![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
(Thread Starter) | Not Ranked : 0 score Dear stock motor big turbo ms3/6's guys, post up your overall miles on car, and then miles on after big turbo swap. Just for a reference, and hopefully people can update thier miles every few months or so.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
| The Following 4 Users Say Thank You to zx2man For This Useful Post: |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score 2008 ms3 20k on the motor. Been on the car since 8k, so I'm running it for 12k and no problems. Compression is 180psi across the board. |
| The Following 2 Users Say Thank You to kmac For This Useful Post: | dougefresh_ (05-21-2011), zx2man (05-21-2011) |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score sup niggah im high u no has 3071 in hata mothafukka? yet?
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | zx2man (05-21-2011) |
(Thread Starter) | Not Ranked : 0 score in about 3 weeks you weed smoking crazy sexy motherfucker.
Groans: 356
| Not Ranked : 0 score hahahahahahahha u still want me after the accent?? hahahahahahahahah weed a talk
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
| Not Ranked : 0 score 2009 Mazdaspeed Unicorn 30k Miles total ATP 3076 has been on for 9k miles Car has been driven to hell and back several times. I've been running 22+ psi the whole time with very few issues. |
| The Following 2 Users Say Thank You to jwilkins88 For This Useful Post: | mghtymouse380 (05-22-2011), zx2man (05-22-2011) |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score 2007 MS6 big cock edition 49k+ miles at the moment TS T3 3076 with Steed TS mani on for about 4k miles pushing 25+ psi the whole time with a few minor issues based on being a developmental kit.
__________________ |
| The Following User Says Thank You to jmhinkle For This Useful Post: | zx2man (05-23-2011) |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,186
| Not Ranked : 0 score 2007 MS3 38K miles 3071 on at 12K miles Been running 19 psi for last 15K, low 12 AFR, no KR Just finishing up T3 build with .82 a/r and steedspeed mani, ported IM and meth...dyno sheet soon to come new setup will be 21 psi
__________________ T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels |
Groans: 356
| Not Ranked : 0 score 07 ms3 88k miles 3071r about 10k miles on it running 21-22 psi..... been running 24psi last 2 weeks no issues /in b4 i try 25-26psi and make a boom thread
![]() Join Date: Jul 2010 Location: Philadelphia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
| Not Ranked : 0 score ^^ you make me want to go BT on my DD!! I need a beater/learning car. In for info.
__________________ 2010 Mica Black RMM/RSB/SRI+TIP |
Groans: 162
| Not Ranked : 0 score BT is far better for DD than K04. Doesn't make 20 psi at 1500 RPM like K04 and doesn't make 1000* of 16psi at redline.
| The Following 3 Users Say Thank You to jmhinkle For This Useful Post: |
I read lennys BT thread and I might be able to go the bolting but the tuning is where I'll blow her up.
__________________ 2010 Mica Black RMM/RSB/SRI+TIP | |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score 08 speed3 52k on car. new motor at 47k. Replaced with 09 brand new motor Still stock tranny and clutch and no issues. Been used to for autocross, drag racing, track events and many thousands of logs and races. LOL Im impressed with the clutch. 5000 miles between 350-400whp on my atp3071r bolt on turbo. NO need for custom setups when this one is proven to make the power and not break the bank if you gonna keep it under 400whp. And even the 3071r will get you there(on low boost). Shoot Id venture to say the 2871r would get you there also at 22psi. Ive never had mine over 18psi on the street cause the car just gets worthless. Been a rocky road but these cars are finally getting figured out due to all the hard work of the badasses on this forum, and the few jackasses to. LOL Hopefully Ill put 50k more on it with my 30r. Car seems to love it. The ko4 gave the speeds a bad name. A 16g sized turbo would have put the speeds in a whole new leaque.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| The Following 3 Users Say Thank You to driver311 For This Useful Post: |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score 56000 stock block .5557 been on 7000 miles @23 psi and a little 26 psi and 19psi no issues no flying dipstick
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() Join Date: Nov 2010 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 432
| Not Ranked : 0 score 45k on the motor 07 speed Atp 3076, 200mi on turbo, stock clutch
__________________ 07 MS3 Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel Perm |
| The Following 3 Users Say Thank You to Scribbles For This Useful Post: |
![]() Join Date: May 2010 Location: Kiev, Ukraine
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score MS`6 Stock engine, Garrett GT3076R Tial A/R 1.06 new motor, 12k miles on 16psi (1.1bar)
__________________ Mazda 6 MPS for comfortable and fast ride Mazda 3 MPS for a mad ride and adrenalin I Love MPS! |
| The Following 3 Users Say Thank You to avtoprofi For This Useful Post: |
| Fkin motor blew! (stock '07) | Mazdaspeedgirl | MazdaSpeed 3 - Engine, Transmission & Driveline | 180 | 05-26-2010 01:03 PM |
| Highest RPM stock motor can be rev'd to... ?? | all4bspinnin | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 08-31-2009 02:49 PM |
| CP-E Motor Mounts for the Mazdaspeed 3 in stock ! | kevin@gripgarage.com | Mazdaspeed3/6 General Discussion | 0 | 04-24-2009 02:25 PM |
| Motor Mounts in stock? | TheDoc | Mazdaspeed3/6 General Discussion | 1 | 07-09-2008 12:50 PM |
