 Old 04-11-2015, 10:27 PM   #1
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
Ok I'll give that a shot...my problem seems to be when I pull the manifold off the studs and try to rotate it forward to pull it out the compressor housing hits that metal piece on the firewall however doing what you did I should just be able to lift it right up. Thanks man
Under Construction
Last_Loser is offline   Reply With Quote
CPe EWG Turbo Manifold vs. ATP EWG Turbo housing cam1391 MazdaSpeed 3/6 - Big Turbo Builds 13 01-30-2015 07:12 AM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
Page generated in 0.23598 seconds with 21 queries
