 Old 07-14-2011, 07:31 PM   #1
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Default can you utilize and internal AND external wastegate?
i've been thinking about doing a 3076r swap for a while now and i have a question. i am leaning toward the direct bolt on from street unit but i am nervous about internal wastegates on a bigger turbo. i know there were boost creep problems before and i don't want to run into those problems.
could i run a steedspeed stock mount mani with a 38mm ewg along with the normal iwg from on the bolt on?
or would the iwg that comes with the bolt on be enough wastegating powa
 Old 07-14-2011, 08:48 PM   #2
ckahler666's Avatar
Posts: 212   (View Stats)
ckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the world
You could get the bolt on turbo and weld the iwg shut so you can use the ewg. I'm pretty sure you can't use both simultaneously.
Eat glass nigga!!!!
ckahler666 is offline   Reply With Quote
 Old 07-14-2011, 09:29 PM   #3
TWOptSL0W's Avatar
Groans: 125
well the plan as of now is bolt on with stock mani and then IF i get creep (which i hope i dont) i might get a steedspeed mani with ewg. i know you can run 2 ewg's but i'm not sure if you can use an internal and external
also, while it obviously isnt ideal, is the stock mani and all that shit ok with the 3076? i know its a "bolt on" but is fitment still okey dokey?
For all the external wastegate guys. Jessed87 MazdaSpeed 3/6 - Turbo Induction 18 05-08-2010 02:49 PM
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
External Wastegate Mazdaspeeds... all4bspinnin MazdaSpeed 3/6 - Turbo Induction 19 10-23-2009 02:07 PM
the ultimate internal wastegate cbspeed3 MazdaSpeed 3/6 - Turbo Induction 2 09-12-2008 02:40 PM
Page generated in 0.23391 seconds with 21 queries
