| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
(Thread Starter) | Not Ranked : 0 score 6031 (60-1 compressor wheel 61 lbs flow min/t31 turbine wheel) - $625 brand new with custom compressor cover and water jacket. 4 inch intake w/ honey comb+ amsoil filter = $120 hard parts (pipe, maf flange, honey comb) $40 for welding/fabbing pg manifold rewelded t3 = $325 manifold, $15 flange, $20 for weld FMIC china = $100 pipes, $100 core, $80 assorted couplers/pipes, $40 weld/fab oil lines coolant lines = $40 -4an feed line, $40 fittings/adapter plate, $20 coolant lines + fittings from pepboys external waste gate emusa w/ 21 psi tial springs = $50 wg, $15 spring grimspeed mbc = $100 injector seals + map sensor = $175 cp-e, $75 3 bar map sensor prices rounded up because racecar grand total = 2000 forgot to add meth kit (labonte isg-25) = $525 grand total = 2525
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" Last edited by dooderek; 05-30-2012 at 12:15 PM. |
| The Following 5 Users Say Thank You to dooderek For This Useful Post: | ESB Jiu JItsu (08-03-2012), Lex (05-30-2012), lilred (05-30-2012), phate (06-25-2012), stp (05-31-2012) |
![]() Join Date: Mar 2012 Location: San Luis Obispo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score Helpful list, thanks! Tappin'
__________________ 2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB 2008 Mazdaspeed3- Totalled! |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score That's great of you to share the info Daddy. I was curious about a few of the options you had opted for but your making great power for 2 grand.. And i think youre smart to not push it much more without building it right first. That's great of you to share the info Daddy. I was curious about a few of the options you had opted for but your making great power for 2 grand.. And i think youre smart to not push it much more without building it right first.
__________________ Last edited by helmetface; 05-30-2012 at 12:03 PM. Reason: MSF Database - Automerged Doublepost |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score I'm happy for you dude, you got it done.
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score Thats a nice round up of parts for around 2large. Not bad for a output over 400whp
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score AWESOME BRO!
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
| Not Ranked : 0 score wtf no picts? phail!
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score Should have gotten the Toyota injector seals for even more China savings.
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
| The Following User Says Thank You to Karmat For This Useful Post: | Angr-E1 (05-30-2012) |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,852
Groans: 165
| Not Ranked : 0 score Good shit man I wish my car would play nice considering what i have put in it, oh how much for fire manifold?
__________________ New....Camaro SS/RS Stocked out selling parts.2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
| Not Ranked : 0 score Derek, does your labonte kit have a failsafe output? Hook it up to the GA if it does.
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
| Not Ranked : 0 score sick shit bro
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
| VVT Fix Notes and Observations | tkephart | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 12-28-2011 11:29 AM |
| Final dealer arbitration case today; final rulings due within 10 days | Haltech | Automotive News | 0 | 07-14-2010 01:30 PM |
| Abs vs Req Load in ATR + ECU Function Notes | FORZDA 1 | Cobb ATR Support | 44 | 02-15-2010 10:02 AM |
| v1.03 Map Notes? | BlackT5 | Cobb Access Port/Maps | 3 | 02-15-2009 08:24 PM |
