 Old 04-11-2015, 06:22 PM   #1
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
Default Cp-e Manifold and Turbo
Ok so before I go any farther trying to get this shit out lemme ask...I am trying to get the manifold and turbo out all as one piece, has anyone had any luck doing that? Has anyone installed it that way or removed it like that? I unbolted the rmm like I did to install the manifold but it seems as if my tmm is hindering it from moving up enough...Ive given up for the night just wanted to see if it was even possible before I spend more time trying to do it that way or it I should just separate and pull it that way.
Under Construction
Last_Loser is offline   Reply With Quote
 Old 04-11-2015, 09:10 PM   #2
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I have lifted and lowered my cpe mani with the 3076 bolted on it many times now, all motor mounts still in place. What you do is to remove the windshield cowl+wipers+wiper motor and also the plate under the cowl that runs along the engine bay.
Here is a pic of how it looked after I removed all that and lowered mani+turbo down into place:
One more thing you can do to make it easier is to cut the hardpipe that points out from between the mani and windshield. I cut that down to about 1"
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Last_Loser (04-11-2015), Swinger13 (04-11-2015)
 Old 04-11-2015, 10:27 PM   #3
Last_Loser's Avatar
Ok I'll give that a shot...my problem seems to be when I pull the manifold off the studs and try to rotate it forward to pull it out the compressor housing hits that metal piece on the firewall however doing what you did I should just be able to lift it right up. Thanks man
Under Construction
CPe EWG Turbo Manifold vs. ATP EWG Turbo housing cam1391 MazdaSpeed 3/6 - Big Turbo Builds 13 01-30-2015 07:12 AM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
Page generated in 0.25125 seconds with 21 queries
