![]() | | #81 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| The Following 4 Users Say Thank You to driver311 For This Useful Post: |
![]() | | #82 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score Do you anticipate a compromise in power/efficiency using a 2.5" TIP vs. something bigger?
__________________ '07 CWP MS3 Forged. |
| The Following User Says Thank You to BlueStreak For This Useful Post: | wolly6973 (10-21-2011) |
![]() | | #83 | ![]() |
Obviously, having a little more pressure drop in the intake makes the compressor operate at a higher pressure ratio (and this typically means hotter discharge temp) for the same boost/massflow; however, this turbo can flow 55lbs/min, which is way more than I will ever need. Also between the FMIC and meth, I doubt I will have too many concerns about BAT going up due to somewhat elevated compressor discharge temps that will result from the non-optimal TIP.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following 2 Users Say Thank You to cld12pk2go For This Useful Post: | BlueStreak (10-21-2011), wolly6973 (10-21-2011) |
![]() | | #84 | ![]() |
| Not Ranked : 0 score Personally I believe it will be just fine. In fact I believe it so much that I plan on switching from my cpe 4in inlet to a atp 3in one. I just like the idea of having the exact same size all the way to the turbo and the same going out. I also like the idea of a hard pipe vs the soft cpe one. The cpe one is nice for trying to get on. A 4in hard pipe would be difficult at minimum.
| The Following 2 Users Say Thank You to driver311 For This Useful Post: | BlueStreak (10-21-2011), wolly6973 (10-22-2011) |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score Updates in posts 3/5.
| The Following User Says Thank You to cld12pk2go For This Useful Post: | wolly6973 (10-22-2011) |
![]() | | #86 | ![]() |
| Not Ranked : 0 score Call mark he will get you the 14psi spring. Mine came that way also. Apparently you have to request it now cause thats what atp has more of laying around. Stupid. Mine hooked straight to a boost source sees 15psi. Good write up man. Looks to be coming along just fine. Did you soak the header wrap in water before install? It looks like you didnt but maybe its the pics. Putting it in water allows for it to stretch and then when it dries it shrinks real tight and clean looking. Again nice work. I cant wait to see what kind of results you get. This turbo is no joke and got popular real quick.
| The Following User Says Thank You to driver311 For This Useful Post: | wolly6973 (10-22-2011) |
![]() | | #87 | ![]() |
I will shoot Mark an PM. I did soak the header wrap back in 08. However, it has a little wear and tear over the past few years.
![]() | | #88 | ![]() |
| Not Ranked : 0 score Oh I see. It just looked new to me and not tight, but now I see what you are saying.
![]() | | #89 | ![]() |
| Not Ranked : 0 score Yes I checked the part number. Its the 10psi wg. Same shit I got and the reason that those gtx3076 owners are having issues also Id bet money
![]() | | #90 | ![]() |
That is hella lame. I don't mind having to get coolant hoses and stuff so much but incorrect WGA spring pressure isn't a small issue.
![]() | | #91 | ![]() |
| Not Ranked : 0 score No and will need to be addressed before any tuning. Mark got me mine in 3 days. Its easy to swap in the car also. From under the car it literally takes 10min.
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, looking at the pics it doesn't seem like it will be overly difficult to get at. Oh well, just another item to add to my to do list.
| The Following User Says Thank You to cld12pk2go For This Useful Post: | wolly6973 (10-24-2011) |
![]() | | #93 | ![]() |
(Thread Starter) | Not Ranked : 0 score moved to post 4
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 10-23-2011 at 08:05 AM. |
![]() | | #94 | ![]() |
(Thread Starter) | Not Ranked : 0 score EGT install updates in Post 4. New logs posted in Post 5. Starting to get some power now...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 10-23-2011 at 10:54 AM. |
![]() | | #95 | ![]() |
(Thread Starter) | Not Ranked : 0 score 433whp VD plot added to Post 5... Things are starting to get interesting...
![]() | | #96 | ![]() |
| Not Ranked : 0 score when you were doing the hardline, did you line up the oil feed banjo with the hole in the CHRA to see if it would even fit? when i was doing @vbt101's, it was a PITA to get them to line up all while keeping the washers in there but i was finally able to do it. when i was doing my own however, i had to grind down the hotside bolt like you did. but i also ordered a T3 3076 and swapped to the ATP hotside so that may have been it. also we never had a problem with the drain line. i do agree it was pretty long but you should have attached it to the CHRA first and then bent it to mate with the block. after we did this it fit perfectly with the exception of having a huge bend in the hose rather then a nice smooth transition. issues like these are exactly why i made that huge fuss with @eric@edgeautosport a while back about the ATP kit not being 100% bolt on.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Broxer (10-24-2011), cld12pk2go (10-24-2011) |
![]() | | #97 | ![]() |
Initially the oil drain was attached to the turbo's CHRA, and the line was so long that I would have had to severely kink it to make it attach to the block. I tried forcing it before realizing it was simply a no-go. Actually, even the 2.25'' shorter line had to be forced to fit since it was still in a bind somewhat. "Flex hose" is a very relative term and short, thick "flex" hoses really aren't very flexible (i.e. they have a large bending radius), which is why the oil drain is such a PITA if the length isn't right to within a fairly tight tolerance. Yeah, it is 100% bolt-on....if you don't mind the ~5-6 issues of the "non-bolt on" variety. ![]() Seriously, ATP could resolve most of these very, very simply to make this a true bolt on.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 10-24-2011 at 04:36 PM. | |
| The Following 4 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #98 | ![]() |
| Not Ranked : 0 score I had none of those issues. The extra length in mine wasnt an issue and everything bolted right up. So strange that some have issues.
| The Following User Says Thank You to driver311 For This Useful Post: | cld12pk2go (10-24-2011) |
![]() | | #99 | ![]() |
Groans: 31
| Not Ranked : 0 score It's simply bad quality control. Which is sad coming from ATP.
![]() | | #100 | ![]() |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score Thanks cld for the awesome write up and taking all those pics during the install. Wouldn't take much for this to be a how to lol.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
| The Following 3 Users Say Thank You to Broxer For This Useful Post: |
![]() | | #101 | ![]() |
More logs added to post 5. Time to increase load targets more...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 10-24-2011 at 05:06 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #102 | ![]() |
Groans: 31
| Not Ranked : 0 score Alright, so a lot of people say VD is quite accurate. I haven't used it before...but is it really supposed to measure whp or at the crank? You have 297whp in your sig with k04...yet VD shows 358. Looks like crank to me.
![]() | | #103 | ![]() |
My sig dyno was from March 2010, before running E85, before the load cap was eliminated, and before my adding more boost and a shit-ton of timing. Dyno link: http://www.mazdaspeedforum.org/forum/foru...66-9wtq-53665/ The fact that my 1.5 year old dyno and my VD Dyno plots from logs in the past few months are very different is not in the least surprising...
| The Following User Says Thank You to cld12pk2go For This Useful Post: | wolly6973 (10-25-2011) |
![]() | | #104 | ![]() |
Groans: 31
| Not Ranked : 0 score 358 is still very steep for k04 on e85. That's probably more than Clint is making, haha.
![]() | | #105 | ![]() |
I tried to dyno ~2 weeks before the K04 died to try to substantiate the VD data; however, the Dyno guy was out of town and I didn't get another chance prior to the turbo pronouncing its demise with a epic shriek.
![]() | | #106 | ![]() |
| Not Ranked : 0 score remember that clint has VERY limited mods. cld12pk is fully bolted so it all adds right up to me....
| The Following User Says Thank You to superskaterxes For This Useful Post: | wolly6973 (10-25-2011) |
![]() | | #107 | ![]() |
Groans: 31
| Not Ranked : 0 score Yeah but dude...we're talking about a bone stock k04. I have no idea how that thing flows the air it does, but it has to stop somewhere, haha.
![]() | | #108 | ![]() |
| Not Ranked : 0 score timing is a magical thing lol
| The Following 7 Users Say Thank You to superskaterxes For This Useful Post: | BlueStreak (10-24-2011), Broxer (10-25-2011), cld12pk2go (10-25-2011), Dano (10-25-2011), Nataphen (10-24-2011), Realgib3 (10-25-2011), wolly6973 (10-25-2011) |
![]() | | #109 | ![]() |
(Thread Starter) | Not Ranked : 0 score Torque back above 400 ft-lbs after adding load in Post 6... Fully bolted except for the stock CBE...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 10-25-2011 at 08:39 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | BlueStreak (10-25-2011) |
![]() | | #110 | ![]() |
| Not Ranked : 0 score esp once you remove the knock limitation and can actually reach MBT....E85 is the holy grail to fast DD machines. 12pk the tune is coming along very quickly and nicely...I suppose if you peg the MAP and IF you have another $60-80 laying around you could pick up another MAP and pigtail I know you have already spent a ton of money lol
| The Following 2 Users Say Thank You to Dano For This Useful Post: | BlueStreak (10-25-2011), wolly6973 (10-25-2011) |
![]() | | #111 | ![]() |
![]() | | #112 | ![]() |
| Not Ranked : 0 score also dont forget that E85 just makes more power then pump gas because it has a higher energy value, so its not just the additional timing that people are seeing the gains from. my turbo is well beyond the compressor map and im still making power and not just blowing hot air.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | BlueStreak (10-25-2011), wolly6973 (10-25-2011) |
![]() | | #113 | ![]() |
__________________ '07 CWP MS3 Forged. | |
| The Following User Says Thank You to BlueStreak For This Useful Post: | wolly6973 (10-25-2011) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score right now about 4-5 but im only running a PR of 2.6 so as i upp the boost i will come back to the island if my efficiency drops off and i dont gain anymore g/s
![]() | | #115 | ![]() |
Groans: 31
1 gal of gas has 114,000 BTUs whereas 1 gal of e85 has 81,800 BTUs. That's unless you don't mean BTUs but something else?
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. | |
| The Following 3 Users Say Thank You to bmylez For This Useful Post: |
![]() | | #116 | ![]() |
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #117 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| Not Ranked : 0 score It takes more e85 to get the same result, that's why it takes ~35% more fuel volume to work properly. The main reason (I believe) for the gain in power is that it has cooler combustion, which allows the addition of timing up to MBT without race gas. You're going through fuel 35% faster, so it's not technically "more efficient", it's just that the way that it reacts to spark so happens to be better for making power. This is what I've understood from the research that I've read here and a few other places, but I could have misinterpreted. |
| The Following 6 Users Say Thank You to Nataphen For This Useful Post: | Alpha (10-25-2011), Broxer (10-25-2011), JacksonMS30 (10-27-2011), superskaterxes (10-25-2011), trf5000 (01-13-2012), wolly6973 (10-26-2011) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score ok heres where i remember reading what i said earlier, its from the attached document in the E85 FAQ sticky
![]() | | #119 | ![]() |
Groans: 31
| Not Ranked : 0 score Hmmm...although that seems to contradict what I posted, I think it's because he's talking about a pound of fuel instead of a GALLON. Volume and weight are different things entirely.
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | JacksonMS30 (10-27-2011), wolly6973 (10-26-2011) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score ^^^^ yes thats where i think our differences are
| GTX3071 build | JacksonMS30 | MazdaSpeed 3/6 - Big Turbo Builds | 767 | 05-18-2013 12:49 AM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
