Like Tree10Likes
 Old 11-03-2015, 01:17 PM   #1
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Default Corksport Turbo Install
Hey guys today I have begun my install of the Corksport drop in turbo. So far managed to get the top exhaust manifold heat shield and pb blasted the bolts on the exhaust manifold and other heat shield bolts. Now just going to wait a couple hours while I'm at class and go back to working on my car.
I am very excited to get this installed I hope I will not have any issues. I have a Cobb downpipe installed so I hope I do not have any issues removing the downpipe.
I am getting a e-tune form purple drank tuning and they informed me once I have everything installed I will be hitting 320 horsepower! So I am excited and hope the install go smoothly.
If any one has any pointers or tips please let me know I do not have much experience with this besides changing oil or other minor work on a car. Thanks!
pastry00 is offline   Reply With Quote
 Old 11-03-2015, 01:31 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Take your time, be especially careful with the hard oil drain tube. Make sure your oil feed/drain lines are well seated (and also coolant lines). Use all new crush gaskets for oil feed/coolant feed/drain and make sure the oil drain gasket is in good shape.
Give yourself plenty of time, don't rush it.
MINI H1 6.0 - CAR LED TAILS
brandontrek (11-03-2015), mazdaspeedmyk (11-03-2015), Micha (11-07-2015), pastry00 (11-03-2015), RalliartRsX (11-03-2015), WAMBUSHHHH! (11-04-2015)
 Old 11-03-2015, 04:52 PM   #3
pastry00's Avatar
Ok I will and all new gaskets are supplied with the corksport turbo.
 Old 11-03-2015, 05:15 PM   #4
brandontrek's Avatar
Posts: 132   (View Stats)
brandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the worldbrandontrek is the leader of the world
Also report back on how it drives after the install. Good luck!
Sent from my XT1575 using Tapatalk
brandontrek is offline   Reply With Quote
 Old 11-03-2015, 05:19 PM   #5
speed23's Avatar
Posts: 1,480   (View Stats)
If you have a speed6, try not to disconnect the lower oil return hardline from the engine block- its a PITA to reconnect...
troubled81 likes this.
 Old 11-03-2015, 06:16 PM   #6
Lol, I almost did that, but it is fortunately harder than disconnecting from the turbo. That turbo oil drain pipe on MS6 is probably one of the biggest PITAs ever. Not so much the removal, but the blind install and lining up with the gasket and turbo while contorting wrist 90 degress...Arrrrr. That was the hardest part of the install. Speed3 guys will never understand.
Code Monkey (11-03-2015), DingoDave (11-06-2015), Micha (11-07-2015), speed23 (11-03-2015), Vansquish (11-05-2015)
 Old 11-03-2015, 06:20 PM   #7
Fuck that line. Or better, that lack of space between the engine and the TC.
 Old 11-04-2015, 01:03 AM   #8
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
Planning similar upgrade on my MPS6 soon. Nice to get some advise on the do's and don'ts.
MRR is offline   Reply With Quote
 Old 11-04-2015, 06:23 AM   #9
nice first post intro. and you can search to find out those do's and don't.
 Old 11-04-2015, 07:25 AM   #10
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
PA member Y U NO NATOR WIT US!!!!!
Good luck with the install! Come bullshit with us in the NATOR PA section if you have any questions. Between the gaying around we do have some decent knowledge should you need it...talk nice enough that might turn into a free handy!
The Following 3 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
f15ms6 (11-10-2015), MD1032 (11-04-2015), pastry00 (11-04-2015)
 Old 11-04-2015, 07:34 AM   #11
pastry00's Avatar
Thanks for the input. I will report back once I am done on how it went. Currently 3 of the bolts on the downpipe are stuck so I am working on those. Other then that everything is going good so far!
If anyone can help I am trying to install the corsport bar map sensor but the 7 mm screw that holds it on is stuck and is almost stripped any reccomendations?
 Old 11-04-2015, 04:03 PM   #12
pastry00's Avatar
Never mind I got it. I just have one bolt left on the exhaust manifold to get off and the turbo should be ready to come out. So far I have not ran into that many issues that stumped me for a while. Other then getting a face full of coolant haha
This might sound stupid but to refill the coolant once I'm done I just start the car then fill her up correct? How would I get rid of air bubbles and an reccomendations on coolants?
 Old 11-04-2015, 05:24 PM   #13
speed23's Avatar
Youll need mazda specific coolant or "asian" coolant.
 Old 11-04-2015, 05:35 PM   #14
MRR
MRR's Avatar
Thanks,
There is so much info in this forum.
My MPS6 has this mods so far;
TIH 3' with K&N panel filter (want it discrete, Cops here don't want panel filter. Lost of cars get defected)
Turbosmart BOV plumb back (very quite)
CS Boost controller
CS engine and trany mounts
CS Downpipe
CS hi flow Cat
CS HPFP
Denso FP
Street Unit TMIC
DCR VVT cam gear and chain
COBB accessport and race tune software.
From the cat back is stock to keep the car silent and stockish in the eyes of anyone.
Currently running stage 3 98 with a few changes to suite my mods. Boost limited to 18 psi by setting WG duty cycle.
Car wheel spins on second gear every time the turbo kicks in.
Use to own a Nissan 200sx fully modified for racing. This MPS6 is different, its got enormous torque.
 Old 11-04-2015, 05:55 PM   #15
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Thanks,
CS Boost controller
CS Downpipe
CS hi flow Cat
CS HPFP
Denso FP
Street Unit TMIC
*blink*
Not stupid at all. Most Japanese cars, the overflow tank is separate and not under pressure and the rad cap incorporates a check valve to bleed small amounts of air out of the system automatically, and these systems have to be bled of air manually while running in my experience (link to how-to) any time any significant amount of air is introduced (eg coolant flush). MS6's have to deal with this. Mazda3's on the other hand use an expansion tank like Fords, where the overflow tank is part of the pressurized system...therefore the system is self-bleeding and you do not need to do anything but fill it back up if the level drops considerably.
2007 Mazdaspeed3 GT
The Following 4 Users Say Thank You to MD1032 For This Useful Post:
Code Monkey (11-10-2015), f15ms6 (11-10-2015), pastry00 (11-05-2015), roguemazda (11-08-2015)
 Old 11-05-2015, 08:27 AM   #16
Thanks,
CS Boost controller
CS Downpipe
CS hi flow Cat
CS HPFP
Denso FP
Street Unit TMIC
LOL WUT.
MAKE YOUR OWN THREAD, GUY!
MD1032 and MS3Shadow like this.
The Following User Says Thank You to WAMBUSHHHH! For This Useful Post:
Micha (11-07-2015)
 Old 11-06-2015, 07:48 PM   #17
pastry00's Avatar
Finally got the turbo out should be putting the new one in on Sunday. Can't wait to drive my car again.
 Old 11-07-2015, 11:57 AM   #18
Freelan3r's Avatar
Posts: 1   (View Stats)
Freelan3r is an unknown quantity at this point
Can't wait to hear about the results. I'm relatively new and need to make a thread for my build, but was looking into this after I order my corksport turboback
Freelan3r is offline   Reply With Quote
 Old 11-07-2015, 06:30 PM   #19
pastry00's Avatar
Does anyone know I am about to put the turbo in but when I install the corksport boost control solenoid should I run it in interrupt mode or bleed mode. Which is better and why?
 Old 11-07-2015, 06:52 PM   #20
MD1032's Avatar
Groans: 143
I like the simplicity of interrupt from a routing standpoint.
2007 Mazdaspeed3 GT
WAMBUSHHHH! (11-08-2015)
 Old 11-07-2015, 06:56 PM   #21
pastry00's Avatar
Ok I understand the difference in routing but why would you use one method over the other?
 Old 11-08-2015, 12:40 AM   #22
broda's Avatar
Posts: 375   (View Stats)
(Simplified version)
In 2 port mode (bleed) it will simulate the stock BCS, but it'll be more responsive and you won't have to tune for it.
If you go 3 port you'll overboost if you don't tune for it, but you'll have more control and should spool a bit quicker when you do. This is what you want with a larger turbo since you should be getting a tune anyway.
Also, nice to see someone else in the area.
The Following User Says Thank You to broda For This Useful Post:
 Old 11-09-2015, 07:40 PM   #23
pastry00's Avatar
Default Help
So I got the turbo in but the car will not start. So far I ruled out the tune and a dead battery. If you guys have any idea of what to look for please let me know. I double checked that I reconnected everything and its all good so I do not know what is wrong?
 Old 11-09-2015, 07:44 PM   #24
MD1032's Avatar
Groans: 143
Will it turn over? Did you check for spark?
2007 Mazdaspeed3 GT
 Old 11-09-2015, 07:46 PM   #25
pastry00's Avatar
It will not turn over at all. You hear the fuel pump kicking in but that is it. The car makes no other noise when I turn the key.
 Old 11-09-2015, 07:51 PM   #26
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Common Problems and How to Diagnose
Edit: check the starter cable give it a jiggle.
ms3gt08 likes this.
MECP
2012 BM
Rfinkle tune in progress
 Old 11-09-2015, 08:03 PM   #27
pastry00's Avatar
Checked the ground near the HPFP everything seems to be good there. I don't know what is wrong the car will not even try to start.
 Old 11-09-2015, 09:37 PM   #28
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
inb4 it's the security system cuz his key fob battery is dead... or he forgot to plug the car in... one of the two fur suuure
acemanz is offline   Reply With Quote
 Old 11-09-2015, 09:51 PM   #29
Police - Grammarhead
Vansquish's Avatar
Did you check the grounding wire on the starter?
Originally Posted by Meanmx5 View Post
So leme get this straight... Sum guy that obviously threw sum money at msf atempted doing somthing that he shouldnt be doing jacked up his ride b4 even starting it up and you coddle him?
I have been reading these fourms for a long time and when "non donators" do things with no help and every thing works to profection you badger them to death?
No need to be a dick. @pastry00; has been a pretty pleasant new addition to the forum, despite his n00b-ness.
No disrespect to you what so ever pastry00
...says anyone who ever wanted to disrespect someone else and make sure to be the center of attention.
i am just pointing a key issue wrong with msf. Even though it is by far the best mazda site for all things mazda ever it does raise a political eyebrow.
You're the only one who's raising the issue here. Nobody else decided that another person's turbo install thread (which has stayed on topic until your post) should become an arena for so-called "political" complaints about the way the forum functions.
Chances are pastry00 you probably just missed a plug in or somthing cuz you were overwhemd with gittyness.. I was the same way with the damn heat shield that came with the cs turbo. I compleatly forgot about that fucker once i got the car started up. Just retrace your steps and check connections. Its probably stareing you in the face and you dont relize it. Best of luck.
Why not just say this part instead of getting shitty?
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
DaUberSchwebel (11-10-2015), Djohns (11-09-2015), frothy (11-09-2015)
 Old 11-09-2015, 10:10 PM   #30
Djohns's Avatar
Posts: 3,944   (View Stats)
Just a thought but are you throwing any codes? Is it possible you can maybe upload some pictures of everything and maybe we can see something you're overlooking? It's easy to overlook stuff when you've been at it all day
No disrespect to you what so ever pastry00 by any means i am just pointing a key issue wrong with msf. Even though it is by far the best mazda site for all things mazda ever it does raise a political eyebrow.
The man is attempting to do this on his own for the first time and for a learning experience. By no means is he asking to be spoon fed or asking for someone to come help him off the bat. Also how could you be "reading these forums for a long time" when you joined last month according to your profile
2010 black mica speed3
Soon:built motor
Last edited by Djohns; 11-09-2015 at 10:13 PM. Reason: MSF Database - Automerged Doublepost
frothy (11-09-2015), Vansquish (11-09-2015)
 Old 11-09-2015, 10:32 PM   #31
frothy's Avatar
Posts: 1,067   (View Stats)
@Raider; , is Meanmx5 another jboss23 account?
They share a very similar lexicon...
The Following 5 Users Say Thank You to frothy For This Useful Post:
Djohns (11-09-2015), MS3Shadow (11-10-2015), Raider (11-10-2015), SofaKingAwesome (11-10-2015), Vansquish (11-09-2015)
 Old 11-09-2015, 10:45 PM   #32
Djohns's Avatar
Hmmm good point... He also mentions the heat shield like jboss.
Soon:built motor
 Old 11-10-2015, 07:44 AM   #33
pastry00's Avatar
I have checked everything again and it is all connected. If you see anything I'm missing let me know. Thanks
Starter Ground and gauges.
 Old 11-10-2015, 07:50 AM   #34
Djohns's Avatar
How did you rule out it wasn't your battery?
No pcm means you're missing a plug
Soon:built motor
Last edited by Djohns; 11-10-2015 at 07:50 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-10-2015, 07:50 AM   #35
pastry00's Avatar
I tried jumping the car.
I got the pcm because I did not have my intake in or the maf sensor plugged in.
 Old 11-10-2015, 07:56 AM   #36
broda's Avatar
Did you make sure that your ECU plugs were pushed in all the way? One time when I put them back in, they were just a tiny bit backed out and my car wouldn't start.
 Old 11-10-2015, 08:02 AM   #37
Djohns's Avatar
also with abs code being on I'm 100% percent convinced you missed a plug somewhere or you crossed two plugs.
Soon:built motor
 Old 11-10-2015, 08:14 AM   #38
pastry00's Avatar
Ok so I just hooked everything up car still will not start and these were the only codes the accessport was giving me.
What do you mean by crossed two plugs? I checked all of the onesi unplugged and all of them are plugged in all the way.
 Old 11-10-2015, 08:23 AM   #39
Djohns's Avatar
by that I mean possibly plugged something in the wrong port. Just a thought.
Soon:built motor
 Old 11-10-2015, 08:26 AM   #40
pastry00's Avatar
Yea I have checked every wire and everything is in the right place. Could disconnecting the coolant lines and getting air in the lines stop the car from starting? Other then that I am out of ideas.
CorkSport Coilover Install yasun 2010 MS3 - Suspension & Brakes 65 02-09-2016 09:12 PM
Corksport coilovers install help 07TRMS3 MazdaSpeed 3/6 - Suspension & Brakes 15 03-07-2013 12:48 PM
corksport sri install.....wow!!! killerb87 2010 MS3 - Engine, Transmission & Driveline 18 08-03-2011 03:15 PM
CorkSport FSB Install ADlBOO CorkSport 0 06-27-2011 06:36 PM
Corksport DownPipe Install Akira 2010 MS3 - How-To's 62 04-02-2011 11:12 PM
Page generated in 0.70636 seconds with 36 queries
