 Old 06-03-2011, 09:25 PM   #1
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Default Burn813's 3071r Build
So here we go.... I guess I am jumping on the wagon and building a 3071r grocery-getter..... As soon as I get home I will post up some pics of stuff I have gotten so far and i will be posting pics and before and after dyno sheets
Kyle
2008 MS3 gt
470hp/463tq on GT35r at 29psi
The Following 12 Users Say Thank You to burn813 For This Useful Post:
4G63 (06-04-2011), aaronc7 (06-04-2011), AZSPEED3 (06-04-2011), Ckmazdaspeed3 (06-04-2011), djuosnteisn (06-08-2011), dougefresh_ (06-29-2011), IshiKage (06-04-2011), jwilkins88 (06-06-2011), PunjabiPlaya (06-04-2011), Speed3eak (06-04-2011), xhymer (06-03-2011), zpele (06-23-2011)
 Old 06-03-2011, 09:27 PM   #2
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
bolt on 3071? Or t-3/v-band?
 Old 06-04-2011, 06:53 AM   #3
lulz @Raider
burn813's Avatar
It is going to be a t/3 vband with a 5bolt adapter
2008 MS3 gt
 Old 06-04-2011, 11:45 AM   #4
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
If i had the money i would do the same
good luck with build
surebOOst is offline   Reply With Quote
 Old 06-04-2011, 11:50 AM   #5
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
burn813 says, "and I'd like to thank ckmazdaspeed3 for twisting my arm and making me spend all this fucking money"!
Jedyboyrokr likes this.
The Following 3 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
burn813 (06-22-2011), djuosnteisn (06-08-2011), jwilkins88 (06-06-2011)
 Old 06-04-2011, 12:24 PM   #6
lulz @Raider
burn813's Avatar
Thank is one way of putting it.... Lol
2008 MS3 gt
The Following 2 Users Say Thank You to burn813 For This Useful Post:
 Old 06-04-2011, 12:47 PM   #7
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Can't wait to join the fun Kyle could u compile a list of all parts etc you'll be using. I've been researching and it seems im gonna have to go custom intake, MAF, fabbed downpipe etc. Thanks bud
Hey Keith I texted u yesterday man not sure if u got it or just didn't want to respond hit me back when u get a chance man!
2003 Evo VIII
 Old 06-04-2011, 01:26 PM   #8
lulz @Raider
burn813's Avatar
So far I am working with:
Gt3071r w/ t3 hotside (going to have to get a 5bolt to t3 flange)
38mm tial ewg
Grimspeed ebcs
Steedspeed t3 38mm exhaust mani
I think I will need a 3 in to 4 in coupler for my short ram.....
I think that may get me started.... I will have to do an inventory and make sure I have everything I need
If anyone reading can think of other stuff I may need.... Please let me know.... I just love blowing money
2008 MS3 gt
4G63 (06-04-2011)
 Old 06-04-2011, 01:41 PM   #9
4G63's Avatar
Groans: 123
Haha nice! Which downpipe are u running? I have a TurboXS and I know I'll need either a new one or an adapter like your gonna run thought I remember u saying u had a TurboXS. Lmk if u ever need help man I'm not that far away and I'm an extra set of hands if u need em!
2003 Evo VIII
 Old 06-04-2011, 01:46 PM   #10
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
I'm confused by what you mean by "5 bolt to t3 flange." The only thing that t3 means is where it connects to the manifold. I believe you are talking about this: T3 5 bolt (Ford style) Turbine Housing for GT Turbo : atpturbo.com
Are you thinking of getting a 5-bolt to v-band adapter?
You'll need coolant fittings: 14mm Banjo Fitting Set for coolant lines - 3/8" Barb : atpturbo.com
Oil inlet with restrictor: -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
90* swivel so the feed line isn't sticking straight up: Fitting, Swivel, #4AN Flare, Male to Female, 90D : atpturbo.com
A couple of oil drain flanges (one for turbo, one for block): Oil Return Flange with integrated -10 Flare for GT15 Through GT35R : atpturbo.com
Oil drain hose: http://www.atpturbo.com/mm5/merchant..._Code=ATP-OIL1
Fitting for block oil drain: http://www.jegs.com/i/Russell/799/624100/10002/-1
Fitting for turbo oil drain: http://www.jegs.com/i/Earl%26%23039%...00111/10002/-1
The oil drain stuff is just a suggestion. You can get a custom length stainless steel braided line if you like and not run push-lok fittings.
2007 CTS-V - Trying to sell
 Old 06-04-2011, 02:48 PM   #11
lulz @Raider
burn813's Avatar
It's something more like this http://www.atpturbo.com/mm5/merchant..._Code=ATP-FLS2
I am sure I am going to need moar stuff..... Thanks Myles for giving me some things to think about
2008 MS3 gt
 Old 06-04-2011, 02:49 PM   #12
lulz @Raider
burn813's Avatar
Turboxs downpipe, racepipe and hks Like yours
2008 MS3 gt
4G63 (06-05-2011)
 Old 06-04-2011, 02:50 PM   #13
bmylez's Avatar
Groans: 31
Can you take a pic of your hot side?
 Old 06-04-2011, 02:53 PM   #14
lulz @Raider
burn813's Avatar
This is the one I bought
2008 MS3 gt
 Old 06-04-2011, 03:02 PM   #15
bmylez's Avatar
Groans: 31
Alright, you have me more confused, haha. That hot side has a v-band flange...why don't you want to keep it? Not to mention, if you try to add a flange to v-band, it's going to stick out really far.
 Old 06-04-2011, 03:06 PM   #16
lulz @Raider
burn813's Avatar
Cause I have a 5 bolt downpipe and I am a cheapass.... I want to keep my dp and have the t3 hotside for the steedspeed mani I bought
2008 MS3 gt
 Old 06-04-2011, 03:28 PM   #17
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
tial mvs + t3 hotside, cmon now
 Old 06-04-2011, 04:17 PM   #18
bmylez's Avatar
Groans: 31
Just so you know, the link to the 5-bolt adapter you posted is NOT the Mazda 5-bolt style.
You need this: Steel - GT25/GT28R/GT28RS & T25/T28 Disch Flange : atpturbo.com
 Old 06-04-2011, 05:39 PM   #19
lulz @Raider
burn813's Avatar
Of course I may just end up buying a v band downpipe ..... I don't know..... I will have to figure it all out
2008 MS3 gt
 Old 06-04-2011, 05:52 PM   #20
Speed3eak's Avatar
Groans: 82
I've been curious about doing a t3/5 bolt mazda flange, but I didn't think anybody made them. Can't you just get the v-band downturn part and have someone weld it onto your existing downpipe? Maybe the one leen is making?
 Old 06-04-2011, 06:10 PM   #21
bmylez's Avatar
Groans: 31
NOBODY makes a T3 with Mazda 5 bolt. You are correct.
 Old 06-04-2011, 06:21 PM   #22
lulz @Raider
burn813's Avatar
That may be what I do..... There is a guy here in st Louis that makes magic happen with exhaust stuff
2008 MS3 gt
 Old 06-04-2011, 07:05 PM   #23
Groans: 134
Yeah Kyle, you should call matt at Htp and see what he can do, I'm sure it will be pretty cheap... Get a proper t3 set up, that would be great!
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
burn813 (06-22-2011), Speed3eak (06-04-2011)
 Old 06-04-2011, 07:14 PM   #24
spnkr21's Avatar
Posts: 2,827   (View Stats)
All you gotta do is chop of the bellmouth and have someone that can Tig add a v-band. It's pretty simple.
2012 WRX HB w/mudflaps yo!
The Following 4 Users Say Thank You to spnkr21 For This Useful Post:
burn813 (06-22-2011), djuosnteisn (06-08-2011), manelscout4life (06-13-2011), Speed3eak (06-04-2011)
 Old 06-04-2011, 07:19 PM   #25
lulz @Raider
burn813's Avatar
That is exactly what I am planning on doing and Karl errr I mean Keith, I was planning on calling him.... That is who I was talking about in an earlier post
2008 MS3 gt
Ckmazdaspeed3 (06-05-2011)
 Old 06-06-2011, 09:52 AM   #26
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
Ok... So... Lots of bullshit going on here...
Brian - He doesn't need half that shit you posted up. He would need that if he were making his own lines for the turbo, but you should be able to just reuse most the stock lines.
What you need for the adapter is this backwards - V-band Module, Stock Mazdaspeed6 Turbo to 3" V-band : atpturbo.com
Or you could just buy a vband flange and have it welded on your downpipe... I'm sure that wouldn't take long, and there wouldn't be much downtime.
 Old 06-06-2011, 10:14 AM   #27
lulz @Raider
burn813's Avatar
I will get together with you soon Joel and we will talk about the thingys I need
2008 MS3 gt
 Old 06-06-2011, 10:33 AM   #28
Speed3eak's Avatar
Groans: 82
If you haven't bought the exhaust mani yet, you could go with a twin-scroll t3 setup...
.78 A/R Divided T3 Exhaust housing for GT Ball Bearing Series : atpturbo.com
yes yes y'all
 Old 06-06-2011, 10:52 AM   #29
lulz @Raider
burn813's Avatar
yes yes y'all
Already working the steedspeed mani
2008 MS3 gt
 Old 06-06-2011, 11:03 AM   #30
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
My mani and EWG ship tomorrow.
sellers is offline   Reply With Quote
 Old 06-06-2011, 11:40 AM   #31
lulz @Raider
burn813's Avatar
Nice!
2008 MS3 gt
 Old 06-06-2011, 11:41 AM   #32
sellers's Avatar
Groans: 546
 Old 06-06-2011, 11:41 AM   #33
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Good luck man
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 06-06-2011, 11:49 AM   #34
Groans: 134
yes yes y'all
So it doesn't matter to Kyle as he already has a mani coming, but I was under the impression that a twin scroll only really benefited a twin scroll turbo?
Am I mistaken?
burn813 (06-22-2011), jwilkins88 (06-06-2011)
 Old 06-06-2011, 01:05 PM   #35
spnkr21's Avatar
You're correct
 Old 06-06-2011, 01:47 PM   #36
lulz @Raider
burn813's Avatar
You're correct
#x202aBilly Madison "That is correct"&#x202c‏" target="_blank">YouTube - &#x202aBilly Madison "That is correct"&#x202c‏
2008 MS3 gt
 Old 06-06-2011, 02:14 PM   #37
Groans: 50
Lol I miss Chris Farley
08 Mazdaspeed 3
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
burn813 (06-22-2011), ScarMS3 (06-23-2011)
 Old 06-06-2011, 03:00 PM   #38
jwilkins88's Avatar
Groans: 126
I think NATOR MO is about to have the most big turbos of any NATOR... Exciting shit.
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
burn813 (06-22-2011), Ckmazdaspeed3 (06-06-2011)
 Old 06-06-2011, 03:10 PM   #39
lulz @Raider
burn813's Avatar
My balls are tingly..... I have been driving the wifes ms6 for the week an got to drive mine yesterday and today.... Such a difference in powa and I can't wait till I have just that much moar!
2008 MS3 gt
 Old 06-06-2011, 03:20 PM   #40
Speed3eak's Avatar
Groans: 82
Am I mistaken?
Yeah, the link is for a twin scroll hot side for the 3071 - I was under the impression that a TS exhaust housing + a twin scroll mani was all you needed for some TS goodness? Or are there other things too?
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Page generated in 0.58933 seconds with 30 queries
