![]() Join Date: Jun 2008 Location: Oceanside, CA
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score ok starting a data log at 3k rpms, mash it right at 4k rpms cuts then goes then at 6k rpms cuts again on the dash hawk it looks like the ingector shut down like i let off... ANY IDEAS??? mods-fully bolted brn-stge 3 turbo 18psi no meth |
![]() Join Date: Nov 2009 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Fuel pump?
__________________ Mazdaspeed3 E85 ~ Sold 333/383 Mazdaspeed6 #10018 TiGrey Forged Internals, PTE5858. 2015' Freektuned on 93Octane 322/337 (stock top mount and BPV) 2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor) 2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling) Mazda CX-5 AWD Daily |
(Thread Starter) | Not Ranked : 0 score yes fuel pump logs will be posted soon |
![]() Join Date: Apr 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 577
Groans: 38
| Not Ranked : 0 score ... edit: not sure if I posted them right but theres 3 logs of his car cutting. last log shows 4.2 kr, normally see no more than 2 degrees of kr so im not sure what thats about. the cut feels like a fuel cut but fuel pressure stays high the whole time. maybe a load cut or ignition problem (coilpack blowing out under load)? had water in spark plug tubes in the past causing a misfire... |
(Thread Starter) | Not Ranked : 0 score logs posted right above |
Groans: 31
| Not Ranked : 0 score Uhh...what are you tuning with? If you're taking DH logs and not AP, please don't tell me you have a Standback. Also, when I try to open those logs, it says I need the associated .LRP file.
Groans: 38
| Not Ranked : 0 score yeah he is running a SB, using the DH to datalog since a working laptop is not available to log with the SB while driving.... From what I gather his car is hitting a load cut. On runs where it doesnt cut the afr is steady 11's to low 12's, the KR never goes over 2* usually like .7* or so, and fuel pressure is <1700. When it cuts, its like the injectors shut off, feels like a fuel cut but the logs never show FP dropping. It gets worse with increased boost or cold weather... Time for the load cut flashes or switch to AP..? |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 539
| Not Ranked : 0 score Yeah those logs are posted completely wrong, post a .csv file.
__________________ 2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03 FREEKTUNE |
| The Following User Says Thank You to Boost Addict For This Useful Post: | bykeryder4life (12-15-2011) |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score i hope you mean >1700 |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | bykeryder4life (12-15-2011) |
Groans: 38
| Not Ranked : 0 score hah yes sorry its above 1700psi |
Groans: 31
| Not Ranked : 0 score Go AP....NOW!!! SB sucks so much cock.
Groans: 38
| Not Ranked : 0 score lol SB is a good tuning device man, It just depends on your setup and hp goals. I parted out long ago and sold my ms3 but back when I had it, I ran SB with no problems and the car ran really well, made good #'s. Anyhow, the OP is now looking into getting an AP since the SB aint working for his setup and goals so updates will be posted when they come... |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| The Following User Says NO Thank You to ScarMS3 For This Un-useful Post: | bykeryder4life (12-15-2011) |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score alot has changed since then man
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
(Thread Starter) | Not Ranked : 0 score ya AP is the way i gotta go from what i hear... |
| MS6 - Cutting OEM Springs | FADE2GRY | MazdaSpeed 3/6 - Suspension & Brakes | 54 | 10-14-2013 06:59 PM |
| Cutting at WOT | skiptowncat | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 50 | 09-26-2011 01:23 PM |
| Still cutting | ms310 | 2010 MS3 - ECU Computer Tuning | 47 | 04-21-2011 10:54 AM |
| Car Bucking and Cutting | Phantom | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 08-11-2009 10:38 PM |
| Cutting ECU Wires | kingpin748 | MazdaSpeed 3/6 - ECU Computer Tuning | 22 | 08-10-2008 10:59 AM |
