![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
(Thread Starter) | Neutral : -1 score Manley H-beam rods Carrillo Pistons Crower valve springs Pinned cams Keyed crank L19 head studs ARP main studs Minor head porting intake side Ported intake mani Custom Blow thru intercooler setup Custom 4inch intake PTP injector seals CPE exhaust mani GTX3071 Emusa 44mm wastegate(ebay) w/ custom dumptube Tial Q 50mm BOV M2 Downpipe Devils own meth SP63 6th port Here is a V-Dyno from my latest logs. I believe this is the 3rd revision since the break-in map. Had the motor built by Jordan Keefover. Nishan is the tuner, and the car feels great so far. Vdyno 4th gear rev. 3.jpg datalog30.csv datalog31.csv
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port Last edited by Hammology; 06-16-2015 at 08:53 PM. |
| The Following 10 Users Say Thank You to Hammology For This Useful Post: | Code Monkey (06-16-2015), fivefingerdeathpunch (06-18-2015), hermz (07-31-2015), ItsNox (06-17-2015), Mattyhawk1 (06-18-2015), Micha (06-21-2015), NCspecV81 (06-17-2015), Scare Dem (07-11-2015), SpeedRebirth (06-18-2015), WetzMS3 (06-18-2015) |
Groans: 36
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
Groans: 36
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Excited to see the results! What numbers are you shooting for? How long did it take him to build your motor?
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | Hammology (06-17-2015) |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score Nice build. Are you going to have enough MAFv headroom to use fully use 6th port? You're already @ 4.5v.
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Hammology (06-17-2015) |
Groans: 36
It took Jordan about a week to get everything balanced, machined, assembled, and to swap the motor. I can't say enough good things about the man. And as far as power goals are concerned, anywhere north of 400awhp 400awtq.
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port Last edited by Hammology; 06-17-2015 at 05:47 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
| Not Ranked : 0 score Sweet. Looking forward to seeing this in person. |
| The Following User Says Thank You to Mattyhawk1 For This Useful Post: | Hammology (06-18-2015) |
![]() Join Date: Dec 2013 Location: Mountain House, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
| Not Ranked : 0 score Is Jordan Keefover is Overspeed Motorsports right? Just saw his facebook page yesterday, subd' to see the results...Did he do the build and install?
__________________ 2013 Mazdaspeed3 Crystal White Pearl [Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno] Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit] |
| The Following User Says Thank You to my2k13speed3 For This Useful Post: | Hammology (06-18-2015) |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Yup, he did both.
| Not Ranked : 0 score Where is he located exactly? Mind me asking what you roughly paid for the build/install? May have to take a trip down to So-cal one of these days.
Groans: 36
(Thread Starter) | Not Ranked : 0 score He is located in Long Beach. A basic build and install is $4600 with parts included. Your engine must be a good core of course.
| The Following User Says Thank You to Hammology For This Useful Post: | my2k13speed3 (06-18-2015) |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Here is a log from a new revision. Solid gains from 1lb of boost, and a few degrees of timing. Unfortunately 91oct has its limits, so im sure there isn't a ton of power left in this pump gas tune. Not to worry though. I have a DO14 nozzle on the way ![]() Vdyno 4th gear rev. 5.jpg datalog32.csv
| The Following 2 Users Say Thank You to Hammology For This Useful Post: | BLKSTIG (06-21-2015), Code Monkey (06-20-2015) |
| Not Ranked : 0 score I'm sure the D014 will really wake that up. You might try some Meth (I use 2 gallons per tank) in the tank as well. Good luck |
| The Following User Says Thank You to sheston For This Useful Post: | Hammology (06-20-2015) |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I thought about that, but if I put anything in the tank it will be E85 since a gallon of that is like a third the price of meth.
| Not Ranked : 0 score How big is the housing on the blow-thru maf?
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Hammology (06-21-2015) |
Groans: 36
| Not Ranked : 0 score You only need less than half as much Meth to get the same knock protection as E85. I like only having to get on extra fuel. Maybe I'm just lazy |
| The Following User Says Thank You to sheston For This Useful Post: | Hammology (06-21-2015) |
| Not Ranked : 0 score I use 1 gallon of meth intank for solely knock protection. I don't even tune for it.
![]() | | #19 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I'll consider it. I don't think its a bad idea. I doubt i'll have a gallon of meth to put in my tank every time i fill up.
![]() | | #20 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Took a trip to @keefover; today at Overspeed Motorsports to get some work done. He fabbed/welded my hotpipe to eliminate a coupler, did a valve cover modification, and swapped my meth nozzle thats a pain in the ass to get to. I took a 4th gear log just to make sure the meth was working as advertised, and it is. @ms3blackmica; just sent me a map that will supposedly get the bitches I iz excite.098.JPG 101.JPG 100.JPG datalog35.csv
| The Following User Says Thank You to Hammology For This Useful Post: | Koke382 (07-10-2015) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score That is a flat power curve. Load is flat and cfms are linear. I'm jealous |
![]() | | #22 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Just flashed the first meth revision today.... HORY SHEET BATMAN!
![]() | | #23 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score no VD
| V2 Pre-amp | | |
![]() | | #24 | ![]() |
Groans: 36
| The Following 2 Users Say Thank You to Hammology For This Useful Post: | BLKSTIG (07-11-2015), thepatient77 (07-15-2015) |
![]() | | #25 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Vdyno 4th gear meth.jpg datalog37.csv Im pretty sure the spike in power up top was a dip in the road, but you get the idea.
| The Following 3 Users Say Thank You to Hammology For This Useful Post: |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Took you long enough. I can now finish massaging my penis using visual simulation
| V2 Pre-amp | | |
![]() | | #27 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Lolz I need moar bewst!
![]() | | #28 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Just received a new map from Nishan targeting 26psi
| The Following User Says Thank You to Hammology For This Useful Post: | BLKSTIG (07-12-2015) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Can you get the full spool earlier or is it as good as it gets?
![]() | | #30 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score I'm not sure. @ms3blackmica; would know more about that. If I had to guess I would say a little.
| The Following User Says Thank You to Hammology For This Useful Post: | Code Monkey (07-12-2015) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score How long is the vd gonna take on this one @Hammology;
| V2 Pre-amp | | |
![]() | | #32 | ![]() |
Groans: 36
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port | |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Lol slackin
| V2 Pre-amp | | |
![]() | | #34 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
__________________ www.tunedbynishan.com | |
![]() | | #35 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Just went for a ride with the new 26psi map flashed....I spun tires in second. Haven't found a suitable road to take logs on yet. Humboldt has a lot of fun twisty mountain roads though.
![]() | | #36 | ![]() |
| Not Ranked : 0 score updates?
| V2 Pre-amp | | |
![]() | | #37 | ![]() |
Groans: 36
(Thread Starter) | Not Ranked : 0 score Car is fast as fuck. There are no roads near by to take logs on. I'll get a video of a pull next time I'm in the car.
![]() | | #38 | ![]() |
![]() Join Date: Nov 2009 Location: Vancouver, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score How do you keep any traction on the street?
__________________ COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85 Stratified Tune |
![]() | | #39 | ![]() |
Groans: 36
![]() | | #40 | ![]() |
| Not Ranked : 0 score Fair enough.....but at that power level it must be a the breaking point of shredding those tires....lol
| Built Motor MS6 | I_AINT_RICE | MazdaSpeed 3/6 - Big Turbo Builds | 87 | 05-15-2016 11:26 PM |
| built motor | blackms3_71 | Mazdaspeed3/6 General Discussion | 11 | 01-31-2013 08:19 AM |
