 Old 11-03-2011, 09:47 AM   #1
Sines's Avatar
Posts: 1,102   (View Stats)
Sines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the world
Default Cobb or cp-e FMIC?
I'm trying to decide on which FMIC I want to buy. I want to do a BT build next summer so I am just trying to get the supporting mods for right now.
I wanted some input on people who have used these with a BT build.
09 CWP MS3 318WHP 349TQ
Sure Aeros // Sure Sidewinder // JBR 70 Duro Rmm // JBR Heavy Shift Knob // JBR EGR Delete // JBR TMM 88 Duro // JBR RSB // JBR SSP //JBR REAR CAMBER ARMS // Cobb AP Finkle Tuned 93/E85 Mix // Autotech HPFP Internals// Koni Yellows // H&R Springs // CNT Catted DP// NGK Iridium IX // Turboxs FMIC//
Sines is offline   Reply With Quote
 Old 11-03-2011, 09:59 AM   #2
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
For a BT FMIC you're better off getting custom.
 Old 11-03-2011, 10:05 AM   #3
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Def custom for a BT setup.
You can probably put one together for less too.
Beanfab / Tuned by Nishan
 Old 11-03-2011, 10:42 AM   #4
NoLeftTurn's Avatar
Posts: 188   (View Stats)
NoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the world
I used Cobb V2 Piping kit and a Treadstone TR8L core. Worked great and I am happy as the cobb kit worked with my MSCAI. I didn't like that CPEs core is off center of the car.
NoLeftTurn is offline   Reply With Quote
 Old 11-03-2011, 11:08 AM   #5
Groans: 1,443
tr8 is too small.
 Old 11-03-2011, 11:09 AM   #6
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
what about the intercooler delete?
The Following 2 Users Say Thank You to karl-hungus For This Useful Post:
Sacrilicious (11-03-2011), sick_role (11-03-2011)
 Old 11-03-2011, 11:17 AM   #7
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
run 10x D010 nozzles with 5x meth pumps...
Sacrilicious is offline   Reply With Quote
The Following User Says Thank You to Sacrilicious For This Useful Post:
karl-hungus (11-03-2011)
 Old 11-03-2011, 11:19 AM   #8
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
and just in case you didn't understand any of the above...custom
If my car lasts long enough, which it won't, BT+Custom FM.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 11-07-2011, 01:15 AM   #9
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
I can't speak of the Cobb, but I'm still running the CPE fmic w/ my GT3076, and it's been fine. I will easily hit 400awhp with this set up once I'm done tuning, and I have to live within the limits of the stock clutch, so that's where I'll be. I'm 15whp uncorrected from the 400 mark now, and running pig rich.
I was going to go custom TR8, which I may next summer. It depends what I feel like doing next year, and although the CPE is a bit smallish, it's not keeping me from my power goals.
 Old 11-07-2011, 01:19 AM   #10
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
pick up a used CX racing kit
and if/when you go BT, buy a new core, and make changes to the piping as needed
Rich-PMS is offline   Reply With Quote
 Old 06-24-2013, 03:56 PM   #11
dollarsignbill's Avatar
Posts: 51   (View Stats)
dollarsignbill is a splendid one to beholddollarsignbill is a splendid one to beholddollarsignbill is a splendid one to beholddollarsignbill is a splendid one to beholddollarsignbill is a splendid one to beholddollarsignbill is a splendid one to beholddollarsignbill is a splendid one to behold
Default Stock Clutch Limits
Does anyone know what the stock clutch limits are? I am having my engine rebuilt now and am wondering if i should thow in a CP-e upgraded clutch while im at it. My current clutch only has 28,000 miles on it so it has plenty of life left on it.
I searched for this answer around the forum and could not find it... I am a newbie though so have not really found out how to search efficiently yet.
Any insight is appreciated.
Thanks
dollarsignbill is offline   Reply With Quote
The Following User Says NO Thank You to dollarsignbill For This Un-useful Post:
load (06-24-2013)
 Old 06-24-2013, 04:00 PM   #12
sidekick's Avatar
Posts: 3,093   (View Stats)
EDIT: old ass thread
no more cobb fmic ? stageup MazdaSpeed 3/6 - ECU Computer Tuning 47 06-30-2009 05:42 PM
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Cobb Ap FMIC map with Cobb FMIC not driveable Unoriginalusername MazdaSpeed 3/6 - ECU Computer Tuning 119 07-20-2008 08:40 AM
Page generated in 0.31451 seconds with 30 queries
