Like Tree39Likes
 Old 09-26-2014, 02:35 PM   #81
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
did u do the mod for nuts on the injectors?? it is well worth it and a time and headache saver if you ever have to pull them again. great lookin build by the way... cant wait to get home in January and do my build. How long did the build take u in days like if u work full 6-8hrs on it a day. I have a month ill be home and kinda wanna know if it will be possible to do my build in a month when im home.
It took a 2-3 hours to pull the motor after all the electrical crap was disconnected, putting it in was about the same. Honestly though a lot of this was done over the course of 7 months so very hard to say time wise like that. If you have a full month of full days then you might be able to do it in 2-3 weeks with machining of the block and all.
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 09-29-2014, 11:06 PM   #82
derek13p's Avatar
Groans: 38
Vdyno of a 4th gear wot log tonight on the base breakin tune. Ready to turn it up.
@ms3blackmica; I'm ready for some tunez. Logs sent. Lets see what this girl can do!
06 MS6 & 06 MS6
Daily driven
The Following 6 Users Say Thank You to derek13p For This Useful Post:
Code Monkey (09-30-2014), dan7225 (09-30-2014), Hammology (09-30-2014), ItsNox (09-30-2014), Micha (03-22-2015), Pu Manchu (09-30-2014)
The Following User Says NO Thank You to derek13p For This Un-useful Post:
Rich990 (11-06-2014)
 Old 10-13-2014, 02:59 PM   #83
derek13p's Avatar
Groans: 38
Some shots of the new valve cover and SpeedPerf6rmanc3 breather cap.
Should have another map tonight to go do some runs in!
06 MS6 & 06 MS6
Daily driven
The Following 8 Users Say Thank You to derek13p For This Useful Post:
Code Monkey (10-13-2014), ItsNox (10-19-2014), Kellerspeed3 (10-13-2014), ms3blackmica (10-13-2014), Poohster (10-13-2014), pzr2874 (10-13-2014), Realgib3 (10-13-2014), rymanmazda (10-13-2014)
 Old 10-13-2014, 03:27 PM   #84
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Rode in this bitch yesterday, can't wait to see it fully tuned
derek13p (10-13-2014)
 Old 10-19-2014, 10:55 AM   #85
derek13p's Avatar
Groans: 38
Cleaned up the wiring thanks to @KotzurRacing; and getting ready for some port injection in the tune! Looks a lot nicer now.
Can anyone confirm the wiring of the split injection controller for the MS6 for me? I tapped the middle wire of the MAF sensor for the green(MAF) wire on the controller, the red power wire from the controller I did an add a fuse to the Eng Bar in the fuse box, and the ground I put to the top of the HPFP. As for the yellow ones, we found the coil wires that did not have a common wire with the other coils, which may be where the problem is as I have no instruction on which wires to tap. @SPEEDPERF6RMANC3; would you be able to give some input? I know yall have done a few 6s with this kit.
06 MS6 & 06 MS6
Daily driven
 Old 10-19-2014, 06:28 PM   #86
stevenlapensee's Avatar
Posts: 881   (View Stats)
stevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the worldstevenlapensee is the leader of the world
Groaned at 9 Times in 9 Posts
Looks good man. Hope you get the wiring issue figured out.
Gen2 Bolted E85 BNRS3--SOLD
'14 Sterling Gray 5.0 w/ TrackPack -- AED Tuned on E85 - Ford Racing 47# Injectors - Lethal Performance Catless H Pipe - GT500 Axelbacks - MGW Full Shifter - BMR Springs - BMR Panhard Bar - BMR LCAs - BMR LCA Relocation Brackets - Maximum Motorsports CC Plates - SS Clutch Line - JLT PS Oil Separator - BOSS LS Wheels 19x9/10
stevenlapensee is offline   Reply With Quote
 Old 10-19-2014, 07:25 PM   #87
COCKSTRONG
Groans: 890
What should the condition for the power be? And there's got to be a better ground than that.
 Old 10-19-2014, 08:29 PM   #88
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Tap the very far left wire on each coil pack plug.
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
derek13p (10-21-2014), Micha (12-14-2014)
 Old 11-30-2014, 07:54 PM   #89
update?
The Following 2 Users Say Thank You to stevenlapensee For This Useful Post:
ItsNox (12-02-2014), SofaKingAwesome (12-01-2014)
 Old 12-03-2014, 09:39 AM   #90
derek13p's Avatar
Groans: 38
Originally Posted by stevenlapensee View Post
update?
Nothing major yet. Was getting it tuned but the 3.5in intake wasn't big enough cause the engine was flowing a lot more than expected, so had to order pipe to make a 4 incher, and with getting a new job and working till 930 every damn night its harder to get shit done.
@KotzurRacing; fab'd up a 4in for me on sunday though, and changed a bad wheel bearing.
I'm now getting a almost whining sound coming from the front suspension when turning left(driver side), only while moving, not while stopped. Gotta figure out what that is next.
Got a set of brembos on the way for the front and will be ordering coilovers next paycheck, then get some new bushings and what not and do some maintenance for her.
But yeah, should be getting a new map for the 4in soon and do some maf cals and then get back to port injection and then e85.
I learned that on the first map of port injection I can get some good wheel spin in the rain and get pretty damn sideways in the corners haha..
06 MS6 & 06 MS6
Daily driven
The Following 7 Users Say Thank You to derek13p For This Useful Post:
Code Monkey (12-03-2014), ItsNox (12-06-2014), Kellerspeed3 (12-05-2014), Macncheese (02-22-2015), Micha (12-14-2014), rymanmazda (12-03-2014), stevenlapensee (12-03-2014)
 Old 12-03-2014, 05:10 PM   #91
derek13p's Avatar
Groans: 38
Ordered some ISC coilovers today. Hope they are good!
06 MS6 & 06 MS6
Daily driven
 Old 12-03-2014, 08:24 PM   #92
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Just wait for when we're 30+ PSI deep.
You'll quickly find out that an MS6 becomes a F-Body Camaro LOL
MSP611 likes this.
www.tunedbynishan.com
The Following 7 Users Say Thank You to ms3blackmica For This Useful Post:
Cdnspeed6 (07-09-2016), derek13p (12-04-2014), Hammology (01-27-2016), ItsNox (12-06-2014), KotzurRacing (12-03-2014), Micha (12-14-2014), MSP611 (10-31-2015)
 Old 12-03-2014, 08:36 PM   #93
I can haz custom intake too?
 Old 12-03-2014, 09:35 PM   #94
KotzurRacing's Avatar
Posts: 444   (View Stats)
KotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the worldKotzurRacing is the leader of the world
Hit me up when you want me to build you one. Just finished a 3.5 intake for a k04 car
Code Monkey and ItsNox like this.
COBB BROKE JMS FIXED
MazdaSpeed. Errrone can afford
KotzurRacing is offline   Reply With Quote
The Following 4 Users Say Thank You to KotzurRacing For This Useful Post:
Code Monkey (12-03-2014), hatchedspeed3 (12-08-2014), ItsNox (12-06-2014), Macncheese (02-22-2015)
 Old 12-05-2014, 07:37 PM   #95
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
just out of curiosity, since you seem to be a machinist. Is there a specific spot where you pin the cams? do you have to time them first so you know the links and teeth line up and them drill them? or just say screw it and drill a hole?
sleeperstang1994 is offline   Reply With Quote
 Old 12-05-2014, 09:55 PM   #96
Every set is different. Must set timing first. We used a set of allen headed bolts, torqued them and then drilled through the sprocket and cam. Intake cam is a different story. It has four holes for the vvt and the last thing you want to do is drill one of them.
hatchedspeed3 (12-08-2014), ItsNox (12-06-2014), Micha (03-22-2015), sleeperstang1994 (12-07-2014)
 Old 12-07-2014, 09:35 AM   #97
derek13p's Avatar
Groans: 38
a little flyby a while back.
06 MS6 & 06 MS6
Daily driven
BLKSTIG (12-07-2014), Boostin'likeAboss (12-09-2014), Code Monkey (12-07-2014), Hammology (06-11-2015), hatchedspeed3 (12-08-2014), Macncheese (02-22-2015), Pu Manchu (12-08-2014), pzr2874 (12-09-2014)
 Old 12-07-2014, 07:11 PM   #98
so you basically time the engine complete with the allen headed bolts tighten everything down and then just unbolt the cams and take them to your drill. that way you know your chain and all the teeth will line up properly? seems easy when i write it down like that lol... i know its probably not. thanks for the clarification!
 Old 12-07-2014, 11:33 PM   #99
yes yes and yes it is simply, just take note of the four holes in the intake cam and drill between them. We got it right the first time we had every done any(dereks cams being the first set). speedperformance said they have some kind of JIG but not really sure what that means if all the car set up differently.
The Following 2 Users Say Thank You to KotzurRacing For This Useful Post:
derek13p (12-08-2014), sleeperstang1994 (12-08-2014)
 Old 12-08-2014, 11:53 PM   #100
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
car looks great derek. props to you and @KotzurRacing; on an awesome build. im going to try and finish up my shitbox this weekend so I can actually come see you guys again.
2009 CWP MS3 1-23-2014
derek13p (12-15-2014)
 Old 02-11-2015, 06:02 AM   #101
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
I wonder if my wife will let me do this to her MS6 one day. Can I claim better gas mileage?
On a serious note: this is a damn awesome build. Good luck, @derek13p;. Please tell me you are going to air brush either a Unicorn or Chuck Norris on the hood.
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following User Says Thank You to sporkbomb For This Useful Post:
derek13p (02-11-2015)
 Old 03-21-2015, 08:39 AM   #102
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
Nice meeting you out at TX2k man, build is looking good!
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
The Following User Says Thank You to kashbringer For This Useful Post:
derek13p (06-11-2015)
 Old 06-11-2015, 05:32 AM   #103
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
updates?
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 06-11-2015, 12:55 PM   #104
Originally Posted by levon.mark View Post
updates?
Yes derek has been super busy with work. Trying to get him to post the results. Car is RIDICULOUSLY STUPID NASTY made really great power for the low amount of boost hes running.
The Following User Says Thank You to KotzurRacing For This Useful Post:
BLKSTIG (06-11-2015)
 Old 06-11-2015, 09:52 PM   #105
derek13p's Avatar
Groans: 38
updates?
Made 613awhp and 519awtq at JMS in San Antonio.
Did some powdercoating, got a turbo blanket. Next will be a bigger IC and a 6466 a different tuning solution and some axels.
06 MS6 & 06 MS6
Daily driven
The Following 13 Users Say Thank You to derek13p For This Useful Post:
BLKSTIG (06-12-2015), Code Monkey (06-11-2015), Hammology (06-11-2015), ItsNox (06-18-2015), Kellerspeed3 (06-14-2015), KotzurRacing (06-12-2015), levon.mark (06-15-2015), Mazdazilla6 (10-31-2015), Micha (10-31-2015), pixelNate (01-27-2016), Pu Manchu (06-12-2015), SarcasticOne (06-11-2015), SpeedRebirth (06-11-2015)
 Old 06-11-2015, 10:17 PM   #106
MSP611's Avatar
Posts: 2,291   (View Stats)
Some monster numbers!!! This is on a 6266 or 6262?? Are u running e85mix??
In progress:
derek13p (06-12-2015)
 Old 06-11-2015, 11:47 PM   #107
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
The post above you says 6466.
EDIT: Im dumb, he said next up is 6466.... fuck my mouth.
EDIT #2 : GT3582
Built motor
GTX3071
Meth
6th Port
The Following 2 Users Say Thank You to Hammology For This Useful Post:
derek13p (06-12-2015), Micha (10-31-2015)
 Old 06-12-2015, 12:03 AM   #108
Hammology's Avatar
Groans: 36
Looks fast as fuck. What psi? And what rpm are you hitting max boost?
Built motor
GTX3071
Meth
6th Port
 Old 06-12-2015, 08:35 AM   #109
derek13p's Avatar
Groans: 38
I'll hit boost around 3500ish. 30-32psi. 50-50 e85 mix.
Its pretty fun for sure lol.
06 MS6 & 06 MS6
Daily driven
The Following 3 Users Say Thank You to derek13p For This Useful Post:
BLKSTIG (11-01-2015), Hammology (06-12-2015), MS3Shadow (06-12-2015)
 Old 06-15-2015, 03:24 AM   #110
levon.mark's Avatar
zayumm nice work ! I remember seeing this car on JMS's Instagram, but wasn't sure if it was yours?
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following User Says Thank You to levon.mark For This Useful Post:
derek13p (10-31-2015)
 Old 06-17-2015, 06:01 PM   #111
BlackEscortGT's Avatar
Posts: 161   (View Stats)
BlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond reputeBlackEscortGT has a reputation beyond repute
holy shit. this build thread has me totally erect!!! so much inspiration. mid motor build myself on my vrm ms6
2006 vrm mazdaspeed 6
304awhp/327awtq on k04 tuned by socks
build coming soon....f cylinder #3
2003.5 mazdaspeed protege. turbo daily/montain monster......ounce the motor is in
BlackEscortGT is offline   Reply With Quote
The Following User Says Thank You to BlackEscortGT For This Useful Post:
 Old 10-31-2015, 09:06 AM   #112
derek13p's Avatar
Groans: 38
Got another speed6 so that's taken up a bit more of my time and money, but the red one will definitely continue to become more of a beast!
It put a 5 car whoopin on an evo 9 the other day going to cars and coffee. That was just 2nd and 3rd gear too
ItsNox likes this.
06 MS6 & 06 MS6
Daily driven
BLKSTIG (11-01-2015), Code Monkey (10-31-2015), DingoDave (10-31-2015), KotzurRacing (10-31-2015), pzr2874 (11-05-2015), SpeedRebirth (01-26-2016)
 Old 10-31-2015, 11:59 AM   #113
MSP611's Avatar
mmm this is nice (borat accent)!!! thts crazy u are spooling tht fast with this monster!! highly impressed
In progress:
 Old 01-26-2016, 01:45 PM   #114
@derek13p; Where'd you buy the kit to pin your cams?
Also, anything new? Sticking with the t3 flange when you change turbos?
 Old 01-26-2016, 02:28 PM   #115
No kit used. I bought some dowel pins and set the timing on the motor, then installed some Allen head bolt in the cams. Then removed the cams from the motor, built a jig for my drill press and went to town. Was way easier then I thought it would be. Took about 5 mins to drill both cams, just marked the vvt holes in the cam first so that we didn't drill into them.
BlackEscortGT likes this.
Mazdazilla6 (01-26-2016), SpeedRebirth (01-26-2016)
 Old 01-26-2016, 04:06 PM   #116
Where did you get the dowels from though?
 Old 01-27-2016, 12:31 AM   #117
A place in town called quality fasteners very similar to fastenall
Mazdazilla6 (01-27-2016)
 Old 07-05-2016, 09:15 AM   #118
derek13p's Avatar
Groans: 38
http://www.mazdaspeedforum.org/forum/foru...-gt500-203391/
Little race a buddy caught on film for me.
06 MS6 & 06 MS6
Daily driven
The Following 4 Users Say Thank You to derek13p For This Useful Post:
chris323 (07-05-2016), MS3Shadow (07-05-2016), pixelNate (07-05-2016), Thor Hammer (07-05-2016)
 Old 07-05-2016, 01:22 PM   #119
MSP611's Avatar
hey question @derek13p; how did u setup ur ITFP? u have an upgraded ITFP?
In progress:
 Old 07-05-2016, 02:13 PM   #120
derek13p's Avatar
Groans: 38
Yeah, upgraded in tanks. Got the sp63 kit. I think I show it somewhere in this thread maybe, I forgot.
Edit: Post 66 on 2nd page is where it shows it.
Btw, you have the longest signature I've ever seen lol
06 MS6 & 06 MS6
Daily driven
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.60273 seconds with 36 queries
