Like Tree13Likes
 Old 04-23-2016, 03:22 PM   #81
MSP611's Avatar
Posts: 2,291   (View Stats)
can u feel the tick in the clutch pedal when going in or out?
In progress:
 Old 04-23-2016, 06:00 PM   #82
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
No difference.
Just checked everything. Took the pan and valve cover. The noise went away for a brief minute, but as soon as it warmed up the ticking returned. I think it has to do with VVT because once oil pressure\temp increases the noise returns. I'm lost tbh
Sent from my SAMSUNG-SM-G870A using Tapatalk
I_AINT_RICE is offline   Reply With Quote
 Old 04-23-2016, 10:15 PM   #83
MSP611's Avatar
Hmmm could be vvt... positive it's not ur hpfp? They produce a ticking sound
Sent from my SM-G930V using Tapatalk
In progress:
 Old 04-23-2016, 10:17 PM   #84
Picking up a mechanic's stethoscope tomorrow to verify
 Old 04-26-2016, 10:36 PM   #85
Sounds like it's coming from the timing chain area. Purchased a new oil control valve, should be in tomorrow. Cross your fingers!
 Old 05-07-2016, 06:37 PM   #86
Just an update, the timing chain is loose. Found marks on the inside of the valve cover from contact. Just missed them the first time through. I'll be purchasing a new chain and actuator in the next couple days. Been crazy busy with finals so the car has been just sitting around for the past 2 weeks.
Any reason to purchase anything more than the crank bolt, actuator and chain? Motor has ~30k on build
 Old 05-10-2016, 01:57 PM   #87
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
friction washer if not keyed ? cams bolt/washer if needed to be removed.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-15-2016, 11:26 PM   #88
Just a little update..
Took off the TC and looks like the tensioner failed. Parts will be here tomorrow so cross your fingers!!
On other news, here's some future plans:
-Switch out the shitty push fittings for the meth.
-Purchase a controller from Splitsecond for the meth.
-Switch to Versatune.
-Install headunit that can be utilized for gauges.
-purchase the rest of the shit I need for custom coils.
At the moment, I'm consistently make ~500whp @ 7k Elevation (Flagstaff AZ). Hopefully will be producing high 500s to 600 at sea level!!
The Following 3 Users Say Thank You to I_AINT_RICE For This Useful Post:
BLKSTIG (06-18-2016), DingoDave (06-21-2016), SpeedRebirth (05-16-2016)
Built motor and BNR V2 MattyP617 2010 MS3 - Big Turbo Builds 9 03-05-2015 08:57 PM
Built motor.....?.? Matx MazdaSpeed 6 - Engine, Transmission & Driveline 17 06-25-2012 06:15 PM
Page generated in 0.28630 seconds with 23 queries
