 Old 12-03-2011, 06:16 PM   #1
kriss90's Avatar
Posts: 110   (View Stats)
kriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant futurekriss90 has a brilliant future
Default Comp turbo
planning on going BT next year nd the shop whos gna install it for me recommended Comp turbo...i dnt know much about them...what do u guys think about their turbos...any ms6s out there using them???? thx for help
CPE FMIC, Turbosmart Dual Port, PTP fuel pump internals, Custom TIP+SRI, , 3in ebay dp,CP-E 3in CBE, Devils Own stage 2, Steedspeed mani, 38mm Tial wastegate, GT3076r, CPE Seals, ITV24, EBCS Grimmspeed, 3 bar map sensor, Cobb AP, SU rear engine mount, AWR transmission and passenger side mount, TWM stage 2 short shifter, J-Speed short shifter plate, SU countershift, sharkfin, RHO tow plate, Corksport mudflaps, BC BR-Type Coilovers, CPE center guage pod.
STOCK INTERNALS: 410 awhp, 371 awtq by RedMist
kriss90 is offline   Reply With Quote
 Old 12-03-2011, 06:19 PM   #2
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
I don't even know WTF you are talking about to be completely honest. Most guys run Garret 3071s & 3076s, and unless you are mechanically retarded I suggest you do this yourself.
 Old 12-03-2011, 06:28 PM   #3
kriss90's Avatar
if u look it ull know what im talking about...im just considering options...garret isnt the only turbo out there
nd im not mechanically retarded just no time to do it myself.
Last edited by kriss90; 12-03-2011 at 06:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-05-2011, 02:27 AM   #4
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
You don't have 5-7 hours to do it yourself? Wow you're pretty busy then.
You have a speed6 so to reach 400wheel I would at least look at a 3076 and would stay at a 3076 to keep costs down.
Just get a bolt on kit for little skrilla, use ATP hotside and have a bolt on solution. No extra downpipe or welding on it. Bam done. I am done buying all the parts for my build and did it less then 1500 dollars retaining the stock manifold for now.
Wow! Isn't that much easier?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 12-03-2011, 06:32 PM   #5
Metal409's Avatar
Posts: 316   (View Stats)
Metal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the world
Off topic, what year & color speed do you have? I work in Franklin Park, curious if i've ever seen you around.
2016 Ford Focus ST
2013 Ford Fusion Titanium AWD - Sold
2009 Mazdaspeed 3 GT - Sold
Metal409 is offline   Reply With Quote
 Old 12-03-2011, 06:37 PM   #6
MSFer87's Avatar
Groans: 83
After doing further research yeah def. never heard of them and the shop doing the install sounds directly tied into these guys. Hey if you got the money get shit done.
 Old 12-03-2011, 06:40 PM   #7
Police - Grammarhead
Vansquish's Avatar
No need to be so snippy,
Google is your friend.
NJSPEED3 (12-03-2011), Tokay444 (12-03-2011)
 Old 12-03-2011, 06:43 PM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Especially when I've never heard a gt3073.
Originally Posted by jdmoptiontune View Post
I don't even know WTF you are talking about to be completely honest. Most guys run Garret 3071s & 3073s, and unless you are mechanically retarded I suggest you do this yourself.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-03-2011, 07:28 PM   #9
MSFer87's Avatar
Groans: 83
Fixed *
 Old 12-03-2011, 07:14 PM   #10
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
On the Focus forums, I've lost count of how many guys have had oil seal problems with Comp Turbo. A few other guys got some monster size Comps, shootin for 600whp and they failed miserably. They switched to gt35 and got there. Just sayin, mang.
2007 CTS-V - Trying to sell
 Old 12-03-2011, 07:17 PM   #11
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Are you planning to run the oil-less triple ball bearing turbos that they make now? Personally I don't trust Comp turbos having had experience seeing a few of them fail on some friends cars.
It would, however, be different. For the money there's other options available that can be just as different....
NATOR PA
 Old 12-03-2011, 07:28 PM   #12
bmylez's Avatar
Groans: 31
Yeah, like Precision or Borg Warner turbos. Not many running around.
Alpha (12-03-2011)
 Old 12-03-2011, 09:20 PM   #13
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
wigglewigglewigglewigglewiggle YAH!
OP read this section and you'll know what works. At the same time there's no shame in trying something different.
Lets start with this, what is your goal for numbers and what is your budget for this build?
 Old 12-04-2011, 08:06 AM   #14
kriss90's Avatar
yea for now im just considering options to see whats out there...my goal is 400+ whp and budget around 3000 or so...metal409 uve probably seen me around its a red speed6, maybe at the stratz or something
 Old 12-04-2011, 11:00 AM   #15
Tripple OG
NJSPEED3's Avatar
Groans: 113
So $3000 to spend
and 400 whp
from looking at your sig, you need a dp,exhaust manifold,turbo, oil/coolant lines/ wastegate and dump pipe in case you go external.
I dont think you're going to have many options with this budget unless you go with a bolt on turbo kit, which your Comp turbo isnt.
stock flange
A basic bolt on turbo kit for our cars runs around $2500 to $3000 which would include:
atp turbo (gt series 3071,3076 or for a few hundred more the 35r) $1400+/-
exhaust manifold (steedspeed,dnp,pg) all go for around $600-$750 new
oil/coolant lines, miscellaneous crap $250
inlet/intake $250-$350
T3-T4
Aftermarket turbos
Everything is pretty much custom with an aftermarket turbo. You will need a down pipe fabbed up as well as an intake system. Many times guys have to relocate coolant lines to fit the inlet in place. I would say easy $4000-$4500 for a custom set up.
Also with either set up it would be good to run a meth kit which u also dont have. They go anywhere from $300 to $1000+. You will need an AP and a tune(see PERM for this) Now add the labor for your shop to install everything. You may want to save up some more $$$.
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
Easter Bunny (12-05-2011), kriss90 (12-04-2011), mtnrunner (12-04-2011)
 Old 12-04-2011, 08:18 AM   #16
bmylez's Avatar
Groans: 31
400whp can be had with a gt3076 @ 21 - 23psi, depending. I know Anthony was at 395 with a gt3071, but I'm sure you could eek some more out of it.
A Precision 5557 CEA (billet comp wheel) should get you there, as well.
Some sort of Borg Warner s200 series would do the job, and if you get one with extended tip technology, it sounds like fuckin tits.
 Old 12-04-2011, 10:19 AM   #17
MSFer87's Avatar
Groans: 83
BorgWarner S200SX 7670 Turbo - Full-Race.com check it out.
Calm down you Canadian Nazi troll. I fixed it.
Last edited by MSFer87; 12-04-2011 at 10:19 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to MSFer87 For This Useful Post:
GLORIFIEDBOZO (12-04-2011), Tokay444 (12-05-2011)
 Old 12-04-2011, 12:14 PM   #18
Tokay444's Avatar
Groans: 793
I'm calm bro.
You're the one who felt the need to quote the same post of mine twice in the same thread.
Demodded.
The Seals
kmac (12-05-2011), MSFer87 (12-04-2011)
 Old 12-04-2011, 11:23 AM   #19
bmylez's Avatar
Groans: 31
Yeah, I dropped a good 2200 on: manifold, turbo, downpipe, oil lines, gaskets, etc, etc. That was with a cheap turbo ($670). I already had AP, meth, and all other supporting mods.
Tuned myself and did the labor myself. Install was a nightmare, but don't let that scare you.
 Old 12-04-2011, 07:31 PM   #20
kriss90's Avatar
most likely im gna get 3076+ mani form one of the forum members so thats gna save me some money...i got the dp and 3in exhasut sorry gotta update the sig lol nd yes im gna go ewg
 Old 12-04-2011, 07:35 PM   #21
bmylez's Avatar
Groans: 31
Ok, but if you have a Mazda downpipe...that doesn't help you with T3.
 Old 12-04-2011, 09:19 PM   #22
kriss90's Avatar
well vband works with garret turbos doesnt it?
 Old 12-04-2011, 09:34 PM   #23
spoonher's Avatar
Posts: 636   (View Stats)
spoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the worldspoonher is the leader of the world
Groaned at 38 Times in 10 Posts
yes there are garrett turbos that are vband flanged for dp's
spoonher is offline   Reply With Quote
 Old 12-05-2011, 01:49 PM   #24
kriss90's Avatar
yes i got a 3076 and steedspeed mani so its all good...just need tip+intake nd some minor stuff
APP Translation : Speed Comp djuosnteisn
Cobb ATR Support
13 05-17-2014 07:17 PM
Building a new comp hyun Computers & Technology News 13 08-02-2010 07:28 PM
Boost Comp & RPM badams118
Cobb ATR Support
3 05-07-2009 12:36 PM
Stock comp pistions Grim Mazdaspeed3/6 General Discussion 14 09-17-2008 07:30 AM
Page generated in 0.42362 seconds with 29 queries
