return sucks and ruins your day lol... i gotta get that oil feed line to ya then!
__________________ 2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor PERM! |
![]() | | #35 | ![]() |
Groans: 113
| Not Ranked : 0 score Remember you need to get a bolt that is at least 5mm longer or you will rip out more threads from your block when you go to torque the bolt down. |
![]() | | #36 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score You had said 10mm longer the first time, haha. But the thing is, Gerry, I'm not using the stock oil feed anymore, so I actually need a shorter regular bolt because I won't have the threadless banjo portion. So I've made a lot of progress today. I got the manifold and turbo installed. Just need to put the rest of the nuts on the studs. I need to extend the heater core hoses. Those things fuckin suck. I just need some 3/4" hose and some 3/4 unions. I only need like 1/2" of clearance. @mason, your downpipe is ALMOST perfect, bro, props. Unfortunately, it runs into my oil drain hose, which is obviously a big no-no because it will cook my oil in just a few minutes. I am going to have to damage a thing of beauty and dent it. I'll take it to a shop and have to change it just a little. It's BARELY off from the catback, but I'm very very impressed how close you got it with how different my setup is. Everyone, if you need a downpipe, go through mason, he won't rip you off and he'll do it right, even when he's doing it blindly!
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. Last edited by bmylez; 09-04-2011 at 08:40 PM. |
| The Following User Says Thank You to bmylez For This Useful Post: | Chimmike (09-05-2011) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score thanks bro! i hope everything goes good with the rest of your build. i hope its a minor change needed. if it is costly let me know.
![]() | | #38 | ![]() |
Groans: 113
| Not Ranked : 0 score you will still need a longer bolt (5-10mm) even if its just to plug off. The length will depend on how many threads you ripped out. If you torque a shorter bolt down to the few threads left in the block, you will just rip them out as you torque the bolt down. Each thread retains a certain amount of torque pressure, when you rip out a good amount of threads, the rest wont be able to sustain the same torque value needed. This is why you need a longer bolt to grab more threads to make up for the ones you no longer have. Make sure you use new copper washers too. |
![]() | | #39 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Ok, so the part of the oil line that the banjo bolt goes into makes up over half of the bolt's length. The bolt is 35mm. So that means only about 15mm of the bolt goes in. I ordered a 25mm bolt. I will get back 10mm of threading, which is plenty. Like I said, the bolt was able to tighten without the crush washers...so however thick two crush washers are, that's how many threads I ripped out.
| The Following User Says Thank You to bmylez For This Useful Post: | NJSPEED3 (09-05-2011) |
![]() | | #40 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score So I changed my oil drain fitting (still downhill the whole time, don't worry) and mason's downpipe fits perfectly now! It's 2" too short for the catback, but that's no big deal. I just get to run open dump to the shop, hehe. Oil port bolt will be here tomorrow ($18 for 2-day shipping...for 3 bolts, hah). Car is mostly put back together. Messing with the heater core lines to fit the intake is a huge bitch. So I just need to put on: oil port plug, alternator, downpipe, oil sandwich plate, oil feed line, TIP/intake, and battery.
| The Following User Says Thank You to bmylez For This Useful Post: | Chimmike (09-07-2011) |
| MX-5 EFR Turbo Build | Andy@Killshot | Miata - Forced Induction | 40 | 12-28-2011 04:01 PM |
| Turbo Build | UKMPS3MK2 | 2010 MS3 - Turbo Induction | 12 | 05-10-2011 09:53 AM |
| My big turbo build | Speedie6 | MazdaSpeed 3/6 - Big Turbo Builds | 4 | 12-09-2010 01:54 AM |
| Anyone running a precision turbo on MS3 | origjdm3 | MazdaSpeed 3/6 - Big Turbo Builds | 37 | 07-08-2010 04:04 PM |
