![]() | | #81 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
![]() | | #82 | ![]() |
![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
(Thread Starter) | Not Ranked : 0 score I'm sticking with the 3071. Not saying that I wouldn't like a bigger turbo, but a new mani, downpipe, and turbo just aren't in the cards right now. I think Manley rates H beams at like 650hp, so I'm fine lol
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
![]() | | #83 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score AEM wideband failsafe gauge is on the way! Now I can stop watching my BATS to make sure meth is spraying lol Time to hook up the 6th port, and make some moar POWWA
| The Following User Says Thank You to Hammology For This Useful Post: | SpeedRebirth (10-13-2015) |
![]() | | #84 | ![]() |
Groans: 36
| The Following 2 Users Say Thank You to Hammology For This Useful Post: | ItsNox (10-14-2015), SpeedRebirth (10-14-2015) |
![]() | | #85 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score wooo... those are the shit.. got one myself
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #86 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Now I can have some peace of mind. And go faster of course. I'm hoping this GTX holds up at 30psi.
| The Following User Says Thank You to Hammology For This Useful Post: | ItsNox (10-14-2015) |
![]() | | #87 | ![]() |
| Not Ranked : 0 score I just installed one of these on my MS3. I still need to program the failsafe part of it.
![]() | | #88 | ![]() |
| Not Ranked : 0 score Good shit. Let us know how the install goes and what you think. Pics are required of course. Been considering one myself. Sent from my big ass Note 4 using shitty Tapatalk.
![]() | | #89 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I'm having mr Keefover do the install cause I'm a lazy turd lol I'll have pics of the finished product.
![]() | | #90 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score https://www.facebook.com/jon.hamm.71...0075235382839/ Fucking around after work tonight. Hopefully the link from FB works. Apparently I can't upload a video from my phone.
![]() | | #91 | ![]() |
Groans: 33
| Not Ranked : 0 score "Not available" It may be that you need to change your sharing options to everybody, not just friends
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | BLKSTIG (10-25-2015) |
![]() | | #92 | ![]() |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score youtube or bust!
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
| The Following User Says Thank You to levon.mark For This Useful Post: | Hammology (10-29-2015) |
![]() | | #93 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I'll upload it when I get home.
![]() | | #94 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I just changed the Facebook video to public, but I'll still upload it to the YouTubes when I get home.
![]() | | #95 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score I just remembered that I requested you just yo see the video...
| V2 Pre-amp | | |
![]() | | #96 | ![]() |
Groans: 36
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port Last edited by MS3Shadow; 10-30-2015 at 07:09 AM. |
| The Following 4 Users Say Thank You to Hammology For This Useful Post: |
![]() | | #97 | ![]() |
![]() Join Date: Sep 2015 Location: Canada, Ontario, Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score Sooooo Sick! Filmed in Mexico of course lol |
| The Following User Says Thank You to Cdnspeed6 For This Useful Post: | Hammology (12-04-2015) |
![]() | | #98 | ![]() |
| Banned ![]() Join Date: Feb 2014 Location: McLean, Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score Damn, that thing is hauling ass. The BT build forum is going to make my wallet hurt. |
![]() | | #99 | ![]() |
| Not Ranked : 0 score it always does and there is always something to buy. It doesnt stop with BT lol
![]() | | #100 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I don't have a long sig because I don't want to be reminded of the pain and suffering of my wallet haha.
| Built Motor MS6 | I_AINT_RICE | MazdaSpeed 3/6 - Big Turbo Builds | 87 | 05-15-2016 11:26 PM |
| built motor | blackms3_71 | Mazdaspeed3/6 General Discussion | 11 | 01-31-2013 08:19 AM |
