Like Tree4Likes
 Old 05-14-2014, 10:13 PM   #1
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
I am not a fan of an s-shaped line either, I was thinking about something like this
and @torquemaniac; design should work perfect, you want the inlet on the flange to be roughly perpendicular to the bolt holes, this way you have a barb fitting on each side and a piece of hose, clean and simple.
Good luck with that. Considering the ewg housing of this turbo and the way the flange on the block sits this was the absolute best scenario. Keep in mind the tcase is NOT on in this picture. The tcase sits smack up against the flange on the block nearly. This mock up took about 3 days and many many fittings by trial and error. Most expensive oil return line hands down.
As far as flow, as long as there are no uphill or sags there should be no issue. Oil will continue to flow in the path of least resistance aka down. There are no dips or uphill sections in my line.
Haven't had an issue yet knock on wood.
Sent from my SCH-I605 using Tapatalk
Fuck MSF
avesfan101 is offline   Reply With Quote
The Following 2 Users Say Thank You to avesfan101 For This Useful Post:
Code Monkey (05-14-2014), kbz0129 (07-03-2014)
Code Monkey goes full retard racecar mode!!!! Code Monkey Mazdaspeed3/6 General Discussion 210 06-11-2014 03:09 AM
Page generated in 0.30022 seconds with 22 queries
