Like Tree8Likes
 Old 09-20-2011, 03:49 AM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default Chinkus Maximus
hey guys, trying to keep this thread as clean as possible till i finish. i would prefer if you guys need to ask questions do it via pm or in the Chinkus Spinnius thread, aswell as instead of posting "subbed" just use the thread tools, however i expect opposite considering i would do the same.
as of tonight operation chinkus maximus went into effect. pulled everything off mani/dp/turbo. did some comparisons getting ready to weld up the pg mani and ewg to it.
snap a quick comparison pic. also to note for the godspeed gt3076 STOCK OIL/COOLANT LINES FIT, minus the drain. so even easier day with this install, i went ahead and test fitted the turbo and the coldside clears which was what i was concerned about at the time. also im gunna re wrap the mani once everythings said and done.
all gone, the pen is what i used to plug the coolant line lol
one thing to mention though, adding food coloring to my meth was probaly the best idea ive ever had on this car. as you can see, meth evaporates, food coloring doesnt. which leaves a very fine blue powder, and itll show you pretty much where the air its in is traveling as seen in these pictures.
my k04 fins are a bit coated so i presume i was getting some amount of compressor surge considering my nozzle is located on the tmic's cold pipe.
here it shows were it ate through my gasket, causing a boost leak
here i assume it was blowing past the coupler. which means, man ive been running with even more boost leaks lol
heres the mani ready to get re flanged
K7addict likes this.
The Following 18 Users Say Thank You to dooderek For This Useful Post:
aaronc7 (09-23-2011), AJ713 (10-03-2011), breakfstincluded (10-02-2011), Chimmike (09-25-2011), djthom (09-20-2011), djuosnteisn (09-20-2011), doubleflusher (09-25-2011), dougefresh_ (09-20-2011), Downmented (01-12-2012), Easter Bunny (09-20-2011), h.h.sk1nny (11-23-2011), i8urgti (09-24-2011), IshiKage (09-23-2011), K7addict (09-20-2011), Neverlift (09-30-2011), rigor (11-22-2011), Scribbles (09-22-2011), TexasSpeed3 (09-30-2011)
The Following 2 Users Say NO Thank You to dooderek For This Un-useful Post:
manelscout4life (09-26-2011), spnkr21 (09-26-2011)
 Old 09-20-2011, 01:19 PM   #2
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Subbed.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
 Old 09-20-2011, 01:21 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
tell them about how retarded you are and you would have ended up putting the CHRA upside down if i hadnt skooled you.
i was high btw....
u fucken suck derek....but u are likeable .....so
subbed
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
djuosnteisn (09-20-2011), rigor (11-22-2011)
 Old 09-20-2011, 01:35 PM   #4
wankular's Avatar
Posts: 4,343   (View Stats)
Food coloring in the meth? That doesn't fuck anything up?
2009 MS3 sport MGM
 Old 09-20-2011, 01:38 PM   #5
Hoangy's Avatar
Posts: 344   (View Stats)
Hoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the world
I don't think so brah. it's a good idea to check for leaks and such, essentially a paper trail.
Hoangy is offline   Reply With Quote
The Following User Says Thank You to Hoangy For This Useful Post:
wankular (09-20-2011)
 Old 09-20-2011, 01:57 PM   #6
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
or just use a match and u can use fire as a trail
The Following 7 Users Say Thank You to rodrigo For This Useful Post:
aaronc7 (09-23-2011), Abu Zib (10-04-2011), Darksun280 (09-25-2011), djuosnteisn (09-20-2011), Hoangy (09-20-2011), rigor (11-22-2011), zpele (09-21-2011)
 Old 09-20-2011, 01:59 PM   #7
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
 Old 09-20-2011, 02:08 PM   #8
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
Subbed
DONOTBUGME is offline   Reply With Quote
 Old 09-20-2011, 06:54 PM   #9
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Second threads of same project are for faggots!!
Beanfab / Tuned by Nishan
The Following 2 Users Say Thank You to doubleflusher For This Useful Post:
Dash08 (09-24-2011), manelscout4life (09-20-2011)
 Old 09-21-2011, 10:33 AM   #10
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
You should post this in his new thread.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
dougefresh_ (09-22-2011)
 Old 09-21-2011, 11:04 AM   #11
Groans: 1,443
Done.
Dash08 (09-24-2011), dougefresh_ (09-22-2011)
 Old 09-22-2011, 08:56 PM   #12
2zz mr-s
dooderek's Avatar
Groans: 239
manifold ready to go
t25
wg
bolted up
went to go dry fit it, and then i was like oops because i pretty muched eyeballed the ewg location, and it was close to meh hoses
but then i realized the manifold wasnt flat against the block, slant eyed ftw
The Following 11 Users Say Thank You to dooderek For This Useful Post:
AJ713 (10-03-2011), BPASPEED (09-23-2011), djuosnteisn (09-23-2011), doubleflusher (09-23-2011), dougefresh_ (09-22-2011), GLORIFIEDBOZO (09-22-2011), Hoangy (09-23-2011), josurr (09-22-2011), Neverlift (10-01-2011), rigor (11-22-2011), Scribbles (09-22-2011)
 Old 09-23-2011, 01:33 PM   #13
Captain
#winning
www.permtuning.com
 Old 09-24-2011, 11:24 AM   #14
2zz mr-s
dooderek's Avatar
Groans: 239
look what came in today! thanks crazyp!!!!!
bolted up to the turbo
testing fitting against the block, my hot pipe for the ic is going to be interesting, gunna need some 90 degree elbow bends lol
all bolted up
old oil return cut
new one using the cut peices. running some heater hose into the cast iron portion of the stock return line
The Following 10 Users Say Thank You to dooderek For This Useful Post:
aaronc7 (09-28-2011), AJ713 (10-03-2011), crazyp (09-24-2011), djuosnteisn (09-26-2011), doubleflusher (09-25-2011), dougefresh_ (09-30-2011), GLORIFIEDBOZO (09-24-2011), IshiKage (09-25-2011), rigor (11-22-2011), zpele (09-24-2011)
 Old 09-24-2011, 11:39 AM   #15
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Good lookin build!! Are you using any boost controller?
I am going to be doing the same with my pg manifold and have it reflanged glad it worked out! Also your wastegate tube, is that the bend for the wastegate that atp sells? Because I was going to have that welded to my pg mani as well. Where did you get your vband dp? I am on the hunt for one.
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 09-24-2011, 11:41 AM   #16
2zz mr-s
dooderek's Avatar
Groans: 239
they sell vband dps on ebay, not sure if they make em for the 3 though. my screamer pipe was custom fabbed and ill be running a grimspeed for bcs
 Old 09-24-2011, 11:48 AM   #17
EL F00LI0's Avatar
Me=Fail. Didnt notice your ms6 in your avatar. Where did you have your mani reflanged? All the exhaust shops I have called didnt speak good english and didnt understand what I wanted lol...I'll take the drive down to oceanside for the day if its down there.
 Old 09-24-2011, 12:44 PM   #18
jonlax's Avatar
Posts: 312   (View Stats)
jonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the world
My buddy ran that turbo for 4 months on his turbo2 Rx7 while his GT35 was getting reubilt and replaced. Work'd ok but had a few little problems.
Good luck with the build.
jonlax is offline   Reply With Quote
 Old 09-24-2011, 03:14 PM   #19
2zz mr-s
dooderek's Avatar
Groans: 239
richards performance muffler awesome place, do all my welding there
The Following User Says NO Thank You to dooderek For This Un-useful Post:
 Old 09-24-2011, 03:45 PM   #20
bewsted's Avatar
Posts: 2,456   (View Stats)
Why dont you clock the comp housing more toward the block son.
EWG K04...GETSUM!
 Old 09-24-2011, 03:48 PM   #21
2zz mr-s
dooderek's Avatar
Groans: 239
hits runner 1, i have to clock it towards the firewall
 Old 09-24-2011, 08:42 PM   #22
bewsted's Avatar
thats retarded.....I have mine on the stock mani its straight up....close to mani but i can fit a coupler and clamp on it for sure.
EWG K04...GETSUM!
 Old 09-24-2011, 10:58 PM   #23
2zz mr-s
dooderek's Avatar
Groans: 239
gotta pay to play son
 Old 09-25-2011, 12:25 PM   #24
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Don't use heater hose for the oil return. Oil and the heat around it is gonna destroy that stuff pretty quick.
07 MS3
The original Genpoo Hater
 Old 09-25-2011, 12:33 PM   #25
m4tic's Avatar
Posts: 4,928   (View Stats)
man, and you gotta do this all over again (read pay all over again) when that turbo fails... should be fun though
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 09-25-2011, 02:56 PM   #26
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
yeah, heater/rubber hose isn't gonna last long. I used it for my water lines on the miater....they failed a few thousand miles later. I'm sure if I would have heatshielding them some, it would have helped, but it's gonna happen sooner or later. I use some high temp silicone for my oil return...works great. Gonna get the same stuff for my water lines next.
 Old 09-25-2011, 07:44 PM   #27
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
I'm surprised that heater hose failed when it was used for its intended purpose. I am planning on doing a custom heater hose and deleting that stupid hard line that hits my compressor...but now you've got me worried. I guess I'll have to drop $25 on 5 ft of silicone hose to make sure.
2007 CTS-V - Trying to sell
 Old 09-25-2011, 04:59 PM   #28
bmylez's Avatar
Groans: 31
Yep, high temp siricone is mush better: 5/8" BLACK SILICONE HOSE HEATER HOSE HI-PERFORMANCE | eBay
 Old 09-25-2011, 07:17 PM   #29
2zz mr-s
dooderek's Avatar
Groans: 239
no doubt the turblow woulda failed asap if i not had it rebalanced. but on the same note, suck it b. thanks for the advice on the hose, i use to run regular pepboys heater hose on my rexus and never had any issues but might as well go the extra mile just incase shit
The Following User Says Thank You to dooderek For This Useful Post:
Chimmike (09-29-2011)
 Old 09-26-2011, 12:06 PM   #30
Groans: 661
Whos dick did you suck to become orange?
The Following 2 Users Say Thank You to manelscout4life For This Useful Post:
Chimmike (09-29-2011), dougefresh_ (09-29-2011)
 Old 09-26-2011, 09:50 PM   #31
2zz mr-s
dooderek's Avatar
Groans: 239
The Following 4 Users Say Thank You to dooderek For This Useful Post:
djuosnteisn (09-29-2011), dougefresh_ (09-29-2011), jracer (09-27-2011), rigor (11-22-2011)
 Old 09-28-2011, 01:47 AM   #32
2zz mr-s
dooderek's Avatar
Groans: 239
dougefresh_ likes this.
The Following 2 Users Say Thank You to dooderek For This Useful Post:
dougefresh_ (09-29-2011), jracer (09-28-2011)
 Old 09-29-2011, 12:46 PM   #33
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Originally Posted by Derek Doo View Post
"I broke them cuz I'm Chinkus, and I fuck shit up" LOL
Chinkus says fuck 31 times in that video
The Following 5 Users Say Thank You to dougefresh_ For This Useful Post:
AJ713 (10-03-2011), BigjohnB20 (09-29-2011), djuosnteisn (09-29-2011), jracer (09-29-2011), rigor (11-22-2011)
 Old 09-29-2011, 12:03 PM   #34
Captain
Holy mind fuck....
after watching all these videos, i stood up and started wandering around my cubicle muttering to myself about shit i have to do.... and picking things up and putting them down... and thrashing through my desk looking for something, but not finding it... then wandering off to a different corner... and finding something different to mutter about....
Dude, i think your ADHD officially trumps my own.
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
AJ713 (10-03-2011), BigjohnB20 (09-29-2011), Chimmike (09-29-2011), dougefresh_ (09-29-2011), Jeremy M (10-03-2011), jracer (09-29-2011), rigor (11-22-2011)
 Old 09-29-2011, 02:05 PM   #35
2zz mr-s
dooderek's Avatar
Groans: 239
Lol ive never noticed it
The Following 3 Users Say Thank You to dooderek For This Useful Post:
djuosnteisn (09-29-2011), dougefresh_ (09-29-2011), jracer (09-29-2011)
 Old 09-29-2011, 02:23 PM   #36
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
I wanted to see what doug and dusting were talking about so I went and watched that last video. LOL, after your guy's comments I was litterally laughing out loud in my cube.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following 5 Users Say Thank You to BigjohnB20 For This Useful Post:
djuosnteisn (09-29-2011), dougefresh_ (09-29-2011), jracer (09-29-2011), Neverlift (09-30-2011), rigor (11-22-2011)
 Old 09-29-2011, 05:42 PM   #37
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
LOL, BTW what core is that I cant wait to see it installed
 Old 09-30-2011, 12:09 AM   #38
2zz mr-s
dooderek's Avatar
Groans: 239
The intercooler is like 31 inches long from end to end, its a cxracing one
 Old 09-30-2011, 07:07 AM   #39
Chinkus, I like your videos, and I took the liberty of condensing the more important aspects of the build into one, short 39 second video:
The Following 10 Users Say Thank You to dougefresh_ For This Useful Post:
AJ713 (10-03-2011), Alpha (12-29-2011), andrewpiro (10-02-2011), Chimmike (09-30-2011), djuosnteisn (09-30-2011), Frequentflyer (11-12-2011), h.h.sk1nny (11-12-2011), laxplayermjd (11-20-2011), rigor (11-22-2011), zatara (10-10-2011)
 Old 09-30-2011, 01:50 PM   #40
Captain
I wanna thank that post 15 times. OMG doug, riots in my belly from giggling.
www.permtuning.com
dougefresh_ (09-30-2011), rigor (11-22-2011)
Chinkus Spinnius dooderek MazdaSpeed 3/6 - Big Turbo Builds 55 10-14-2011 04:08 PM
Page generated in 0.71298 seconds with 39 queries
