![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score 56000 stock block .5557 been on 7000 miles @23 psi and a little 26 psi and 19psi no issues no flying dipstick
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| Fkin motor blew! (stock '07) | Mazdaspeedgirl | MazdaSpeed 3 - Engine, Transmission & Driveline | 180 | 05-26-2010 01:03 PM |
| Highest RPM stock motor can be rev'd to... ?? | all4bspinnin | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 08-31-2009 02:49 PM |
| CP-E Motor Mounts for the Mazdaspeed 3 in stock ! | kevin@gripgarage.com | Mazdaspeed3/6 General Discussion | 0 | 04-24-2009 02:25 PM |
| Motor Mounts in stock? | TheDoc | Mazdaspeed3/6 General Discussion | 1 | 07-09-2008 12:50 PM |
